Originally Posted by TroutStream
...We are going to put in a wood laminate (probably floating). Is the gaucho easy to lift and replace? also as it looks as though the carpet runs right under the gaucho, should I run the wood under it.
Thats what i did with mine. My trailer has a aluminum composite floor and was sagging between the supports. I just took out the dinette and side couch(
both of which just unscrew from the floor and lift right out), put down a new layer of 3/4" plywood then tiled that. I just lifted everything up 7/8" of and inch and there are no issues at all. Floor is sturdy, looks good and is easy to clean.
