Old 06-13-2013, 01:27 PM   #1
blickcd's Avatar
Milford , Ohio
Looking for outrigger replacement pics
I probably won't start on this until the weather gets cooler, but I plan to pull some banana wrap and check my outriggers under the fridge area.
Since I am just doing research at this point I'd like to see some photos of outrigger replacement, just in case I have to go there. I'd prefer to see a job done on a late 70's model, which has the shell and flooring still in place.
Seems to me I've heard of bolt-on replacement outriggers but lately all I've been able to find available are ones that you weld on. Bolts would work better for me since I don't weld, though I am willing to learn. Any comments on weld vs bolts are welcome.
Thanks.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 06-20-2013, 02:22 PM   #2
salzburg , salzburg
I geuss bolt-ons are o.k if it's not too many, but on the other side of that is you will be wekening your frame by drilling through it, personally i'd try and find a friend with a welder. sorry i have no pics as i made a complete new frame with my own styled outriggers!
mrgreen is offline   Reply With Quote
Old 06-21-2013, 09:41 AM   #3
blickcd's Avatar
Milford , Ohio
At long last, a reply. I had thought that welding was the way to go. Might be a good excuse to take an evening welding class at the local vocational school.
If anyone has some photos, I'd still like to see them.
Christopher
Old 06-22-2013, 07:37 AM   #4
salzburg , salzburg
Welding is not that hard, I learnt the basics in 15mins which is all you would need to replace the outriggers, the biggest problem you would have is a mig welder is quite expensive hust to do this one small job, practice and setup is what it's all about.
Old 06-23-2013, 10:01 AM   #5
1999 25' Safari
Somewhere , Ohio
Hi blickcd!
If you go to our thread "1956 Bubble Restoration -- Bubble Trouble", I believe you will see our new frame with the new outriggers my DH and our friend made. Although, your 31' will more than likely have different lengths of outriggers than our small Bubble, but at least you can get an idea.
Best of luck in your upcoming work.
Deb
Air Cruiser is offline   Reply With Quote
Old 06-30-2013, 07:28 PM   #6
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
I just replaced outriggers on my '78 31' Sovereign. The shell was on, but the floor was out and the bellypan is down, so I don't know if my photos are what you are looking for.
GAStreamin is offline   Reply With Quote
Old 06-30-2013, 08:04 PM   #7
1971 31' Sovereign
fort myers , Florida
I welded 6 new outriggers today...out of angle iron and plate steel. Came to around $5 each....better than the $27 they get at outdoor mart.
swampthang7 is offline   Reply With Quote
Old 06-30-2013, 08:22 PM   #8
GAStreamin's Avatar
Moultrie , Georgia
Can you show a pic of what you did?
Old 07-01-2013, 05:44 AM   #9
1971 31' Sovereign
I will have to make up a new one,as the trailer is out at the storage unit. I'll try later today...if it stops raining.
Old 07-01-2013, 06:57 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you make up an outrigger that works it is easy to make a jig for each one you make afterward. Make it out of wood will be easy. Yet you will need to remove wood where you weld or you will have a campfire and we know those are anathema
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-02-2013, 04:22 AM   #11
salzburg , salzburg
I also made my own otriggers out of flat plate bent over at the top and then the rounding cut out with an angle grinder, a metal working shop should fold the metal for you cheaply, if you need to cut out the centres for pipes etc you can always ask them to plasma cut the centres out, i wish i had done this on one side of mine as now i want to run gas pipes through and i will be cutting into the galvanised layer, oh well
Old 07-13-2013, 11:24 AM   #12
1971 31' Sovereign
Finally...
Well...finally quit raining long enough to get one welded. My son is an 11 year old boy scout. He got his welding merit badge for doing 2 of these. I may add a little spot weld to it....
Sorry for taking so long,but my buddy came by with a bottle of JD Green.
ID:	190832   Click image for larger version
Old 08-16-2013, 07:51 AM   #13
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Hi swampthang7,
I did exactly what you did, however, I sistered up a larger piece of 14 gauge steel to my outriggers, see pictures.
Of note, I made sure the metal shop bent my profile to have at least a 1-1/2" on the 'L' of the outrigger.
Makes it so much easier to rivet the banana wraps back in place.
Good Luck,
Chris
ID:	193296   Click image for larger version
newsgauger is offline   Reply With Quote
Old 08-18-2013, 06:39 PM   #14
Replacement outriggers should be welded into place.
Bolts get loose, then welds crack, but they take much longer to crack the the bolts do getting loose.
Replacement outriggers are readily available.
We have provided many of them.
