Old 07-12-2012, 10:09 AM   #15
pbearsailor's Avatar
Port Hadlock , Washington
Originally Posted by aluminitus View Post
pbearsailor - ooo yea I know all about c-channels and shell support. This is a shell off, so access for the moment is not a problem. Fortunately the belly pan was not bent over the channel, but it sure was a pain to pull out. Glad I only have to do this once!
Sorry I just assumed you were shell on. Shell off is way easier and definitely do the belly pan before you drop the shell back on.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 07-12-2012, 02:51 PM   #16
Baltimore , Maryland
what Steve said..
Old 07-17-2012, 04:36 PM   #17
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Originally Posted by ddstech View Post
I used .025 aluminum. I want to say it was 35 dollars for a 4x8 sheet. I used six sheets because I had to put a 12 strip down the middle on both sections. Maybe I used 8 sheets to cover my 22' trailer.
WOW that was a great price....did you order online or from a local shop?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 07-17-2012, 10:10 PM   #18
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I got it from a local shop. I'm probably way off on that price.
ddstech is offline   Reply With Quote
Old 07-17-2012, 10:24 PM   #19
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Nope, thats about right for a couple years back.
I nabbed 60" x 120" sheets of .032 for $39 each almost four years ago. The same place is NOW advertising specials:
.040 Painted White Aluminum Sheets 48 x 120 $69.00;
.040 Painted White Aluminum Sheets 49 x 120 $74.00
.050 Painted Black Aluminum Sheets 49 x 120 $84.00
OUCH.
Old 07-18-2012, 06:12 AM   #20
1973 31' Sovereign
2007 20' Safari SE
OUCH.
still good prices considering that the sheets are 12ft long.
So far the best I found is $85 per sheet on 4x8 and .032 and w/o shipping
2 chronicles 7:14
Old 07-20-2012, 06:15 PM   #21
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
So I picked up 9 sheets of 4x8 .030 aluminum sheet today from a local place at $37 each. It is mill finish on one side and white powder coated on the other. The white side will go against the steel frame as an added layer of protection against corrosion. Oh...and they even fixed the kinks in my over-the-door eyebrow for free and they tried out a product called Sprayon Heavy Duty Citrus Degreaser on the underside of the drip cap where there was some nasty corrosion kind of stuff going on that wouldn't come off with Nuvite. The Sprayon took it right off, saving me the trouble of making a new one!
aluminitus is offline   Reply With Quote
Old 07-22-2012, 04:52 PM   #22
1972 25' Tradewind
McKinleyville , California
Just to confirm, the wrapped sides on a '72 vintage uses 0.032in 5052 aluminum?
tesstoaster is offline   Reply With Quote
Old 07-22-2012, 06:41 PM   #23
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There seems to be plenty of debate about what is right and/of necessary. I just redid my 21" '73 with .032 6061. The materials cost about $400 from Aircraft Spruce, I think including shipping. That was two 12x4 sheets and one 4x6 sheet. My replacement was thicker than the original, which was probably around .025.
Old 07-22-2012, 08:32 PM   #24
1972 25' Tradewind
Yes, but is that the belly only or does that also include the side wraps? I think the factory used 0.032.
Old 07-23-2012, 07:29 AM   #25
Belegedhel's Avatar
Houston , Texas
I did the belly, wraps, etc. all in the .032
Name:	DSC_0662 small.jpg
Old 07-23-2012, 01:40 PM   #26
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Belegedhel- Beautiful! So nice to see the whole thing together!
Old 07-24-2012, 07:38 AM   #27
Belegedhel's Avatar
Houston , Texas
I just reviewed the original post, and the concerns about making the curved sections. I found with the .032' 6061, that it did not take a bend very easily. I tried some test pieces, bending it over the edge of my bench, over some 4" PVC pipe, but either I would end up with a hard crease, or it wouldn't take the shape. Luckily (or unluckily), I had bought an English Wheel as one of those "its on sale, how can I pass up a deal this good?" kind of events. The Wheel did the trick, though I am sure most people don't go to this kind of length.
Old 07-27-2012, 02:12 PM   #28
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Belegedhel - The cat is out of the bag now! Tell the Airstream community that you have your own English wheel and suddenly you will find yourself with lots of friends who just happen to need some compound curves
We were able to get the back piece on and one of the curved side pieces this morning. The side piece looked great until we got to that back corner. It looks like something from Monty Python.
Or pretty much exactly like what CV65 warned me about. I stood back and had a good hearty laugh at my own expense.
I guess tomorrow is another day. It the mean time, other than making tiny cuts, any advice on the matter?
