08-10-2009, 07:11 PM
moderator
Brandon
, Mississippi
Lots of rotten floor
Well, we knew when we got the 34' that it had floor issues in the front, BUT it is SLIGHTLY worse than I thought  . I had hoped for a 2' x 3' section but there is enough damage to justify a full 6' section, side to side.
Tomorrow I'll finish the stripping of the interior from the door forward and start pulling the lower panels. I can't see where the curb side lower panel has a joint so I suspect I'll just roll it back toward the dinete.
The good part is it's only 1/5 of the floor that has issues, if this was a 16' trailer it would be almost 1/2 of the floor!
08-11-2009, 11:19 AM
moderator
Brandon
, Mississippi
Removal complete
This morning I removed everything that was bolted or rivited in the way of the floor removal. It looks like a 4' long section will get me back to good solid wood. I am amazed at the lack of bolts or screws that hold the front together. 10 bolts and 2 wood screws are all that goes thru the wall/floor joint in the first 4 - 5 feet of the trailer. I think I can access everything needed from below by removing the banana wraps and peeling down the belly skin.
Now for the bad part, working outside of the airconditioned interior!
08-11-2009, 12:13 PM
1967 24' Tradewind
Estancia
, New Mexico
A 91, to me, would be just broken in. What caused all this rot in the first place? I assume part of the answer is particle board vs. real plywood.
Turn left right here
08-11-2009, 12:24 PM
aluminauti
Where we
, Park it!
Agreed, as particle board more prone to moisture damage - need to determine where the water was coming in that created this mess and repair.
What motivated Airstream to use OSB for the flooring on certain models? We have a '96 34' Ltd and it definitely has 5/8" tongue & groove marine plywood throughout the floor - we know, as we ripped out all the old carpeting recently!
08-11-2009, 01:28 PM
1967 24' Tradewind
Estancia
, New Mexico
$$$$$$$$$$$$. My $.02 worth
08-11-2009, 03:22 PM
moderator
Brandon
, Mississippi
Yup, OSB flooring in one huge piece as best I can tell. Once I pull the carpet I'll be able to see exactly how big the pieces are. Here's the bummer - 19/32 thick and milled down at the edges to 1/2 inch. Geeze that ain't much meat!
I got the curbside portion pulled today, the few bolts that were there are cut and removed, except the one big one that goes into the front of the frame.
Now I need to find a source for 19/32 or 1/2 Marine ply in my area, get some POR and start the reassembly.
08-11-2009, 03:25 PM
moderator
Brandon
, Mississippi
Owning a '77 that we use on a regular basis, it seems odd to me also that the '91 is in worse shape. The damage was caused my leaks, no doubt. With all the rain clouds and thunder outside, I may get to look for the leak in a moment!
08-11-2009, 03:38 PM
Out in left field......
Possum Holler
, Georgia
Gees, what a mess. Looks like my '73. Your frame looks to be in good shape, is that just surface rust? I didn't use marine grade ply on the new floor. I used regular ply, epoxied the edges in about 6 to 8 inches, then varathaned the rest (top & bottom). Do you have a way to mill down the 3/4 to fit the 1/2 channel? I'll be following along to see how you do it.
I love the smell of campfire in the morning
www.nesa.org
Air No. 6427
08-11-2009, 05:03 PM
1967 24' Tradewind
Estancia
, New Mexico
I wonder if there is anything you use as a proflactor, so to speak, to keep the rest of the stuff from going south or at least prolonging the inevitable. Penetrating epoxy resin?
08-11-2009, 05:30 PM
moderator
2001 30' Classic S/O
Novato
Isnt this floor rot thing so discouraging? I used to think about airstream as the all aluminum trailer that cant rust and if it leaks so what.. Its all aluminum. Obviously I was very new to the game. This actually seems to be the achilles heal of the airstream? Glad you have a plan and found the leaks. Its going to look great when its finished.
Vin
Air-safe / Reese dual cam
2011 Dodge 3500 Diesel
6 speed manual 4x4
08-12-2009, 06:46 PM
moderator
Brandon
, Mississippi
Stinky no more
I ran by the Big Orange Box on the way home, no 19/32 external grade ply but I did pick up a sheet of luan for a pattern and an assortment of pvc fittings...see if you can guess what this is  ?
Hint - the previous owner left me a little present that I really wanted to get rid of  .
08-12-2009, 06:48 PM
moderator
Brandon
, Mississippi
Pic.
08-13-2009, 10:20 AM
1972 29' Ambassador
St. Paul
Deeded you some Black Hills properties did he?
08-13-2009, 11:22 AM
1967 26' Overlander
Upperco
, Maryland
Plywood, OSB or chip board... you get it wet often enough and it will eventually rot. In my completely unqualified personal opinion, the key is keeping the floor dry. That's we won't do anything carpet in our finished Overlander. We'll do a floating wood floor or a composite material. My goal is to keep water away from the subfloor and I've always felt carpets and pads "held" moisture. As for the idea of sealing the plywood, I concur. We'll probably do a couple of coats of spar varnish before we lay the flooring.
| Thread Tools |
| Display Modes |
