Old 03-07-2013, 07:59 PM   #15
1973 25' Tradewind
Beautiful , Oregon
Bart thanks for taking the time to draw it out. Yes I can see all that.
So I guess what I do is drill out the rivets along the belt deal ( don't know what to call it) around to about the lights or so and slip the old steal out. That will be easier than putting in the replacement. I will round up some stainless steel and someone with a break or do a home effort between some 2x 4s or something.
Now I am debating going back to another x member. I feel the 1/2 lap and epoxy will make it stronger than the wood itself but I think epoxy is a brittle bond without much flex. So like everything I research and ponder at least 3 x the work I get in doing a thing. It would be longer without you alls help.
Tony
Tony S is offline   Reply With Quote
Old 03-07-2013, 10:33 PM   #16
Maniacal Engineer
barts's Avatar
Menlo Park , California
I used gorilla glue when I did mine; titebond III would work really well. Construction adhesive works too. I fastened the floor patches together with laminating screws, which look like really heavy duty wallboard screws. They're there just to hold things together while the glue dries.
With the rear floor gone, you can slip the metal up and in from the inside w/ only a few rivets out.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-08-2013, 07:42 PM   #17
1968 26' Overlander
Duluth , Minnesota
Epoxy will work but is a pain to work with. Construction adhesive is easy to use supplied in tubes, it's inexpensive, has long open time, and is very strong and somewhat flexible when cured. It is probably more like the glue in your plywood than epoxy is.
If your marine plywood has any kind of coating on the exterior, glues may not bond as well as they do to wood. Your lap detail eliminates that problem.
Bunkroom is offline   Reply With Quote
