Old 09-08-2011, 12:49 PM   #15
1981 31' Excella II
New Market , Alabama
What sort of gas miliage do you get towing? I get about 10 towing anything.
Perry
Old 09-08-2011, 06:52 PM   #16
Mexray's Avatar
1978 28' Ambassador
Morada , California
Sorry for the delay - had to do the 'work thing' for a few hours...
We get between 9.5 and 10.5 towing our 28ft'er...depends if we're up in the mountains or on the flat lands...
We only run about 55 MPH here in CA, and maybe up to 60 MPH in NV...
Our Excursion has 3.73 differential gears...
Ray & Pat; Morada, CA
Old 09-08-2011, 07:46 PM   #17
1981 31' Excella II
Yeah you got the road gears which is fine for the loads you are carrying. You probably get about the same MPG as I do with the 4:30 gears and 3wd. I have a buddy and he has the same gears as you with 2wd and he gets or says he gets a couple MPG better than me. I think there is a little bit of fish story in there. Even a small tow vehicle is going to get bad MPG pulling a trailer so I would rather have the HP if I am going to get 10 MPG.
Perry
Old 09-08-2011, 09:28 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
Perry,
I agree, I'd rather the 4.30 gears in our Exc for the better performance up in the hills we have out here in the west...but we bought it 'used' with the 3.73's...
When we had a 2000 E-350 4x4 with a V-8 and a heavy truck camper aboard, I spent the $'s and replaced the 3.73's with 4.30's, along with a tru-trac in the rear diff - it made a BIG difference in performance in the hills! We used to run it on lots of sand down in Baja CA with wide tires, and the 4.30's and tru-trac did a great job...
I put the truck's wide tires on the Exc for trip to Pismo Beach here in CA a while back - really made a dune crawler out of it! Look here: http://www.airforums.com/forums/f42/...ach-59050.html
Name:	Mexray's Beach Rig.JPG
Old 09-09-2011, 09:59 AM   #19
1981 31' Excella II
I am starting to lean back towards buying an AS after reading about delamination issues with vacuum bonded fiberglass construction. At least the old SOB trailers with the aluminum skin can be fixed but I don't know about this vacuum bonded stuff. I really don't want something that will be temporary.
Perry
Old 09-10-2011, 03:05 PM   #20
salzburg , salzburg
cooool
your pic's make me so jealous, i want to travel your country sooooo bad!! i gotta say i luv America!! (and i will get me an Airstream to Europe!!)
mrgreen is offline   Reply With Quote
Old 09-10-2011, 07:48 PM   #21
1981 31' Excella II
Well I am the proud owner of a 31 ft, 81 Excella II. It was in better shape than the 78 and it has the center bath and the rear twin beds. It was also in better shape mechanically than the 78. There is no water damage and very little in the way of exterior damage. There are a few small rock dings and no floor rot at all. The lights and brakes seem to work and it is a good thing because we drove it home in the dark. It seem to be well behaved. I have a load distributing hitch but did not hook up the anti-sway bar at all. It came with a hitch actually.
Perry
Old 09-10-2011, 10:42 PM   #22
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Congratulations on your new acquisition! Now you'll have lots of spare time to fill with finding out how everything works or doesn't, and making The List of what you want to change/clean/adjust/update/remove. It's a big part of the fun!
David
DKB_SATX is online now   Reply With Quote
Old 09-10-2011, 11:49 PM   #23
Mexray's Avatar
1978 28' Ambassador
Morada , California
Ok, Perry... your turn for pictures! We want to see what your new 'baby' looks like!
Congrats on joining the mass of Aluminum Tubes out there on the road!
The fun is just starting...use it and enjoy!
Old 09-11-2011, 01:49 AM   #24
1981 31' Excella II
Here are the pics that the seller took. I will take some more tomorrow or later today since it is almost 3AM. It needs some little stuff but overall it is in good shape. I would grade it about a 90% outside and maybe 80% inside. The inside stuff is easy though. All the awnings work and there are awnings on every side. It has been replumbed with PEX and I hope it don't leak. The fridge and AC work and it supposedly has a new water heater. The control panel for the tanks seems to work. Not a bad trailer for $5k.
Index of /AS-Temp/81-ExcellaII-31ft
Perry
Old 09-11-2011, 03:12 AM   #25
salzburg , salzburg
well done that looks v.tidy for 5k. if i could find something like that i would definately ship it home! unfrtunately in Europe the longest you can put on the road is 27ft.
Old 09-11-2011, 07:02 AM   #26
1981 31' Excella II
I would have prefered something a little shorter but I got tired of looking. The shorter ones are hard to find or they are trashed. This one just needs a few little things and some major cleaning. I have seen some that were pretty on the inside but questionable mechanically. This one is also newer which means a little less stuff to fix.
What do you pull a trailer with in Europe? A mini-cooper won't pull much. How do you afford gas for the thing?
Perry
Old 09-11-2011, 08:13 AM   #27
1981 31' Excella II
Well I do have some floor rot issues in the back section under the beds. It was well hidden. I don't seem to have any separation issues as of yet so I am thinking of pulling the bad floor and splice in some new pieces. I guess the good thing is that the bathroom is not in the back. The beds should be reasonably easy to remove and fix the floor. How is the water getting in back there? I have checked the floor in several places father forward and I don't see any problems there. There is some rust on the frame but it does not look bad. I assume that frame separation occurs when the rivets between frame and the skin give way and it has nothing to do with the floor? The rot was hidden under the carpet under the beds. Any advice on how to proceed here? We want to take her to the beach 3rd week in october. I got the water system going and there does not seem to be any major leaks that I can find. Everything seems to work.
Perry
Old 09-12-2011, 12:37 PM   #28
salzburg , salzburg
Perry
yes you're right a mini cooper wouldn't be my choice of tow vehicle but the range rover will do the job!! as for gas i don't intend pulling it often as it will be a consession stand and therefore mostly static!, good luck with your rear end doesn't seem too bad by the sounds of things as for rear end seperation from what i gather it's more of a frame problem when the shell pulls away from it (but i maybe totally wrong on that assupmtion) but it seems to be the rear bath models anyway so you should be safe!
Coastalview :: 1978 Airstream Ambassador Coastalview Airstream Registry Discussions 2 03-25-2015 07:20 PM
2012 Airstream current available models and Floor Plans Colonial Airstream Commercial Listings 11 10-08-2011 08:24 AM
VWFANS :: 1978 Airstream International Ambassador vwfans Airstream Registry Discussions 0 08-19-2011 08:31 AM
Blue Halo :: 1978 Airstream Ambassador Mexray Airstream Registry Discussions 0 08-19-2011 08:30 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
