Old 09-09-2014, 07:33 AM   #267
aquinob's Avatar
Portsmouth , Virginia
Looks great. One thought. If your water tank goes where mine went, you may not have enough room between it and the insulation. I ended up pulling one layer out and it was a very tight fit with the original 1" plywood panel going back in.
You will also need to cut an access opening for the plumbing and for the tank sensor wires. On mine, the hole was not over that section of the tank, so I connected the wires before I slid the lower plywood panel back in. If you dont want such a large hole, then you can probably run some leads off the tank sensors and then connect them up when the shell goes back on.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 09-09-2014, 03:12 PM   #268
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Most excellent! You are munching away. It's a big elephant.
David
Old 09-10-2014, 07:32 PM   #269
millertimeUS's Avatar
1976 25' Tradewind
Name:	ImageUploadedByAirstream Forums1410395389.477623.jpg
Gray and fresh tanks in! The new steel pan fit and looks great! Drilling into that 1/4 inch main rail tube is quite a task though. Highly recommend a corded 1/2 drill and lots of bits
Front belly pan in up to tank just too dark for photos. Need to finish up the belly pan tomorrow then it's time to flip her back over and get that C channel in place!
Matt
millertimeUS is offline   Reply With Quote
Old 09-11-2014, 07:25 PM   #270
1976 25' Tradewind
Whew these long days in the fl heat are taking a toll, I am beat!
Name:	ImageUploadedByAirstream Forums1410478326.719342.jpg
Bellyskin almost complete, my dad here cutting some angle iron.
Name:	ImageUploadedByAirstream Forums1410480689.073221.jpg
Coming back down!
Name:	ImageUploadedByAirstream Forums1410480722.259095.jpg
Installed all the straight sections of
C channel. Added in a few extra 1/4 in bolts in lieu of all the sheet metal screws that AS originally used. I went with 1/4-20 1.5 in hot dipped bolts with a flat washer on the bolt side and a lock washer on the nut side. Like original, I put the bolt going upwards with the threads and nut in the c channel.
Name:	ImageUploadedByAirstream Forums1410481059.191169.jpg
Wheel wells were pretty easy to reinstall. I laid down a nice bed of trempro and then set the wells in place. I used Treks self tapping hex head screws which worked great going through the channel underneath and into the wood.
Gantries are in place on the frame and we start early tomorrow to lift the shell and get her dropped in place. Prayers for a smooth and safe operation tomorrow requested! All the c channel went in and fit really nicely so by all accounts the new frame is a very accurate reproduction
76 'Airstream Tradewind
Matt
Old 09-11-2014, 07:47 PM   #271
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Looks great and yes I like the natural look of YOUR yard! Lol shell back on takes a lot of patients so take your time! You have done great so far I am still not sure about the particle board floor! Good luck.
Cliff
Yes I said that! Or did I?
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 09-12-2014, 06:14 PM   #272
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Millertime it's Millertime. You deserve a break. You have completed a lot so far. Keep us posted on the "wedding" of your new frame and subfloor to the old body. Hopefully it will come together with fewer cuss words than normal.
Then you can practice your buck riveting skills.
David
Old 09-13-2014, 12:59 PM   #273
1976 25' Tradewind
Millertime's rear bathroom rot '76 Tradewind thread
Frame and shell are reunited
Name:	ImageUploadedByAirstream Forums1410629956.410508.jpg
Back in place! It took some patience and a couple of fittings to find the tight spots.
Name:	ImageUploadedByAirstream Forums1410630038.224870.jpg
This little sliver of wood made the front skin really tight fit, which in turn pulled everything behind it forward enough that our original rivet holes wouldn't line up. Given the new frame and floor I did not have the original holes in the frame to align the c channels on the frame. Perhaps expecting my rivet holes to line up again is too optimistic. In any case once we got it in position we first secured the rear with 1/4 in galvanized bolts every 4 inches throughout the curved section and rear. Then with the help of a 3 in strap we pulled down the rear sides and riveted one small section behind the wheel well. The buck rivets went in nicely and I was able to use the original rivet holes. I had to move my c channel about 1/16 of an inch to get them to align perfectly.
Still need to get the front secured with bolts then complete the riveting. Seems like each section needs little adjustments. I suspect after I secure a few more sections that the shell will be much more resistant to manipulation and I will have to abandon using all the original rivet holes. Time will tell.
It's a great feeling to get the shell back on. The idea of working on the trailer and not emerging covered in grime is nice We purchased our 1976 Tradewind about 5 months ago, the first few weeks after we realized what we had gotten ourselves into was pretty stressful. Now that it is towable a lot of pressure is off and we can slow down, actually BUDGET for future improvements, and enjoy the process. The goal is still for a complete aluminum tent prior to January. That means all the electrical, insulation, interior skins, painting, lighting, vents, and exterior trim need to be complete. Plenty to accomplish by then.
Thanks to all for their support, encouragement, and know-how. Couldn't have done it without Airforums.
Matt
Old 09-13-2014, 01:13 PM   #274
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Well done!!! Way to set a goal and stay with it is spite of the Florida heat!
I am impressed.
Old 09-13-2014, 01:17 PM   #275
1981 31' Excella II
New Market , Alabama
Great job. I don't think I have seen a shell off go this fast especially since you had a complete new frame build.
Perry
Old 09-13-2014, 05:12 PM   #276
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yea! Clap, clap, clap! Very well done. You have earned a very nice Airstream merit badge. Not many of us have done what you have just done.
David
Old 09-13-2014, 05:37 PM   #277
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Congratulations!
Old 09-13-2014, 10:16 PM   #278
Trottinon
Cncampers's Avatar
1962 19' Globetrotter
Maplewood , Minnesota
I am looking forward to getting that completed on ours. Congratulations!
Nancy
Cncampers is offline   Reply With Quote
Old 09-13-2014, 11:37 PM   #279
pbearsailor's Avatar
Port Hadlock , Washington
Really impressive, Matt! Such a very long way you've come in a short time.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-15-2014, 10:38 AM   #280
Swahealy's Avatar
1972 31' Sovereign
Valparaiso , Indiana
You're my hero! Very nice work.
Swahealy is offline   Reply With Quote
Floor rot / rear '89 Excella cathy624 Repairing/Replacing Floor &/or Frame 21 08-21-2014 02:07 PM
Bathroom floor rot Treyladut Repairing/Replacing Floor &/or Frame 2 08-24-2011 09:09 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 03-01-2010 12:05 AM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 02:40 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 11:39 PM
