Old 11-20-2014, 06:00 PM   #365
millertimeUS's Avatar
1976 25' Tradewind
Nice setup you did there David. I chose the Furrion 30A twist lock stainless inlet also. I got a good deal on a 50 ft silver colored Furrion cable, but just realized yesterday that the male end is also twist lock marine style 30A so I had to order a pigtail to convert to 30A RV style. Nice thing is the pigtail has build in reverse polarity and power LEDs.
I did 1- 20A circuit for the AC and 3 15 A circuits for converter, bath/kitchen, and exterior. Since I wired all in 12 gauge romex I might just switch the breaker to 20 if I add a microwave.
I replaced all my outlets with new tamper resistant ones and all the old 115V was replaced also. I put a gfci at the first outlet for the exterior and the kitchen/bath.
I have done some assistant electrician work under my dad who was a licensed electrician for a period. Only big difference from home wiring as I could see is that neutrals do not connect to the ground wires at the circuit breaker box, they stay separate. It all should work ok as long as I didn't reverse a hot/neutral somewhere
Going out tonight to continue cutting and installing the fiberglass and also scrubbing those nasty skins.
Matt
millertimeUS is offline   Reply With Quote
Old 11-20-2014, 06:40 PM   #366
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Oh wow, you're way ahead of me. You're right, the ground is separate from the neutral buss. Mine goes to the street side frame rail via a bolt through the C channel. The 12v ground is on the curb side frame rail.
I suppose twist to connect is appropriate for a side wall mounted connector. My 86 has a wire reel so the shore power cord is all flexible. The circuit checker in your pigtail is a good idea. I've not been bit by a bad campground power post yet, but my turn is coming.
David
Old 11-21-2014, 10:34 PM   #367
1976 25' Tradewind
Millertime's rear bathroom rot '76 Tradewind thread
AC system works 100 percent I checked every outlet and then labeled and made a diagram of the circuits for reference many years from now when I forget how this thing was put back together.
Got a few more skins clecoed in tonight, it takes longer than you would think when you have to drill out all the rivet pieces in the ribs, etc. On a side note I am appalled at how many times airstream completely MISSED the ribs or just caught 1/2 a rivet width of metal, rediculous! Means I will be drilling more holes to get it done right. The skins definitely aren't pretty right now, but perhaps with some if the recommended cleaners/an eventual paint job they will look better eventually. There are just SO many holes from where things used to be attached that there will be a lot of random rivets just to fill them all.
Feels really good getting a few of these in and beginning to imagine what it will be like some day.
Name:	ImageUploadedByAirstream Forums1416634402.088676.jpg
Big work day tomorrow sealing up the rear bumper area, attaching the exterior trim, reinstalling the water heater, and more skins and insulation.
Munch munch munch....
76 'Airstream Tradewind
Matt
Old 11-22-2014, 04:59 AM   #368
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My 66 Trade Wind has those vinyl clad interior skins in an off white. I was pleasantly surprised how well they have held up through the years. They were dirty when I got the trailer, but they cleaned up pretty good.
What covers the interior skins of the 76? I know you are planning to clean and paint them. I'm just wondering what was there originally.
David
Name:	1310 Galley.jpg
Old 11-22-2014, 05:53 AM   #369
1976 25' Tradewind
David, the walls on my 76' are also vinyl clad. Most have a pebbly sort of texture except for the smooth ones you can see in the photo that look a different color, those were around the shower area.
I would be fine not to paint I they clean up well, but I am expecting that to be on the list at some point.
Matt
Old 11-22-2014, 09:10 AM   #370
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would paint them when the skins are hung and the shell is empty while the painting is easy.
If I had done the work you are doing, there is no freaking way that the inside of my trailer wouldn't be the kind of bright, fresh, and clean that only fresh paint can offer.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-22-2014, 03:49 PM   #371
Mixter's Avatar
1976 27' Overlander
So paint after hung, or would painting before hanging the skins be even easier?? Or more difficult?
Mixter is offline   Reply With Quote
Old 11-22-2014, 05:07 PM   #372
1976 25' Tradewind
Given my experience so far getting all of them in.... Paint after they are hung. They scrape, bang, and drag. Not to mention hitting it with the riveter as the mandrel breaks off, sliding them under other skins, etc. as a bonus all of your rivet heads will match your chosen color when you paint after.
