Old 08-30-2011, 12:01 PM   #1
1970 23' Safari
1973 25' Tradewind
raynham , Massachusetts
Metal floor options
Not there yet in this phase of the rehab (slow gut job) but I'm envisioning options and would like to have a metal floor, something very utilitarian in the event this unit is used for some kind of food service (right now slated for a mobile art gallery/studio). What would you recommend? Thanks!
deelind is offline   Reply With Quote
Old 08-30-2011, 01:19 PM   #2
cameront120's Avatar
1972 25' Tradewind
Metal on top of the wood sub floor, or in place of it?
North Vancouver, BC
Old 08-31-2011, 07:14 AM   #3
1970 23' Safari
1973 25' Tradewind
def over
wood.
Old 08-31-2011, 07:41 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Metal gets hyper-slick if oil, grease, soap gets on it - an emergency response vehicle I once worked out of had diamond plate and naturally hydraulic fluid from the equipment it carried put a film all over it; to unload was like working on black ice.
So its true any flooring would be slick but metal especially so. And if you use aluminum diamond plate its too soft and wears out fast if occupied 8-12 hours a day plus nearly impossible to clean thoroughly as a food prep area requires, and steel too heavy with same cleaning problems.
Remember also the floor must act as a shower pan, the baseboard molding extends up so mopping water and cleansers go where they should - and perhaps a floor drain for a sanitary hose down?
Old 08-31-2011, 09:41 AM   #5
1972 25' Tradewind
Unless you're using aluminum, metal flooring would also add a lot of weight. I think you'd be better off with a resilient flooring suitable for commercial kitchens.
North Vancouver, BC
Old 09-01-2011, 12:22 PM   #6
1970 23' Safari
1973 25' Tradewind
great suggestions!
Hadn't occurred to me about installing a drain, perfect. Thanks for your input on the floor options, I'll have a look.
Old 09-01-2011, 01:29 PM   #7
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
How about something like this?
http://www.truckline-sale.com/images/img_0029.jpg
Replace the wood and foam underneath for insulation.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 09-01-2011, 02:44 PM   #8
1973 25' Tradewind
Augusta , Georgia
I like how you are thinking. Wonder if you would need a thin 1/8" plywood for subfloor for vinyl and or laminate floor to lay on. Need to think about weight versus standard 3/4" plywood. I'm thinking this will be lighter per square foot.
DGJackson is offline   Reply With Quote
Old 09-01-2011, 04:14 PM   #9
Wabbiteer's Avatar
1972 29' Ambassador
they have a smooth surface type that would do famously with a layer of kitchen composite on top of it... I think no backing wood would be required...
Old 09-01-2011, 07:01 PM   #10
65CV's Avatar
Western , Massachusetts
Think like a boater...
Why not think like a boat if you are exposing it to moisture?
Combine the drain idea with a coating of marine epoxy, impregnated with non-skid.
See if you can find a good marine supplier near the coast or an experienced person at West Marine.
You can find some great stuff here:
http://www.jamestowndistributors.com
Once you have your game plan, you may want to shop around -- they are top dollar.
65CV is offline   Reply With Quote
Metal Interior Beach Boy Airstream Trailer Forums 20 08-21-2011 06:03 PM
Fine metal shavings appear while travelling bspelce 2006 - 2010 International 11 08-12-2011 07:07 AM
Summer Fest 11 Metal Festival SilverDragon Other Rallies & Events 0 05-13-2011 10:21 AM
What is the metal sub-floor made of? Keyair Classic Motorhomes 25 05-12-2011 03:41 AM
'73 sovereign floor metal Flaboy67 Repairing/Replacing Floor &/or Frame 2 01-30-2011 06:51 AM
