Old 06-06-2012, 06:43 PM   #1
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
Just about ready to pop the top
Ok interior and inner skins removed,
banana skins removed
bolts through floor and frame to end C channels removed
rivets along sides to double C channel drilled out.
rivets through front plate and skin drilled out
building gantries tomorrow.
what am I missing? are there any secret connections from top to bottom i am missing?
nervous....
latest pics here
1975 Airstream overlander restoration
dkrukosky is offline   Reply With Quote
Old 06-06-2012, 07:26 PM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I have no personal experience removing Airstream bodies but I have spent a life taking things apart. Like anything you do, practice makes perfect only I'm guessing you don't want too much practice....
I am sure you will find out it will be fine.
Good luck,
Bruce
Bruce B is offline   Reply With Quote
Old 06-06-2012, 08:25 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Remove the trim around the wheel wells there are some hidden rivets there if you haven't done so already. Well at least on mine there where
I just pulled mine a week ago Here is what I did. http://www.airforums.com/forums/f44/...8-a-90934.html
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-07-2012, 07:54 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
There is a hold down plate in the rear too. On my unit the same rivets that went to the channel went through the plate too, or what was left of it.
Aaron
WBCCI #XXXX AIR #2495
