Old 07-17-2010, 09:00 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
measuring floor
Floor gone soI have no template for rear floor.I am in the process of cutting a piece of thin luan for a rear floor pattern for tank hole etc..
I have measured 87 1/2x 48in. across the frame.How do I take the measurement for the curves on both sides?
bwaysteve is offline   Reply With Quote
Old 07-17-2010, 10:02 AM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
i would take a piece of big brown paper, lay it out and use your fingers to push the paper into the curve of the trailer and then trace the 'dent' in the paper. trim the paper,go back and fill in w/ more paper or trim where it needs to be trimmed and then lay it out on the luan.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 07-17-2010, 11:36 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Using the paper pattern technique above, get is close to the right fit. Then place it in the trailer and scoot it as close to the back as possible. Then take a compass (for drawing circles, point on one end and pencil on the other) and hold it with the point against the rear wall keeping it (the compass) parallel to the length of the trailer. Follow the rear will with the point and the pencil will make an exact copy of the wall offset onto your luan. You can then trim this to a perfect fit. It's the same technique used for fitting counter tops to walls in homes.
Using the luan for pattern making is a good idea, too.
Vaughan
Old 07-17-2010, 12:56 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Great
Great,Now if I can find all my school supplies from 3rd grade for a compass.I did the paper and got almost perfect.Now is the curve in front same as the back?The luan is great as it just slides in.I can then mark all my holes for BT and transfer to 3/4.Thanks
Old 07-17-2010, 01:07 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We found all four "corners" of ours to be different~
Shari
Old 07-17-2010, 01:16 PM   #6
Shari
Absolutely, they are not identical.
Measuring forces at the hitch boondockdad Hitches, Couplers & Balls 55 05-08-2015 11:33 AM
Stress Measuring rangebowdrie Tow Vehicles 1 08-14-2009 04:48 AM
Measuring Sofa dannyo General Interior Topics 0 03-28-2008 08:27 AM
Measuring inverter output guy99 Electrical - Systems, Generators, Batteries & Solar 8 01-04-2007 07:24 PM
measuring propane pressure emanon25 LP Gas, Piping, Tanks & Regulators 2 09-27-2004 05:48 PM
