08-02-2012, 02:11 PM
#182
1991 34' Limited
Wichita
, Kansas
I’ve also taken some time to write up a somewhat detailed to-do list to finish up this project. Here’s the list which was done with a word processor so that I can edit it as I go along.
- Finish sheet metal work
- Riveting in rear
- Design & install doublers & strengthen front as required
- Install blind rivets near bathroom
- Install extrusions on left rear storage compartments (cord & general)
- Remove and seal remaining Olympic and Pop rivets
- Check for and replace missing rivets
- Paint frame & install floor in front
- Shift support of rear frame to allow gap between shell & frame
- Paint rear frame
- Install floor in rear
- Install PEX plumbing that penetrates floor
- Route and connect wiring where necessary (replace grommets)
- Repair floor rot at entry door threshold
- Caulk all exterior fittings and attachments
- Make and install 4 gutter bridges for lower U channel and caulk all voids/cracks, etc. in U Channel
- Drill additional weep holes in U channel as required
- Test for leaks from exterior and repair as necessary (use hose & pressure washer and maybe it will rain someday) – reseal as required
- Install insulation
- Install belly skin, belly wrap, aft leveler jacks (op check) and rear casters
- Install rear bumper and sewer hose storage compartment lid, etc. – Caulk as required
- Install interior skins
- Complete PEX pluming installation
- Install laminate flooring
- Install interior electrical components (batteries, new converter, solar charger regulator)
- Clean walls & ceiling
- Clean and refinish furniture & upholstery
- Install furniture (replace rubber bumpers on doors, etc. as required)
- Make electrical and plumbing checks and rectify as required.
- Repack wheel bearings, replace seals, check, lubricate & adjust brakes
- Replace brake break away switch & verify exterior lighting
- Make several short test drives and correct squawks
- Replace wheels & tires (tires are too old and I've decided to move to 16" wheels and LT tires)
08-02-2012, 02:18 PM
#183
1981 31' Excella II
New Market
, Alabama
Steve your circular plate sticks up a little. Are you going to route out the new floor to account for this or are you going to just jack up the shell to account for that?
I think you are going to have a battle ship there soon.
Perry
08-02-2012, 06:24 PM
#184
1991 34' Limited
Wichita
, Kansas
Perry,
Because plane of the bottom of the plywood will fit into the C Channel, I won't have to compensate for the plates on the plywood. However, I was concerned initially about the fact that these plates would elevate the level of the shell by 1/4". Now, I believe that the thickness of the plates won't affect anything very much except to give more support and a broader interface between the front shell and the front of the frame.
Even with Airstream's use of a fairly scanty frame, I don't believe that front or rear separation would be such a problem if they did a better job of connecting the frame and shell together over a wider area and if leaks and sub-floor rot were not so prevalent.
08-02-2012, 06:31 PM
#185
1981 31' Excella II
New Market
, Alabama
Are you going to put the leveling jacks back in when you are done?
Perry
08-02-2012, 10:16 PM
#186
1991 34' Limited
Wichita
, Kansas
Perry,
Yes, I'll put both jacks right back where they started. The main things that I plan to leave out are carpet and the parquet flooring in the kitchen. The whole interior floor will probably be some type of laminate. Otherwise, the configuration of virtually all of the interior and exterior components will be the same as when I started.
08-03-2012, 04:49 AM
#187
1981 31' Excella II
New Market
, Alabama
You could leave the areas covered by furniture bare so you can inspect for leaks periodically. I expect your layout is considerably different than most because of the jacks and horizontal tanks.
Perry
08-03-2012, 02:12 PM
#188
1991 34' Limited
Wichita
, Kansas
08-03-2012, 05:38 PM
#189
1981 31' Excella II
New Market
, Alabama
That is the same layout that I have. I think I may change mine to a dinet at some point.
