OK. I've gotten a lot of great advice so far here on the forums and I can't thank the generous souls here enough. Your support has gotten me this far, now I'm staring over the precipice and I have really cold (frostbite!) feet.
As some of you know I'm doing a floor off restoration of my '62 Bambi. Problem is I have no garage, I live in a small apartment in Manhattan but I've been working on the trailer in my yard at a weekend place we have out in Montauk Long Island. I've gutted the interior, stripped all the interior panels, and drilled out the exterior perimeter of rivets around the bottom edge.
I'm ready to pull the shell off, but I've been listening to the Vintage Airstream Podcast and reading various threads of the good folks here who've done this already and frankly I'm worried. I'm doing this on an uneven grassy area, in a location that is often quite windy. I've seen all the posts with interior gusseting built and plan to do that, but then I was going to pull the frame over to a welder about 20 miles away for him to repair anything and beadblast and powdercoat the whole thing before returning to Montauk and replacing the bottom and shell.
I've read much about how the frame has little stability once the shell is off and that moving it around could warp it. And that if the shell is not in a perfectly level place, that even with the supports built in, the same could happen, and finally that once off the shell is so light it could totally just blow away in a big gust of wind (it often can get to 30 or 35 knots out here). Everybody really seems to emphasize that the shell off part is really, really, tricky and that many things can go wrong!
It's occurred to me that maybe a 16 foot trailer isn't as sensitive as the bigger ones, but I've tried to find a garage I could rent to do the work in for a short time out here, but to no avail. Although I'm totally new to handy things, I'm learning a lot, and enjoying it all, and I really want to try and do everything myself, but I'm thinking perhaps I might have to settle for having somebody do the frame and floor who's a professional and then taking over to build the interior back.
I'd love to get some input about this, and if anyone knows any good restorers in the east who might be willing to just lift the shell, fix the frame, replace the floor and re-attach the shell that info would be helfpul too. Otherwise should I just forge ahead, or do I absolutely have to find some kind of shop I could rent for the duration of at least the shell-off part.
Lots of info here, many people have done what you re about to do.
You're well on your way, then.
Your shell is very small, only 13ft or so, and narrow. light bracing is advised, but it's not nearly as crucial as on much longer and heavier trailers. You might try and tie down the shell to something heavy, liek aboulder or stakes in teh ground that will keep it from blowing away.
Prevent air entry by keeping it close to the ground and keep doors and windows closed, that will help it from becoming airborne.
I woul dbe concerned about this, but it's usually easy enough to shore the shell so that it indeed does sit level. A little twisting will not hurt it, a lot of twisting will break the seals between the sheets, and possibly shear rivets.
Your frame is short enough that it will not be a problem towing it without support.
That would be a nice break fr yourself from all the worries that you have expressed. Without seeing your location, it would be difficult for anyone to properly help you assess this.
Thanks so much again everybody for all your help.
Steve H.
It's doable, and it sounds like you are well on your way, armed with knowledge and courage, but perhaps a little short on logistical possibilities....it might help to talk with Colin Hyde from GSM vehicles, he's in New York ( state) as far as I remember.
I think all I could add to Uwe's good advice is that the shell doesn't need to be keep perfectly level if you put some good cross bracing in. More important to get it lowered as close to the ground, or on the ground, as possible. If it's on a slight rise up or down doesn't matter.
Maybe you could throw a tarp over it, and really stake down the tarp. The trick, as Uwe said, is to keep wind from getting under it and lifting it like a big airfoil.
HamiBambi, I worked on by Bambi inside. It was great. However my 55FC will not fit in my garage. I have the same question you are asking. Thanks for your questions. As far as your fears about doing some of the work. My suggestions is to keep asking questions. You can get so much information and help here on the forum. And the encouragement is very helpfully as well. I think Airstream trailers are more forgiving than you might think. Be patient, willing to do a job over several time if needed, and don't get in a hurry. Every job is a learning process. Now that my Bambi is almost finished, I find myself just sitting in it and looking at what I've done. It's way cool.
Don
With such a small unit, perhaps it might be economical to have a small, level concrete pad poured at your weekend place. You would then have a nice level pad to park it on after you finish the project. The going rate around here and up in Ohio is around $3 per square foot.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
If a rental question or a permit problem comes up an alternative (for about the same $3 per sq ft (or a bit less) might be to pick up a pallet of "pavers" from your local big box Homer'll doit store and then a truck load of sand and retention timbers. Level the pad area with sand and timbers and pave with the "concrete blocks" in various shapes and colors.
Here in Small Town Texas it's very difficult to get a concrete permit, but we can cover the entire yard with pavers if we want - pavers are not considered "permanent".
Might be an option for you.
Dennis
Thanks for the support and the well wishes, especially regarding the size of the trailer being a little more forgiving than some of the larger trailers. I'd hoped this would be true. Your ideas about securing with a tarp, etc. are good. The concrete and paver idea is a good one, but our house out there is a rental and I don't think I can pull that off without alienating the landlord.
I'm going to soldier on and I'll keep all of you posted. I did try to contact the guy from upstate New York who's on the VAP podcast but I haven't heard back. And I'm still fishing around to see if I could borrow a garage out there in Montauk. The best part is I'd gotten sort of discouraged and I feel heartened again to move forward so thanks for all that!
It has been 10 months and some of them looooooong since my husband started our 1963 Bambi... but we are getting close to our maiden voyage.
It is a lot of work, but so rewarding in the end! Hey, post every day you make any progress, or at least let everyone know what your progress is... any questions, problems, or "hey, look what I did!" you should post ~ and of course, with lots and lots of pictures! The good folks on the forum were very supportive and it kept hubby of mine cheerful and ready to tackle another day! Even through our wet and cold winter. So, hang it there, post pictures from every day...we want to see a "before" pic too! You can do this!
6 long years ours has been in a state of grace. All kinds of terrible things can happen and do. Wonderful things happen as well. Currently, we live Airstream dreams through others efforts while we wait for the right time. Stripers on Montauk? Remember, we are all pulling for you and we love pictures. You will love the pictures when your are done and looking back. Rob
Thanks for the support and yes, I'll start posting some pictures of the process. To aid with the process of completing the Bambi and to help my lovely and supportive wife Jocelyn from feeling too stressed and anxious about it, we've gone out and done it again. We bought a 22 foot 1960 Safari this weekends so that we can hit some rallies and have some guests come visit us in Montauk. (This was the original reason we bought the Bambi in the first place.) I was really beginning to regret that I'd pulled the thing apart before we actually got to enjoy it at all when in retrospect we should have gone to a couple of rallies and had some friends come and stay first. But now we have it all! A beautiful original Safari that "doesn't need any work", and the Bambi project to keep me busy for the next two years to come. I'll keep you posted (with pictures I promise!) on all and thanks again for all your support.
Somehow, despite all the precautions I've got this Aluminum bug bad!
Hey Mrs. NorCal Bambi! (And everyone else of course, but she sent the most smiley faces.) Thank you for your support and good wishes. So inspiring that you've driven me to get another one. Here's our new baby! We got it home to Montauk via three different ferry rides and a mission impossible style connection with the sellers who drove from Maine on the New London Ferry dock on a foggy foggy morning. Now, since this one technically only needs some aesthetic things taken care of for now, it's my wife Jocelyn's project so we can work side by side while I keep plugging away on the Bambi!
