Old 07-24-2015, 08:34 PM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Michelin tires
I think I've spent hours reading about tires on the forums. I've come to the conclusion of getting Michelin LTX M/S 2 for my 1973 23 ft. safari. The dealer is recommending size 225/75 R15; but these tires come in a 235/75 R 15. Would this be a problem fitting for this AS? Also, the load rating is only XL - can't seem to find it in a C or D rating, but I think this should be more than adequate for my trailer - am I thinking correctly?
Greg1410 is offline   Reply With Quote
Old 07-25-2015, 10:31 AM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
You are thinking just fine. I run Michelin's on both of our trailers and just finished 4000 miles to NM and back with the 235/75/R15 tires. I'm very happy with them.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 07-25-2015, 10:40 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You should be fine with a 23, but you should also be aware that (if I understood you correctly) the tire you are considering is a passenger car tire that is also approved for light truck service. Presumably it is a P235/75-15 LTX MS/2, but not an LT235 tire, as the last time I looked Michelin did not make LT (Light Truck) tires in a 15" size. The point of all this is that these tires, when used in trailer service, should be de-rated to 90% of the published rating. Many on here run those tires, even on 25 and larger trailers and have reported good results. I chose not to use them on my 25 because the weight carrying capacity was not close to that provided by the tires specified for my trailer.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-25-2015, 10:45 AM   #4
JimGolden's Avatar
1977 31' Excella 500
I also run 235/75-15's on my trailer...all six of them (seven if you count the spare). I thought the 225's looked too short in height....
Disclaimer: I run an Avion and don't know if the fenderwells are roomier than on an Airstream. The 235's clear on my rig and have never rubbed in over 20,000 miles towing over all kinds of surfaces. But I can't speak that they will clear on all Airstreams.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Eddie Bauer AS uses Michelin Tires? Secguru Tires 67 05-29-2014 12:33 AM
Tires: other than Michelin & Goodyear, what do you think? RAG General Motorhome Topics 25 03-05-2013 02:18 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
