Old 02-08-2017, 09:25 AM   #533
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Your Tradewind looks great. I was curious if your flooring is holding up. I still have two places that won't lock. I love your interior setup.
cole3444 is offline   Reply With Quote
Old 02-10-2017, 06:45 PM   #534
millertimeUS's Avatar
1976 25' Tradewind
Thanks all! Floor is doing well, I think I have one area that unlocked that I need to address, but since the floor is light and the interlock tabs are gray it isn't easy to see
Matt
millertimeUS is offline   Reply With Quote
Old 02-10-2017, 07:07 PM   #535
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Your trailer is incredible. I don't know how you are going to leave it for a year or so.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-21-2017, 10:12 PM   #536
1976 25' Tradewind
Millertime's rear bathroom rot '76 Tradewind thread
Al and missy, thanks so much! I am already starting to get a little bummed knowing she will sit out in the desert for 2 years. I have started thinking about how to best prepare it for storage.... looking for input from anyone and everyone.
1). Fully winterize (blowout plus antifreeze)
2) reflectix in windows
3) disconnect batteries and hookup small 5-10 W solar tender.
4). Still not sure what to do about the tires, I read to put something under them (wood) so they aren't touching the ground. I thought about jacking up the trailer on stands but I worry about a big windstorm upsetting the stands or something. I will be eyes off for the whole time.
4). Also concerned about vermin, thought about those self sealing mousetraps, throwing in a fogger before I leave.... thoughts?
Oh and an UPDATE!
Had the same guy who made my metal wheel wells knock up a new fridge chimney using the cracked old one as a template. This one is much wider since my new fridge is quite a bit bigger. One day I will polish it (lol I say that phrase a lot)
Munch Munch Munch
Matt
Old 02-24-2017, 10:21 AM   #537
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi millertime: Your long term storage plan looks sound. Keeping critters out is helped by plugging any 3/8 diameter holes there might be in the trailer. I had mice enter from the rear bumper storage, propane line penetrations in the belly, gaps in the wheel wells, A frame square ends at the tongue jack, folding step slide "slots" in the step box, and I still get a mouse in there now and then.
I might submit if the trailer is subject to very high straight winds enough to blow it off jack stands, it would blow it over if it were on the tires. I place the jack stands just aft of the rear axle on the axle mounting plate. There is a whole lot of trailer weight on a very small piece of metal making the loads high. It seems very stable to me. And it is a good theft deterrent. Just a thought.
David
Old 03-01-2017, 10:20 AM   #538
1976 25' Tradewind
I agree David, most likely will put it up on stands and cover the tires to prevent UV damage.
The trailer still needs some sealing work just for water around the rear lights, etc and I too no doubt have some penetrations to fill in with foam.
I have been thinking about how to connect the solar charger while ensuring weather integrity. My best solution so far is to run the cable through the vent for the stove, which would leave a small gap which rain or critters may enter. The only way to avoid having some entryway open is to install a set of leads that come out the bottom of the trailer which means drilling through the floor and bellypan, installing grommets, etc. How would you do it? I did run solar wiring from near the fridge vent to the battery, could clip the solar tender to that, but it would be a decently long run and I am unsure of the voltage drop losses. Also would have to unscrew the fridge chimney I just installed to access the wires lol, figures.
Matt
Old 03-01-2017, 11:19 AM   #539
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Have you thought about removing the batteries entirely for a storage period that long? By the time you get back, they may be at or near the end of their useful life anyway
Old 03-01-2017, 11:34 AM   #540
1976 25' Tradewind
Perhaps, but given my situation that I will be unable to store them elsewhere and they are brand-new after the storage period They will only be three years old. You are correct though that it might just less hassle to remove them and purchase new batteries on the way to pick up the trailer upon our return.
The other option is to just disconnect them, ensure the fluid levels are full, and let them sit for two years. They will undoubtably be fully discharged but perhaps they will still perform well after recharging.
Matt
Old 03-01-2017, 12:23 PM   #541
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
My airstream had an antenna of some sort added to the roof with the cable through a 1/4" hole drilled through the skins and in to a cabinet.
I pulled it out and added a small grommet. I ran my solar wire through the hole and sealed it with OSI Quad. You can't see it from the ground and it hasn't leaked in 3 years, but it is part of my annual inspection.
Prior to mounting the panel on the roof I would put it on the propane tanks and run the wires in the space around the battery door.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 03-01-2017, 12:38 PM   #542
1976 25' Tradewind
Oh yeah there is a healthy gap in that door for venting and also a great call to mount on the tongue vice roof!
Matt
Old 03-01-2017, 06:57 PM   #543
Central , Mississippi
You could back feed thru the umbilical cord if you get a kit that has the solar control in the panel.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-01-2017, 08:38 PM   #544
1966 22' Safari
It's likely they'll sulfate
[QUOTE=millertimeUS;1917924]
The other option is to just disconnect them, ensure the fluid levels are full, and let them sit for two years. They will undoubtably be fully discharged but perhaps they will still perform well after recharging.[/QUOTE
I would not recommend that option. Batteries that sit around in a discharged condition form sulfates on the plates and are never any good once that happens.
Old 04-30-2017, 05:55 PM   #545
1977 31' Sovereign
Sunset Valley , Texas
Subscribbled...
Looking forward to what comes next for you. Your tenacity is inspirational.
Also, thank you for your service. I'll actually be on Oahu in a couple week so for work, Mostly north shore.
Thank you for taking the time to document your journey.
Ian
Iansk is offline   Reply With Quote
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 02:07 PM
Bathroom floor rot Treyladut Repairing/Replacing Floor &/or Frame 2 08-24-2011 09:09 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 03-01-2010 12:05 AM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 02:40 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 11:39 PM
