Old 10-06-2015, 10:05 PM   #449
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Making mine out if 20 gage steel. I took measurements off the old plastic ones. I followed the same pattern so the ends at curved. I cut them out with a cut off wheel then tack welded all the way down, I plan on using 4 inches of the old plastic ones to rivet the side where it attaches to the aluminum. I'll rivet the plastic to the steel wheel well also. No corrosion issues.
Matt
rugjenkins is offline   Reply With Quote
Old 10-21-2015, 08:24 PM   #450
millertimeUS's Avatar
1976 25' Tradewind
I called around and found several auto shops that might knock some together for me out of 16 guage steel.
Good thought on dissimilar metal corrosion, a plastic in between or a sacrificial piece of aluminum will be in order.
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 10-21-2015, 08:54 PM   #451
reinergirl's Avatar
Hollis , New Hampshire
I think your endcaps look fantastic! Sorry you'll be taking a break but you've had some amazing progress..... It's an elephant, one bite at a time
reinergirl is offline   Reply With Quote
Old 12-30-2015, 09:46 AM   #452
New and Eager
1972 27' Overlander
Loomis , California
Hey Matt I know you've seen my husband digidad's posts and vice versa...he made our wheel wells out of aluminum and they are super sweet. You might search his posts.
Note he had to make them AFTER I made an emergency road trip 700 miles to pick up plastic wheel wells...and came home with the wrong ones thanks to the parts dealer. Oh lucky us. Now have two giant unusable plastic wheel wells.
O Shiny is offline   Reply With Quote
Old 01-04-2016, 09:21 AM   #453
1976 25' Tradewind
Millertime's rear bathroom rot '76 Tradewind thread
Thanks reinergirl, they were a fun project!
OShiny, sent you a PM about the wheel wells.
All, 2016 is going to be a big year for the Airstream. Last fall I was taking several courses and unable to put in any time towards moving forward, but this year is going to be a big one!
First will be getting the wheels, tires, and wheel wells in order. THEN we will be dropping her off for a full shine job (minus the upper flat area, will be painting white later).
Already on order:
Sendel T03 16" rims
Michelin MS/2 225/65R-16 tires
2 x 30 LB worthington aluminum propane tanks with guages
Dill TPMS
Centramatic balancers
Once she is shined we start with a custom rear bunkhouse, then onto a custom bathroom.
Going to be a good year!
Matt
Old 01-04-2016, 07:21 PM   #454
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Sounds exciting. You're going to love your new wheel and tire package. I did the same thing on our 86 and love the look as well as the tire reliability.
Making the bathroom will be a big project!
David
Old 02-25-2016, 10:46 PM   #455
1976 25' Tradewind
Ok all a few big updates over the last few weeks. I apologize for not updating the forum better, I promise to do better
Name:	ImageUploadedByAirstream Forums1456464460.269252.jpg
The rear upper bunk and bed/sitting area are in! I will get some more photos later. The lower bed has lift up storage underneath, and I will be installing gas struts to make them easy to lift and stay up while we get things in and out of them. They still need finishing and paint and trim, but I am proud of them.
The upper bunk has no need of lower supports due to my riveting a mounting bracket to the rearmost vertical rib. I opted for 5/32 rivets vice 1/8 for a little extra strength. I then connected the 1" thick crossmember with lag bolts and nylocks. A small wood cleat on the inside edge supports the 1/2 ply bed and metal 90 brackets are staged around the rear circumference for support. It is very sturdy and given it is a smaller space shouldn't have any issues with being overtaxed with weight.
Name:	ImageUploadedByAirstream Forums1456464894.765982.jpg
I am really pleased thus far with the look.
Ok, next big job I completed was installing my new ALUMINUM wheel wells. I had a off-road fabrication shop make them up for me. They took forever to complete them (3 weeks!) but for only $300 I think I got a good deal. These babies are SOLID.
