Old 09-27-2006, 01:02 PM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
Major frame rust?
Ok, now I know that it is only really possible to assess frame rust after taking the belly pan off. However, since this is something that we were just looking at to possibly buy that's not possible.
So, for the benefit of my education if nothing else: here is the situation. Inside the exterior compartment near/under the side bed unit it was wet. Wood floor saturated, but only about 3/4 of the way to the back of the compartment. After diligent search inside I determined that the wall area below the window and above that bed seemed to feel a touch damp. Inside the closet between the bed and the rear bath were two very small puddles of water. Now the big part; underneath this area a small section of the visible frame and a pipe were very rusted. (See pictures)
Would you assume then that this rust came from leaking above? Is that in a position to do major rust damage to the rest of the frame?
wannaroam is offline   Reply With Quote
Old 09-27-2006, 01:56 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
It could be bigger than it looks when you get it apart but based on what I see my guess is 4-500$ repair assuming you clear everything out of the way for the welder
'77 Sovereign Intl 31' CB
Old 09-27-2006, 04:01 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I'm having a hard time visualizing what that white box is that's hanging down between the frame rails. What year is this?
I'd recommend that you at least take down the banana skin in that area so you can look at the upper part of the frame. You may also have to take down the belly pan, hence the question posed above. It doesn't look like you have a belly pan.
Zep
Old 09-28-2006, 12:36 PM   #4
Not so. You can use a fiberscope through small holes drilled in the belly pan. I describe this at
http://www.airforums.com/forum...iberscope+nick
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-02-2006, 01:15 PM   #5
wannaroam's Avatar
Images: 36
white thing
The white thing hanging is the pipe that connects to the campground sewer as this has been sitting in a campground for many years.
Yes, there is a belly pan. Many this shot will help more.
Old 10-03-2006, 02:36 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If it were me, I would run away as fast as I could.
There is floor repair, in addition to possible frame repair. I would be more concerned with the floor and walls and other things if wetness was seen and felt on the inside of the trailer. The water is coming from somewhere. That means pipes or seem leaks too.
>>>>>>>>>>>>>>>Action
Old 10-04-2006, 07:28 AM   #7
wannaroam's Avatar
Images: 36
Action -
Thank you, that was my thought too. Guess we'll keep looking,.......
Bottom Rust niftypkg Repairing/Replacing Floor &/or Frame 0 04-14-2004 04:45 PM
Frame rust Ken J Repairing/Replacing Floor &/or Frame 5 07-13-2003 06:39 AM
Rust removal on chains, etc. Sav'h Steve Cleaning, Stripping & Polishing 4 03-06-2003 07:06 AM
axle rust femuse Axles 0 02-28-2003 02:18 PM
Rust on Frig. niftypkg Refrigerators 0 05-20-2002 06:43 PM
