You should be fine with a 23, but you should also be aware that (if I understood you correctly) the tire you are considering is a passenger car tire that is also approved for light truck service. Presumably it is a P235/75-15 LTX MS/2, but not an LT235 tire, as the last time I looked Michelin did not make LT (Light Truck) tires in a 15" size. The point of all this is that these tires, when used in trailer service, should be de-rated to 90% of the published rating. Many on here run those tires, even on 25 and larger trailers and have reported good results. I chose not to use them on my 25 because the weight carrying capacity was not close to that provided by the tires specified for my trailer.
Al