There will be taping, masking, and prep in that respect more work. In the final results column though painting post install definitely takes the win I would imagine.
Name:	ImageUploadedByAirstream Forums1416700699.266297.jpg
Sealed the lower wraps with trempro and started to get the lower trim installed. Starting to look more like her old self! I will keep the blue trim inserts out until after I finish stripping the clearcoat.
Name:	ImageUploadedByAirstream Forums1416700792.233591.jpg
My new metal 7 way just prior to sealing.
Name:	ImageUploadedByAirstream Forums1416700835.436875.jpg
The sealant on the holes really helps to protect against leaks around the fasteners, I used stainless machine screws with nuts and washers on the back.
Name:	ImageUploadedByAirstream Forums1416701007.825996.jpg
Highly recommend these syringes to apply sealant. I keep the big tubes in the freezer and just thaw and add to these plastic syringes which also make it easy to be more precise. Heck I freeze the syringes also for when you just need a little.
Matt
Old 11-22-2014, 10:25 PM   #373
1976 25' Tradewind
Name:	ImageUploadedByAirstream Forums1416720304.081390.jpg
Whew..... Slowly but surely!
Matt
Old 11-24-2014, 06:01 AM   #374
1981 31' Excella II
New Market , Alabama
Where did you get the syringes?
Perry
Old 11-24-2014, 10:56 AM   #375
1976 25' Tradewind
Perry I got them on amazon for a good price.
Name:	ImageUploadedByAirstream Forums1416851781.241305.jpg
Matt
Old 12-02-2014, 09:48 AM   #376
1976 25' Tradewind
Ok we are creeping up on the closing date for the house so free time is tight with move prep. Almost all skins are in minus the overhead and the end caps. Gone through about 400 rivets getting those skins in! Clecos are a must have and a helper for the long upper sections would have saved me some difficulty.
Took all the belly skin scrap and old lower wraps to the scrapyard along with the original copper plumbing and gas lines. Netted 94 bucks! Not bad for scrap.
Last night I got the Weight distribution gear installed on the tongue, she is ready to tow. Short trip to the scales planned soon.
Next project is an exterior custom deadbolt, will shoot plenty of pics for those interested.
Matt
Old 12-02-2014, 09:51 AM   #377
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Looking forward to your next batch of pictures. Most appreciated!
youngpeck is offline   Reply With Quote
Old 12-03-2014, 09:07 AM   #378
1976 25' Tradewind
Ok so got the deadbolt installed last night. Took about 1.5 hours, the main time consuming part was filing and getting the 3/8 stainless bolt to fit in the door smoothly. Oh for this project I used the custom deadbolt from VTS, it came with good instructions. It is a standard RV deadbolt which they have drilled and added a 3/8 stainless rod to extend the bolt, also reducing the size of the hole required in the door and jam.
Name:	ImageUploadedByAirstream Forums1417622067.267134.jpg
First drilled the 3/8 hole in the jam.
Name:	ImageUploadedByAirstream Forums1417622125.275556.jpg
After fitting in the bolt I marked the center location of the outer lock and drilled a 1 1/2" hole in the outer skin with a hole saw.
Name:	ImageUploadedByAirstream Forums1417622432.387552.jpg
Next you reinstall the inner skin temporarily with Clecos and use the outer hole to guide the inner hole.
Name:	ImageUploadedByAirstream Forums1417622454.373132.jpg
Reinsulate and set bolt and outer lock in place. Finally set inner lock in place and attach via 2 long screws. Careful you do not over tighten or the walls will deform and might throw the bolt out of alignment. I sealed with outer key lock with Trempro.
Name:	ImageUploadedByAirstream Forums1417622590.515009.jpg
I put a dab of sealant on the bolt and closed the door and rotated the bolt, on that mark I drilled a 3/8 hole. It took some reaming and checking as my hole ended up being about 1/16 of an inch high, but it ended up working out nicely.
Name:	ImageUploadedByAirstream Forums1417622740.675348.jpg
Final product, please forgive my half removed clearcoat . Doesn't look too pretty.
Happy with the install and glad to know my door won't go flying open, also I can save wear and tear on the KT lockset since I don't have to lock it anymore.
Matt
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 01:07 PM
Bathroom floor rot Treyladut Repairing/Replacing Floor &/or Frame 2 08-24-2011 08:09 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 01:40 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
