Old 09-15-2014, 10:40 AM   #281
newas4mark's Avatar
1968 30' Sovereign
Rockford , Michigan
I have been enjoying your thread since I bought my 68 Sovereign of the Road 7/4714 anticipating my own shell off. I have mine gutted but for the bathtub, toilet, and bathroom sink....please keep posting your progress. It is inspiring!
newas4mark is offline   Reply With Quote
Old 09-15-2014, 11:35 AM   #282
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Ive been watching since you started, its been really great to watch your tenacity. You are one heck of hard working and determined son of a gun. Getting that shell back on has to feel like youve reached a real milestone in the project. Im a retired carpenter and my favorite time in the sequence of building a home was when it was framed, sheathed, and the windows n doors installed so it was all closed in. You now have a "shelter" from the storm! Great work man! Just think how much youve learned in the process, great info and example you are passing on to your kiddos.
Time for you to kick it back, have a beer, and look at the great work youve done! (Not for long though, eh!)
mayco is offline   Reply With Quote
Old 09-15-2014, 06:43 PM   #283
Swahealy's Avatar
1972 31' Sovereign
Valparaiso , Indiana
Matt:
I always thought the belly pan side pieces had to go on first so when the shell was put back into position the shell went on the outside and over the belly pan so you had the outside overlapping the belly pan. Am I wrong? Mine is a '72 Sovereign so it may be different altogether.
Swahealy is offline   Reply With Quote
Old 09-16-2014, 06:15 PM   #284
millertimeUS's Avatar
1976 25' Tradewind
Originally Posted by Swahealy View Post
Matt:
No you are correct, I only connected my belly pan along the crossmembers for now. I will get the sides along the main rail where the side wraps attach underneath when I get to that step. Considering ordering some ALCLAD and remaking them since ther edges are pretty corroded.
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 09-18-2014, 05:22 PM   #285
1976 25' Tradewind
Millertime's rear bathroom rot '76 Tradewind thread
Replacing vent gaskets
Name:	ImageUploadedByAirstream Forums1411082161.108654.jpg
Not a complicated maintenance procedure but your vent gaskets need replacing every now and then. Here the vent is already removed and surface cleaned.
Name:	ImageUploadedByAirstream Forums1411082228.278927.jpg
In place, I zip tied a small section of screen to keep bugs out of the piping.
After that just screw it back in. I replaced the rusty zinc screws with stainless. Although it didn't seem necessary, it was sealed around the base when I pulled it off, I put a seam of trempro around the base of the vent. Be sure you don't accidentally seal the weep hole near the bottom, that is how all the water that gets in gets out
Also got the front curved section of the trailer bolted down to the frame, 1/4 inch hot dipped bolts every 5 inches.
Matt
Old 09-18-2014, 05:29 PM   #286
1976 25' Tradewind
Made some money today! A few days ago I poked my head in the trailer and to my dismay saw several puddles on my new floor. Not happening! My old vents were leaking since the lift and my plumbing vents, removed several weeks ago, were also seeping around the tape I covered the holes with.
Name:	ImageUploadedByAirstream Forums1411082695.827393.jpg
The original vent cover, 50 rivets on this baby! I recommend drilling out with an oversized bit to avoid having to pull out rivet pieces. The FV uses screws so those old rivet holes won't be reused.
Name:	ImageUploadedByAirstream Forums1411082836.118176.jpg
Once the old vent is out you have to clean up the old sealant and get any rivet pieces out of those old holes. Clean the surface with some denatured alcohol, etc. Don't forget to clean all the sealant inside the trailer also.
Name:	ImageUploadedByAirstream Forums1411082750.653990.jpg
My original vents had rounded corners unlike the square shape of the FV, this necessitated some cutting of the roof skin.
Name:	ImageUploadedByAirstream Forums1411082869.160717.jpg
Highly recommend these pneumatic nippers. Unlike hand shears it leaves a clean edge, cuts curves easily, and is super quick.
Name:	ImageUploadedByAirstream Forums1411082926.922019.jpg
Squarish hole
Name:	ImageUploadedByAirstream Forums1411082953.543358.jpg
I had to pre drill a few of the screws as the roof kept flexing away from the mounting flange. I laid a thick bead of Trempro then set the flange in place. It squeezed out nicely and then I used my finger to smooth the bead. Each screw got a bit of trempro also. After that I went inside and smoothed the inside bead. Tip, set something under you fan to catch all the metal shavings and drips of sealant that squeeze through those old rivet holes.
2 fantastic vents in place!
Matt
Old 09-18-2014, 07:11 PM   #287
1981 31' Excella II
New Market , Alabama
You are going to find that the metal vents you took off were better than the plastic stuff you put back. They will crack at some point.
It would be a good idea to seal those bathroom vent tubes from the inside as well. That black rubber will crack in a year or two and it will leak again soon. I put a bead of Trempro around the tube and left the gasket off and so far so good. Eventually, I will put a cap on the Square TeePee thing so water can't get in there.
Perry
Old 09-18-2014, 07:13 PM   #288
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I made an adapter plate that fit on the old vent flange to fit new style vents.
Old 09-18-2014, 08:09 PM   #289
1976 25' Tradewind
Interesting idea on the adapter, the old vent flange was smaller than the FV so not sure how that would work in this situation.
Great suggestion on sealing inside of the pipe also. I really like those stovepipe looking caps for vent pipes, I have seen some that are aluminum that looked great just not sure where they could be purchased. Another project for another day!
While the plastic flanges may crack someday I wanted the modern upgrade so I guess you take the good with the bad. For the cost you would think FV would use metal flanges.
Matt
Old 09-18-2014, 08:29 PM   #290
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I bought mine(aluminum " mushroom" type w/ no holes), from Mobile Home Depot . I think they are somewhere in Florida .
Cochese is offline   Reply With Quote
Old 09-18-2014, 09:56 PM   #291
pbearsailor's Avatar
Port Hadlock , Washington
Matt, I've got one of those aluminum mushroom type vents from that place in Florida that is left over from my project. Send me a PM if you want it and I'll send it to you.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-19-2014, 06:38 AM   #292
1981 31' Excella II
Look at Aerowood's thread on his rebuild. He built a custom flange for the Fanstatic vent. Maybe adding some angle around the perimeter under the skin would stiffen it up a little making cracking less of an issue. Also with nothing under the vent it will oil can if someone steps near it. This will most likely cause leaks or cracks in the vent housing.
Perry
Old 09-19-2014, 09:54 AM   #293
Mixter's Avatar
1976 27' Overlander
Check this out for the sewer vent caps- I might try these:
http://www.airforums.com/forums/f455...ons-82910.html
Looking good Millertime! I cannot believe how fast you're going.... Keep it up, you've just caught up with me, and I'm watching your next steps! I'm getting the itch to get going again now that we are heading for better temperatures.... I dont know how you've been going this hard in this heat and rain.
Mic.
PS- sorry to all that had to witness last nights display of my Buccaneers.....
Mixter is offline   Reply With Quote
Old 09-19-2014, 11:52 AM   #294
1981 31' Excella II
Mixter has the right idea. I am going to do something like that when I get time.
Perry
Mic.
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 01:07 PM
Bathroom floor rot Treyladut Repairing/Replacing Floor &/or Frame 2 08-24-2011 08:09 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 01:40 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
