02-07-2012, 06:03 PM
#113
1981 31' Excella II
Orlando
I hope it won't drop 2 inches. I think the newer frames like mine and his are a lot stiffer than the 70's era trailers. Mine uses two 6 inch channels welded together to make a box beam. If I recall some trailers used a single C-channel with webs as small as 4 inches, web being the height of the beam.
Perry
03-03-2012, 05:35 PM
#114
1991 34' Limited
Wichita
, Kansas
I've taken a related detour from my floor rot journey to doing sheet metal work that needs to be addressed before proceeding on the floor. I'll be back on this thread fairly soon, but if you want to join me on my sheet metal journey, come over to the new thread http://www.airforums.com/forums/f381...ml#post1114804.
Steve
03-03-2012, 07:03 PM
#115
1991 34' Limited
Wichita
, Kansas
I've past the time limit to edit the post above. I want to correct the link to the sheet metal repair thread here http://www.airforums.com/forums/f381...aks-88252.html. Sorry for the mistake in post 114 (the link works, it just takes you to a specific post and not the start of the thread).
03-23-2012, 07:40 PM
#116
1991 34' Limited
Wichita
, Kansas
Just a brief update...I'm taking the furniture out of the front end to check for the amount of floor damage (rot caused by leaks) that I have forward of the road side wheel well. I almost have the dinette pulled and then I only have the couch to remove before pulling up all of the carpet & pad. I have some leak damage on the curb side too. During my intermission, I've regained some courage to tackle these issues.
03-25-2012, 06:51 PM
#117
moderator
Brandon
, Mississippi
Originally Posted by Steve Bryant
Just a brief update.... During my intermission, I've regained some courage to tackle these issues.
Mine went pretty well, once I got the drive to get started...hopefully the weather is getting better and work can continue!
03-25-2012, 11:18 PM
#118
1991 34' Limited
Wichita
, Kansas
Thanks for the encouragement, Vernon!
I will post some more pictures soon. I've now got the front carpet and couch pulled. I'll have to replace a strip on the road side, forward of the wheel well for about twelve feet (one foot in width). On the Limited model, this passes under the battery compartment located in the forward dinette seat. I've also been waiting for some of the 5/32 diameter "Q Style" structural/waterproof blind rivets to come in (they are on backorder) http://www.hansonrivet.com/pdf2008/C...29-C30-C31.pdf.
03-26-2012, 07:08 AM
#119
moderator
Brandon
, Mississippi
Steel shank rivets?
03-28-2012, 08:28 AM
#120
1991 34' Limited
Wichita
, Kansas
Originally Posted by HiHoAgRV
Steel shank rivets?
No, the rivets that I will be using are made out of aluminum and have aluminum shanks or mandrels, so I shouldn't have a corrosion problem. I'll be installing them wet (with TremPro 635 and the rivet inner bore to the mandrel are supposed to be "water-tight."
I'll be using the 5/32" QAAD502 (grip length up to .125") or the QAAD504 (grip length between .126 and .250). The QAAD504 size is on back order.
03-28-2012, 07:26 PM
#121
moderator
Brandon
, Mississippi
Cool. Keep the focus, spend a small amount of time on a regular schedule and VERY soon you will be camping...
(the cheering section does a 'wave' at this point)
05-01-2012, 09:42 PM
#122
1991 34' Limited
Wichita
, Kansas
With the help of my good friend Ralph, I've made a lot of progress on the trailer. I have a lot of additional pictures and narrative that I want to post in the next week or so, but here's a preview of where we are right now (floor, including bathroom, completely removed in back bedroom, much of front furniture removed, all carpet and parkay kitchen flooring removed, flooring along road side partiallly cutout and lower inner skin removed. Take a look. I'll try to fill in some gaps for you good people in the next several days with additional posts.
We're about ready to start on sheet metal and riveting work, then it'll be back to the frame (wire brush, POR-15 three step treatment - degreaser, etch, two coats of paint).
If you want to look at more pictures, look here http://s172.photobucket.com/albums/w...eam%20Limited/.
05-02-2012, 06:31 AM
#123
1986 31' Sovereign
1964 17' Bambi II
Schererville
, Indiana
Wow! That's a lot of work you've done! You're making great progress. While you have the front all apart, are you going to have a steel plate welded to the frame to keep the front end from separating? Now would be a great opportunity to have that done too!
Becky
05-02-2012, 06:42 AM
#124
AlumaCave
1999 34' Excella
Alamogordo
, New Mexico
Great to see your progress, Steve!
I've been following your floor and leak saga; your documentary style is fantastic. However, you must be anxious to get the project completed and begin enjoying your Limited again. I see by the huge QT cups (which I miss - haven't seen a QT in years) the Wichita heat is beginning. Take care!
05-02-2012, 08:21 AM
#125
1994 30' Excella
alexandria
, Kentucky
Steve,
Your really doing a nice job on the repairs and tracking down the leaks. I replaced the front floor in an 89 - 29' trailer this past winter so I understand the depth of work your involved in. This is not a job for the faint of heart. I borrowed ideas from HI-Ho's thread and put in the front hold down plate. I also vulkemed the back side every rivet I could find. The trailer originally had a leak problem around the battery boxes.
Good Luck and keep up the hard work.
Steve, Christy, Anna and Scout (Border Collie)
1994 30'11" Excella - rear twin
Hensley with adjustable stinger
WBCCI # 3072
AIR # 6035
05-02-2012, 09:16 AM
#126
moderator
Brandon
, Mississippi
Wow Steve, it looks like you have a clean slate to start a very nice rebuild...thanks for documenting it all.
| Thread Tools |
| Display Modes |