Perry
08-24-2012, 11:52 PM
#190
1985 34' Sovereign
1958 22' Flying Cloud
1971 31' Sovereign
Zillah
Wow, that does look familiar! Except we had very large mushrooms under our beds. You have a project on your hands, but at least you are getting yours done. Your 34 is built exactly like our Monty. Yours looks to be the same style as all the 1970's trailers we have around our shop. I see you are thinking about testing for leaks. Have you thought about a pressure test? That's what Monty is going to get. I heard they do it all the time for school buses. My plan is to plug all the vents and hook a large carpet dryer fan to one of the stow box openings, and spray the exterior with a water/soap/corn syrup mixture. Then since the interior is out, get the leaks with prodex. It shouldn't take much pressure to show the flaws. I picture it working like a long silver "bouncy house" without the kids. A pressure wash is a good idea, but only before sealing so that you accidentally don't cause more leaks with the high pressure jet. After that test, I may use a sprinkler.
08-25-2012, 11:06 AM
#191
1985 34' Sovereign
1971 31' Sovereign
Zillah
Sorry, I meant to say Tempro not prodex to seal up our inside seams.
08-25-2012, 02:14 PM
#192
1991 34' Limited
Wichita
, Kansas
Landscraper,
Here is a post about a homemade leak tester that Vernon made http://www.airforums.com/forums/f205...ml#post1155535. I'm thinking abut doing something similar. I plan to locate a used furnace squirrel cage blower and make a plug adapter for the rear trunk area with an opening through the partition that separates the trunk from the under-bed storage. I can't use the side (under forward dinette seat) door like Vernon used because that is the exterior battery access on my trailer.
Steve
09-29-2012, 12:49 PM
#193
1991 34' Limited
Wichita
, Kansas
I have a bit more progress to report. Ralph and I have drilled out the rivets in the front of the trailer and made a couple of internal doublers that we’ll rivet in when he gets back from a trip he’s been on. I’ve removed oodles of ineffective sealant goop that AS lathered on the rivets in the front so that we can get down to the bottom of some of the leaks.
10-05-2012, 12:11 AM
#195
1989 32' Excella
Silverton
Bought a 89 Excella 32'. Discovered that 4' of the floor has to be replaced in the rear. I'm well into the job. Will start making templates tomorrow. Wow it was hard to believe the rot. Mine even had a colony of tiny ants eating the rotten floor material.
10-05-2012, 12:44 AM
#196
1989 32' Excella
Silverton
I'm thinking of wrapping the new plywood floor material edge with Tyvek so that any water that gets past the seal will be ducked away from the wood and insulation. If it [water]gets past the seal it would just run down the outside of the wrap and drip into the pan. The pan has a few very small holes in it about the size of rivet holes. The wrap would hang lower than the insulation. Of course I'm using a good exterior plywood that I'm going to coat with a good sealer. Looks like the water came into the floor from a lack of a good seal on the rear bumper box.
10-05-2012, 05:23 AM
#197
1981 31' Excella II
New Market
, Alabama
The bumper plate is a long standing FEATURE of Airstreams. They come with this outstanding leak producing plate.
Perry
10-10-2012, 09:40 PM
#198
1991 34' Limited
Wichita
, Kansas
Mark and Perry, I'll show you what I have in mind for the pesky bumper rot precipitator (AKA Bumper Plate) in a future installment.
Ralph and I have used the Marine Clean degreaser and Metal Prep acid etcher on the rear frame, cross members and outriggers. I first washed everything using liquid dishwashing detergent and a brush. This included about the lower foot of the sheet metal sides and the U channel, the frame parts, everything that I could get to down there. That will make for a cleaner repair as we progress. I have used my electric leaf blower a lot on this whole trailer repair job. It blows out trash/metal shavings/etc. that get stuck in inaccessible places. Also, the leaf blower speeds the drying process with each step of the POR-15 process. Last night, before we painted today, I ran a room fan in the back to circulate the air and try to make the metal bone dry as is recommended by POR-15 instructions.
After cleaning the metal and applying the Metal Prep and rinsing it off thoroughly with hot water, here’s what the metal looked like prior to paint.
Here’s the POR-15 painted frame (2 coats). We have some more miscellaneous riveting to do and then we’ll start installing floor. It’s getting exciting after so many months.
10-11-2012, 12:35 AM
#200
1989 32' Excella
Silverton
Very nice work
