Old 08-22-2009, 11:23 AM   #41
Central , Mississippi
oops
Photos are nice
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 08-22-2009, 06:41 PM   #42
It's in. The two toughest items - squishing the new insulation down as I worked the panels into the c-slots and finding some place to tap since one of the edges was tapered. I screwed a couple of small pieces of ply onto the panels so I could tap. I also used a porta power to push gently. The beveled joint worked pretty good so far.
Now I have to pull the plastic banana wraps and thru bolt in 6-8 places.
Old 08-22-2009, 08:09 PM   #43
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Great work, bet it smells a lot better in there too!! Very smart idea on the joint, lots of surface area for glue.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 08-23-2009, 04:39 AM   #44
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
That is the neatest "patching-in" job I've seen on any of these threads. You've taken "measure twice, cut once" to a new level. Even though your craftsmenship will eventually be covered by flooring material, you'll know its there.
dieseleagle is offline   Reply With Quote
Old 08-23-2009, 05:19 PM   #45
Todays results
This morning started with a trip to the Home Depot, lightening the ole checking account by $250...
I then dropped the Banana wraps and got the misses to help bolt the outrigger/c channels/frame together. 50 rivits later that part was done, the banana wraps are back and the front is close to complete. I still plan on adding a brace to help with Front End Separation that these model trailers are prone to exhibiting.
I went ahead and removed the floor cabinets and the dinet.
ID:	85954   Click image for larger version
Old 08-23-2009, 05:22 PM   #46
Flooring
Installation of the flooring went fast since I decided to go width wise. We made it all the way to the rear of the kitchen with 4 boxes of flooring.
Then its a matter of reinstalling the cabinet and dinet. When I get the frame separation bracket installed I can put back in the front walls and the sofa.
ID:	85957   Click image for larger version
Old 08-23-2009, 05:37 PM   #47
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Beautiful work!!! I can't help but think that OSB "plywood" is a liability for the newer Airstreams.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-23-2009, 07:58 PM   #48
other bolts
Here's some other things that got bolted together this week...Our son kinda busted his knee..
Old 08-24-2009, 05:26 AM   #49
87MH's Avatar
1978 31' Sovereign
Images: 292
That hurts just looking at it - at least he will get "priority" treatment when going through airports for a few months.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-24-2009, 05:54 AM   #50
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
We have the technology. We can rebuild him. Bigger, stronger faster.
Hope he's doing well. There's no two ways about it. Surgery hurts.
Old 08-24-2009, 07:15 PM   #51
Credit is Due
The misses put me on notice today. A new entry is to be added for her efforts. She feels I am getting all the glory for the refurbishing of 'no name'.
She started her day by steam cleaning the smelly, stained sofa. Then tackled the tedious task of removing the broken tabs from the freshly laundried curtains and sewing on the new tabs, all the while silently cursing the sewing machine I so lovingly bought for her years ago. (I think she has used it twice-finally getting my moneys worth) I must say cleaning the curtains and the sofa has dramatically improved their appearance as well as the funky smell that loomed in the air in the camper.
I see a dinner and a movie in her future once we get our new room mate (our 23 year old son) back on his feet from the broken knee .
ID:	86040   Click image for larger version
Old 08-25-2009, 07:06 PM   #52
The front 1/2 of the floor is now solid and covered. I figure that's about the same as a Bambi or Flying Cloud...
Now for the back 1/2...
I knew I had issues around the toilet and it was either a leak in the toilet or the vent - either way the floor is bad, the toilet is getting replaced and the vents will get new seals. The good news...no c-Channels to deal with
Old 08-26-2009, 06:51 PM   #53
Body Separation
"While I'm Here"...
I'm adding a panel to prevent body separation. A few of the forum members have had issues with newer well-traveled units and the front body panels splitting. This isn't an issue on the older trailers since there was a metal verticle panel on the frame that was rivited to body.
This insert is riveted to the outer skin and bolted to the frame.
ID:	86153   Click image for larger version
ID:	86155   Click image for larger version
Old 08-26-2009, 06:53 PM   #54
One really important addition...AIR Forums decal!
Old 08-26-2009, 07:30 PM   #55
87MH's Avatar
1978 31' Sovereign
Images: 292
Man....I can't believe how much some of ya'll get done every day...
Looks great -
What thickness of metal did you use for the front clip, and did you bend it on a brake?
Seems like good piece of preventative maintenance.
Dennis
WBCCI # 1113
AirForums #1737
Old 08-26-2009, 08:25 PM   #56
Originally Posted by 87MH View Post
Man....I can't believe how much some of ya'll get done every day.....What thickness of metal did you use for the front clip, and did you bend it on a brake?...
.120 thick and that's about as thick as the little hand brake at work can handle.
I thought I would have access to a rivet gun but it fell thru so I ended up using 3/16 pop rivits . Now I have to seal them.
I did leave enough room for another row of real rivits if these show any signs of failing.
Old 08-27-2009, 07:22 AM   #57
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Looking good, it's a shame that your deal on the solid rivets fell apart. Why don't you just swing by my place and we can shoot a couple rows of 3/16's solids in it, it will only take a few minutes.
Kip
Old 08-27-2009, 08:16 AM   #58
Originally Posted by Aerowood View Post
... Why don't you just swing by my place and we can shoot a couple rows of 3/16's solids in it, it will only take a few minutes.
Kip
Humm...as tempting as that offer is...
"Hello Honey?"
"I'm gonna run over to Kips, see ya in a week..."
Old 08-27-2009, 08:43 PM   #59
Whew
Tonights progress. Tightened up the bolts for the front separation plate, added insulation, riveted in the front panels (that was no fun!), installed the curtain tracks, hooked up the charging system and placed the sofa. The sofa arm rests are garbage so they will take some fab work - I'm gonna try someting different and see how it goes.
Now to the bathroom
Old 08-27-2009, 09:22 PM   #60
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
Hi Ho,
Excellent work and I know not only you but all those who have had opportunity to read and especially see the work you have done have also learned a lot. Good luck on the bathroom and then sit back and have a well earned libation! Oh, cannot forget your wife - one for her too.
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
floor repair, osb
What to do about my rotten floor??? utahredrock Repairing/Replacing Floor &/or Frame 15 11-03-2011 12:38 PM
Leaks and Rotten Floor pnb77 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 25 04-11-2008 07:17 AM
rotten floor by door colin57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-05-2008 09:17 AM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 12:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 08:03 PM
