Hi, I have a 15 gallon air compressor that pushes 4.6scfm and another smaller 5 gallon air compressor, but I'm looking for a sandblaster that these compressors could power well enough to do the job. Was hoping you guys could help me find one. Not looking o buy another bigger compressor, but then again you gotta do what you gotta do. Any info would be helpful. Posting a pic of frame and surface rust to show so you can have a feel for my project.
Thanks again,
Zach
2021 16' Bambi
2021 22' Bambi
North Port
You wont get anywhere fast with that small of a compressor. I have a 120g tank and it runs a lot when blasting. I think you'd be better off looking for a blaster to come to you and take care of it. Look up dustless blasting. Prices are fairly reasonable
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Been there with smaller jeep frame and a harbor freight blaster with 2 compressors running and not very effective at all. I never take my own advise but having a pro do it could be money well spent.
I bought a sandblaster from HF and did quite a bit of blasting using a 5 gal compressor with no problems not sure what tip I used but they come in different sizes the larger tip opening the more cfm required.
However; my compressor specs says it will put out 6.5 cfm and is belt driven.
I understand the feeling of accomplishment doing it yourself. Unless you think you will need to do more blasting in the future, another vote for Dustless Blasting.
I bought the charming cheapie sandblaster from Harbor Freight for about $40. I used sand from Home Depot. I have a fairly small compressor and was able to get all the rust off of my frame (22' Safari, 1966).
This is NOT the recommended way to do it. Using sand is a good way to get silicosis if done long term. I used a mask and got the job done in a day or two. My setup was also outside in very wide open country (a rural area outside of Tucson)
If you can find a shop and tow the frame to them and let them to do it,
its quick and the mess and crud stays with them.
If that won't work rent one for 1-2 days if they have a matching blaster git it also.
