Old 10-03-2009, 09:00 PM   #1
Profile:  2008 25' Safari FB SE
Spicewood , Texas
linoleum repair
Dropped a heavy pointed object on the floor of my 08 Safari and left a small ding that tore the Linolium.
It's about as big as the nail on your little finger,very small but don't want water to get under there.
The flooring is not glued to the actual floor so glueing it doesn't seem like a good idea.
Does anyone know the proper method for repair in this situation?
Help please and thank you
kingfisher is offline   Reply With Quote
Old 10-03-2009, 09:32 PM   #2
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
First, are you talking about true linoleum or vinyl? If it is linoleum the proper method to begin with is to glue the flooring down to the floor. If you don't want to glue the tear to the floor you may be able to glue the edges together. The recommended adhesive for linoleum is different than vinyl.
Pay no attention to the man behind the curtain- WoZ
Old 10-03-2009, 09:52 PM   #3
2airishuman's Avatar
Profile:
the flooring is vinyl in most of the new units...
and only attached at the perimeter or where INTERIOR bits fix to the subfloor.
i can imagine one of 2 approaches depending on size and location...
1. slip a thin backing material through the hole, then fill the spot with vinyl putty ~ the matching color.
-when dry sand smooth
2. enlarge the hole and sharply define the borders (circle, square, rectangle)
-again insert a backing sheet with adhesive facing UP.
-cut a section of fresh vinyl with the pattern matching at the edges and attach it to the backing sheet
-then carefully glue at the edges which will be ON the backing sheet...
____________
because the sheet vinyl is floating, any attempt to patch or glue that sticks to the plywood subfloor will be an issue.
good luck
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-03-2009, 10:31 PM   #4
Profile:
too late 2 edit...
the flooring is made by armstrong (i think)
here is a link to various repair options per armstrong.
http://www.armstrong.com/content2/resam/files/18879.pdf
cheers
2air'
Old 10-04-2009, 09:26 PM   #5
Spicewood , Texas
repair
Thanks for the info from Armstrong,I will need some sealer.
It's a minor inclusion....great help on this subject!
Dogs and linoleum... cclarkego Off Topic Forum 10 08-04-2009 03:02 PM
Linoleum over new flooring nd48463 Floor Finishes 4 05-12-2009 08:19 AM
Linoleum piratesteve Repairing/Replacing Floor &/or Frame 28 11-07-2007 07:17 PM
Linoleum Tile On Sale fireflyinva Floor Finishes 5 07-21-2004 07:57 PM
New Linoleum tile Bryanhu Upholstery, Blinds, Walls & Interior Finishes 6 09-29-2003 04:35 AM
