Old 09-02-2013, 07:58 PM   #1
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
late '50s early '60s floor channel
I have to replace the floor channel on my 62 FC and want to know what alloy aluminum was used. I have measured it at about .023 thickness. Was it tempered or just 5052 type aluminum? Any help is appreciated.
Name:	bad cross member and terrible channel.jpg
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 09-02-2013, 09:02 PM   #2
mapleton , Utah
A hard tempered aluminum like 2024 t3 will crack if you try to bend it like c channel. Use 5052 h3 in .032 or .040 and you will be happy with the results.
tim
rumrunner is offline   Reply With Quote
Old 09-05-2013, 06:43 PM   #3
JFerguson's Avatar
1964 26' Overlander
Gloucester , Virginia
Here is the replacement part: Floor Channel Bow - Narrow Body104463 [104463] - $58.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
JFerguson is offline   Reply With Quote
Old 09-07-2013, 06:23 PM   #4
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Common 5250 in .032 will form up in a common alum siding brake. The .040 will bend up in a good one. Comes out as original.
putback is offline   Reply With Quote
Anybody add a grey tank to late model bambi? sigv Waste Systems, Tanks & Totes 3 05-27-2012 09:54 AM
The Early American History Trip - Suggestions? rebelstand On The Road... 122 05-13-2012 07:18 PM
