Old 08-15-2015, 01:06 AM   #435
millertimeUS's Avatar
1976 25' Tradewind
Millertime's rear bathroom rot '76 Tradewind thread
Been over a month since my last update, got a good one!
A big thanks to Zep and to Larry B for their posts on interior metal endcaps, really helped a lot.
First I needed to make a patch in the rear endcap for an unneeded plumbing vent, my new layout only needs one.
Name:	ImageUploadedByAirstream Forums1439618714.733457.jpg
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 08-15-2015, 01:14 AM   #436
1976 25' Tradewind
Next I cut the aluminum segments as outlined in Larry B's post "Aluminum Interior Endcap Segmented". I cut enough for both sides using a harbor freight electric metal shears, they worked great and cut nice straight lines.
Name:	ImageUploadedByAirstream Forums1439619056.504506.jpg
Next I took the panels in sets of 5, aligning the short and long edges on the side nearest the holes, and drilled holes .5 in from the edge 1.5 inches apart. This closely simulates the spacing on the exterior endcap. As you drill never skip putting in clecos!
Name:	ImageUploadedByAirstream Forums1439619222.417165.jpg
Matt
Old 08-15-2015, 01:19 AM   #437
1976 25' Tradewind
The endcap needs spacers to provide support for the dome as it takes shape. I could not find 1.75 inch foam so I bought 1 in and .75 in closed cell foam and glued them together in 3 in squares with contact cement. You will need about a half sheet of each for the front and back, quarter sheet for just one.
Name:	ImageUploadedByAirstream Forums1439619445.372833.jpg
Next I glued them to the endcap ceiling with spray contact cement at approx 7 in on center spacing.
Name:	ImageUploadedByAirstream Forums1439619512.515627.jpg
Matt
Old 08-15-2015, 01:25 AM   #438
1976 25' Tradewind
Finish the insulation with loose fiberglass I pulled off a roll.
Name:	ImageUploadedByAirstream Forums1439619588.655623.jpg
You start at an outer edge ensure you have about 1 in of overlap with the wall edge, align the short edge with the overhead panels and press it tight to the ceiling and drill a hole, cleco, drill, cleco, along the short edge.
The long edge works the same way.
Once it is secured, place your next panel, ensure your overlap is the same for all panels, cleco, drill, repeat. Make sure you press the panel right to the ceiling.
Name:	ImageUploadedByAirstream Forums1439619897.381518.jpg
Matt
Old 08-15-2015, 01:44 AM   #439
1976 25' Tradewind
Once you finish the 5th panel switch to the other side and repeat. Once you get to the center panel check your spacing, your left and right sides should be very close since you drilled them all together. Make any small adjustments on the 5th panel so that your center panel is dead center.
The center panel is riveted on both sides.
Ok here are some things I did different than others who have done this project.
1) I used 5/32 rivets, I just had way more black clecos. I had 100 and I still had to take a lot and move them forward.
2) Brace yourselves, I used 5/32 POP RIVETS. Yes I could have used Olympics, the expense and lack of a shaver dissuaded me. Yes I could have taken the whole thing down and bucked 350 or so rivets on each one. It was a lot of work just to get to this point and I am solo. So there you go, I used a HF pneumatic rivet gun and got those 350 rivets per endcap in quick and easy. The 5/32 pop rivets have a nice head size and actually look really good IMO.
Name:	ImageUploadedByAirstream Forums1439620475.975137.jpg
Rear, I trimmed it straight across and regretted it afterward though it looks fine. It caused a slight gap on the sides and I should have just left it and let it go under the screen frame like the front. Only trim where needed under the window frame trim to keep it out of view.
Name:	ImageUploadedByAirstream Forums1439620669.625926.jpg
Front endcap!
Name:	ImageUploadedByAirstream Forums1439620751.253808.jpg
Another photo before I put screen back in place.
This was a big project, albeit once I understood the process the front went much faster. Plan for 12-14 hours on your first one using this method if you are mildly handy. All you master aluminum artists out there be kind in your comments
Matt
Old 08-15-2015, 10:31 AM   #440
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Nice work
Old 08-15-2015, 11:03 AM   #441
Bend , Oregon
Matt,
Nice!!
Derf
derf is offline   Reply With Quote
Old 08-15-2015, 11:40 AM   #442
Mixter's Avatar
1976 27' Overlander
Nice job! Got any close up pics of the 5/32 pop rivets? Sounds way faster and cheaper.
Mixter is offline   Reply With Quote
Old 08-17-2015, 11:29 AM   #443
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Airstream attaches interior skins with 1/8 pop rivets. Your 5/32 pop rivets will have a good head size, similar to the exterior solid rivets. Olympic rivets are tri fold design for assembling softer materials. They are one of the weakest rivets on the market. Your end cap has a dense rivet spacing, it looks plenty strong. I support your decision to use pop rivets over Olympic.
Your aluminum end cap looks great. What a lot of work! Thanks for the Trade Wind update.
David
Old 08-17-2015, 09:56 PM   #444
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
That looks great. Thanks for the tutorial. I'm not putting the plastic end caps back in also.
Matt
rugjenkins is offline   Reply With Quote
Old 08-18-2015, 09:19 AM   #445
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
Nice Job! Its good to see you are still plugging away at it.... you are an inspiration to me. I hope to reunite my frame and shell in the next two weeks but have followed your progress over the last year.
Mark
newas4mark is offline   Reply With Quote
Old 09-21-2015, 11:09 PM   #446
Swahealy's Avatar
1972 31' Sovereign
Valparaiso , Indiana
Very impressed. What a huge undertaking. Keep up the great work.
Swahealy is offline   Reply With Quote
Old 09-23-2015, 10:14 PM   #447
1976 25' Tradewind
Thanks everybody! Mixter I will get you that photo. I am taking night classes Monday-Thursday this semester so the trailer is in hold till next year. In the meantime I am saving funds for a polish job and planning out the interior.
Cheers and munch on!
Matt
Old 10-06-2015, 10:53 PM   #448
1976 25' Tradewind
Hey all, took the family out to San Onofre Campground in Camp Pendelton. Aluminum tent camping at it's best right on the beach!
Question for the group, I want to remake my wheel wells out of metal, was recommended to use 16 gauge steel. Any idea how to construct them? Square is fine no need for fancy complex angles. Might just hire a metal shop to make them if need be.
Matt
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 02:07 PM
Bathroom floor rot Treyladut Repairing/Replacing Floor &/or Frame 2 08-24-2011 09:09 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 03-01-2010 12:05 AM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 02:40 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 11:39 PM