Name:	ImageUploadedByAirstream Forums1456465081.668369.jpg
I actually bought the plastic ones from inland RV, they were almost 2 inches too long. My old ones were cracked and my attempts at patching the ABS plastic quickly failed and during our cross country drive we had them leaking. Not any more! I cleaned the tracks and wire wheeled them prior to applying trempro and then some leftover Vulkem I had in my shop.
Lastly, sitting behind the Airstream are her new shoes. 4 x 16 inch Sendel Aluminum Bullets with Michelin MS/2 with internal tire pressure monitors. I also ordered the centramatic balancers. They seem a little like snake oil to me, but so many people swear by them I will press the 'I believe' button.
This weekend is planned for painting the rear bed and the putting up walls for the side/rear bath. I have decided to fabricate my own custom shower pan. I will post my efforts for your criticism lol.
munch munch munch!
Matt
Matt
Old 02-26-2016, 05:54 AM   #456
Mixter's Avatar
1976 27' Overlander
Nice stuff! Love the wheel wells. I just did my replacement OE plastic ones and lets just hope i never have a blow out- they will shred. And they are such a pain to install sealed up right.
Michelins are def now on my list for that reason.
Whered you order the wheels and tires from? You find good deal?
Mixter is offline   Reply With Quote
Old 02-26-2016, 03:49 PM   #457
1976 25' Tradewind
I bought the dill sensor package from
tire rack, the rims from trailerwheels.com, and the tires mounted and balanced at Costco. Costco had $70 off for Michelin tires so with the mounting and balancing it was a pretty good deal.
No colossally good deals but the best prices I found with companies I can trust.
Matt
Old 02-26-2016, 04:37 PM   #458
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
"The lower bed has lift up storage underneath, and I will be installing gas struts to make them easy to lift and stay up while we get things in and out of them."
I used gas struts on my under-seat storage lids. They're 1/2" plywood roughly 2' by 40"; I found a pair of 100 Newton rated struts worked just fine.
I've had good luck with this guy off Ebay; they're just about impossible to find retail.
Old 02-26-2016, 07:50 PM   #459
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Nice stuff Millertime. It take a long time to rebuild an old Airstream, but you are making good progress.
I am building a U shaped dinette in the son's 69 Globetrotter. It originally didn't have the best sleeping berths. But now he will have about 85 long by 60 wide sleeping space plus a dinette that seats 6 comfortably. My cabinetry isn't as good as yours, but they are benches mainly out of sight. The lids lift up for storage. I will use old fashioned prop rods to hold them up while loading stuff under there. Now my better half has to sew 9 big cushions for it. That will be time consuming.
I do little projects, you do BIG projects. You did get a good deal on those wheel well covers. I had fabricated one waste tank cover for my Trade Wind and the cost was about $425. It was about 60 long by 45 wide by 5" deep in aluminum. It's bolted to the bottom of my Trade Wind. I call it my roadkill racoon scraper. Keeps the highways clean.
David
Name:	1602 Table Up 2.jpg
Old 02-26-2016, 08:18 PM   #460
Mixter's Avatar
1976 27' Overlander
Hey- I like your 3 stage pedestal- I'm thinking same thing.
Can you rotate/ spin the table with that? I would imaging you'd have to loosen the clamp, but didnt know if it has anything that keeps it from spinning if you want. (I need to spin my design)
Old 02-26-2016, 09:57 PM   #461
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
Mixter, the stock table that they use in the 22 sport both slides about 8 inches to and fro, and spins. And will lock in "standard" position. Suggest you look to it for inspiration.
Did you know that you can download a full parts list for every AS make on their website? So you could get the stock parts if you can't find elsewhere.
To see the table in the 22 sport in action, look on the Colonial Airstream website. There is a video about 30 minutes long with Patrick going through the entire unit. He shows the table and how it spins and raises and lowers.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 02-27-2016, 06:37 AM   #462
Mixter's Avatar
1976 27' Overlander
Interesting. .. I did not know that was stock pedestal - thanks for the tip!
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 01:07 PM
Bathroom floor rot Treyladut Repairing/Replacing Floor &/or Frame 2 08-24-2011 08:09 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 01:40 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
