Old 03-09-2012, 08:29 PM   #1
2004 16' International CCD
Orem , Utah
jacking points
ok read the manual and says to jack were arrow points but that is soft alum. Do they really mean the frame off the arrow 6inches. They did have square alum things and figured that was spot.
starcraft is offline   Reply With Quote
Old 03-09-2012, 08:30 PM   #2
Only lift the trailer from the axle mounting plate.
In your case, just rearward of the wheel.
Old 03-09-2012, 09:04 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
They mean under the frame where the arrows point. Sometimes there is a plate riveted to show the exact spot, sometimes not. Ours does not have the riveted plate. Just locate the frame where the arrow points and that's the spot to put the jack.
TB & Greg and Abbey Schnauzer
#3954
Old 03-09-2012, 09:22 PM   #4
Ottawa , ON
And, of course, there are other opinions on that shaggy old subject.
From no less than the Jackson Center factory.
Jack points kb0zke Jacks, Stabilizers, Lifting and Leveling 55 03-10-2014 01:41 PM
Jacking points AWCHIEF 1964 Bambi II 1 02-18-2012 07:30 PM
Support points for putting a Sovereign on blocks Liberia Winterizing, Storage, Carports & Covers 4 11-26-2011 11:05 AM
Stabilizer points on 30' Argosy stgerdonly Jacks, Stabilizers, Lifting and Leveling 0 07-21-2011 12:19 PM
Rough casting hitch "friction" points dznf0g Hitches, Couplers & Balls 2 01-31-2011 04:55 PM
