Old 04-06-2007, 04:21 PM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Is this standard layout
Hello everyone,I have removed my wet bath to replace the rear 4' of sub-floor.Are these cuts standard in this channel or did they miss the layout on the rear crossmember.I have to replace member and should I move it back 1/2" or keep all as well and reuse existing holes.I could not find any info here on this.I do not have the bottom channel is it wise to install.
bertro is offline   Reply With Quote
Old 04-13-2007, 05:27 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Bumping this one up. Sorry I can't answer, but there are those that can
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-13-2007, 09:03 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
No that is not standard. I would wait and see what everything looks like after it is all taken apart. If it's anything like my 71 there was two sets of bolts, one held the plywood down only ( these were under the channel) and the others went through both the plywood and the channel. I would not change the location of the channel, as this will cause all kinds of alignment problems with the inner and outer skins. get it apart and cleaned up then make your decision if you need to drill new holes or not. You do need the channel, as it is what the bottom of the inner and outer skin rivet to
Kip
"THE" Letter !!!-Zoning violations discussions airstreamcaravel Title, VIN & Registration 108 01-06-2004 08:41 PM
Standard vs. option? silverback 1997 - 2004 Bambi 7 07-19-2003 03:00 PM
Layout of wardrobe & chest of drawers jeanarlene General Interior Topics 2 09-30-2002 09:40 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 09:51 PM
