Old 01-17-2011, 06:00 PM   #121
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
lash-up - Definition of lash-up at YourDictionary.com
noun. a temporary or improvised contrivance; expedient; any arrangement or setup. Origin: < lash up, to fasten < lash + up ...
Dictionary and Thesaurus - Free Online at Your DictionaryDictionary Definitions - Cached - Similar
cclarkego is offline   Reply With Quote
Old 01-17-2011, 06:01 PM   #122
cclarkego's Avatar
1966 24' Tradewind
Images: 8
Hey, thanks for posting your pictures. We have been asking for them and now you deliver. I am always interested to see where this thread is going...
Carol
Old 01-18-2011, 01:27 AM   #123
nomader's Avatar
Nashville , Tennessee
I should have taken pictures of the vent rerouted, i also finally got all of the new parts off the floor, I will take some full pictures.
The walls need another coat in spots, I quit painting when I decided to replace the floor. I was just going for the base coat, this stuff is very hard to get the sheen right, I need the right roller.
I have:
1………4”x6”x24’ 3/16 or Ό
1………3”x6”x24’ 1/4
4……… 3”x6”x24’ 3/16
1………3”x6”x12’4” 3/16
1………3”x5”x10’4” 3/16
1………3”x5”x8’ 3/16
1………3”x2”x93 3/16
4………3”x2”x97” 3/16
1………3”x2”x 76” 5/32
3………3”x2”x97” 5/32
4……….2”x4”x32.5” 5/32
1……….2”x4”x58” 5/32
1……….2”x4”x89” 5/32
2……….2”x4”x93 5/32
I’m guessing on the thickness of the metal, it seems right.
4………56”x9.5”x26.5” new tanks with no holes
1………60”x30”x18” new tank, holes in top left corner on the end side.
1………30”x60”x-9” with another 36”x48”x-9” section attached, forming a flat “L” ( holes and sensors on the 30”end side). I was planning on cutting the big tank in to two tanks. It's a very hard plastic, and it looks like you can cut and patch it. It has fiberglass resin type stuff on the inner seem of the "L".
I’m thinking of using the 26000 btu basement A/C or the two 15000 basement A/C. I’m trying to figure a way to fit it in with the radiators getting good air. I didn’t measure them, but I will look it up. I could put them where the penguins were going to be, and put a 36”x6 vent on both sides and a vent on the bottom. I could scrap that plan and move it to the front. I could give up the freezer, or if I moved the freezer a few inches and had a bigger couch, the A/C could be behind the tongue. I would have a gap between the motorcycle deck and the airstream. That should let the air out and keep the water away from the floor, unlike in the original rear bumper.
nomader is offline   Reply With Quote
Old 01-18-2011, 01:39 AM   #124
nomader's Avatar
I will also have the old frames worth of metal. I can trade out with the scrap yard 2 mins down the road.
I'm also hoping to get a pile of angle iron cheap.
Old 01-18-2011, 11:04 AM   #125
nomader's Avatar
berrr.
Ahh!!! I think melted my electrical. I had a spaceheater running and now I have no power on that run. The real scary part is, no breakers are flipped and it's not melted at the plug.
My friend called this morning, he said he's buying new welder.
Old 01-19-2011, 11:14 PM   #126
nomader's Avatar
I couldn't have picked a better time to find this video.
John La Grou plugs smart power outlets | Video on TED.com
Old 01-24-2011, 07:58 PM   #127
nomader's Avatar
I think the beams will be stacked, with 2x2 sitting across them, running from c-channel to c-channel. The bottom supports made of 3"x6". Dropping the tanks from the bottom, with the last tank sliding in from the back. 18" deep tank between the axles. I will do cad soon.
I mainly came on here to say this. If I were to keep the rear bath, I could easily put a seat over the seat in the shower. A piece of corean could hang over the edge and make it a bigger seat.
Remember my truck, I plan to finally get it back tomorrow! $300 labor, $850 for parts. The parts normally would have cost $1700. All of that because I looked at a Prevost. I think I will keep my eyes on the road and not cheat on my AS.
Old 03-23-2012, 02:27 AM   #128
Bigjohn59's Avatar
1966 26' Overlander
1978 31' Sovereign
Glenburnie , Ontario
Any updates on this project?
Bigjohn59 is offline   Reply With Quote
Airstream Bus ALANSD Airstream Motorhome Forums 10 03-10-2011 04:11 PM
Mid 20 degree - garage type storage adonh Winterizing, Storage, Carports & Covers 18 02-05-2010 12:27 PM
Lift struts for access to under bed storage... Phil/Edee General Interior Topics 8 10-02-2008 01:43 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
