Old 09-28-2010, 08:48 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
My Experience with POR-15 on my A-Frame
I spent the last couple weekends sanding, prepping, and painting my Overlander A-Frame using the POR-15 system. I have to say the POR-15 system is expensive but the final results are impressive. In case you're not familiar with the system, it includes three products Marine Clean, Metal Ready (or Prep and Ready), and the paint itself.
I bought silver POR-15 paint for my A-Frame, but it doesn't really matter what color you use since a top coat paint must be applied (the paint doesn't have any UV resistant properties). When the paint drys (it took about 7 hours here in the low humidity of Phoenix) it provides a tough coating for the metal which is highly resistant to rust. I used Metallic Rustoleum spray paint for my top coat and I'm pretty happy with the overall appearance.
Oh yeah, you may have heard that this paint is impossible to remove from your skin and it's true. I took all of the precautions to prevent this from happening, wearing gloves and a long-sleeve shirt, but somehow I still got some paint on my right wrist. I'm told that it takes a week for the paint to finally wear off of your skin. We'll see.
ID:	111860   Click image for larger version
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-28-2010, 11:28 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
For an alternative approach, I've used wire brushing or a flapper wheel in an angle head grinder to clean the surface, phosphoric acid to prepare the surface for paint, and then an aluminum bearing moisture curing polyurethane paint such as Aluthane . Seems to work well, and @$30/quart and no top coat required is cheaper than POR-15.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 09-29-2010, 05:25 AM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Looks great, Mike! I used Por-15 too. It has held up perfectly for a year now. It's true about the paint staying with you.....wear it proudly! It's your badge of honor for a week!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-29-2010, 05:34 AM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
It looks great Mike. That is one area you won't have to worry about rusting again!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 09-29-2010, 07:07 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Looks great. I have used POR-15 products but I now like the Rust Encapsulator line of paints and metal prep products from Eastwood Company a little better. They cater to the auto restoration crowd. Both are excellent products.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-20-2012, 04:42 PM   #6
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
TopCoat
Mike I just did the A-Frame on my "78" Ambassador. Two coats and it is hard as nails. I would like to finish it with one of Rustoleums metallic spray paints. What did you use for the topcoat and how did you prep the POR 15. Did you get their primer? Thanks!
PA TAC-5
WBCCI 4871
ID:	166266   Click image for larger version
Name:	Tongue 1st Coat.jpg
Roadrunner is offline   Reply With Quote
Old 08-21-2012, 09:04 AM   #7
1981 31' Excella II
New Market , Alabama
Good job on that A-Frame it looks good. You want to come do mine?
A little tip for using these moisture cured polyurathane paints. Divide the paint up into small portions using something like pickle jars. These will keep the moisture out of the spare paint. Make sure you don't get paint on the seal or the lids won't come off. You can open the jar once and pour some paint out and then put the lid back on. To get more paint use screw driver or old can opener and put some holes in the lid and pour the paint out that way and use something like duct tape to seal holes in the lid temporarily. I have kept paint for a few months like this.
Barts I am going to check into that Aluthane. I may use that as a top coat on my frame after the POR15 that is already on there.
Perry
Old 08-21-2012, 09:37 AM   #8
1981 31' Excella II
FYI guys you can get POR15 for $40/qt free shipping which is better than Aluthane if you fold in the shipping costs. I just bought 2 qts of the Aluthane since shipping was $20 for one or two cans. I like being able to use it as a top coat.
Perry
POR-15, and frame repair soldiermedic Repairing/Replacing Floor &/or Frame 29 04-19-2007 09:04 AM
70's AS asphalt-based frame paint prep for POR-15 Wabbiteer Repairing/Replacing Floor &/or Frame 1 10-09-2006 08:23 AM
Por-15 vs. Powdercoat on a new frame JimGolden Repairing/Replacing Floor &/or Frame 11 09-22-2006 08:03 AM
POR-15 products and frame prep 1959newbie Clearcoat, Exterior Paint & Trim 19 07-01-2006 08:37 PM
How much POR-15 for the Frame? JeepinAudiophile Repairing/Replacing Floor &/or Frame 12 07-31-2004 11:24 PM
