Old 02-24-2011, 04:29 PM   #15
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Today's progress. Got the belly pan off from the back bumper to just past the front wheels. So far all the cross members except the rear most one. 2 out riggers in need of repair or replacement. One rear corner out rigger is missing, and the other one came off with the bananna wrap ( looks like it only had about 1/2 inch of weld). The main frame rails look good except for one spot on each side behind the rear wheels. Across the back of the trailer, the bathroom floor stops about an inch from the back wall. Looks like the water was getting in around the door in the bumper. So far it looks a little better than I had feared. Then again I am only 1/2 way done opening the bottom.
ID:	122979   Click image for larger version
ID:	122981   Click image for larger version
ID:	122983   Click image for larger version
ID:	122985   Click image for larger version
Baseman is offline   Reply With Quote
Old 03-11-2011, 12:09 PM   #16
Baseman's Avatar
1974 25' Tradewind
Progress so far.
ID:	124239   Click image for larger version
Old 03-11-2011, 01:00 PM   #17
1973 31' Excella 500
Spring Green , Wisconsin
Thanks for posting the pics. I'll be opening up our belly pan in the next couple weeks and expect to find about the same thing. Is your frame cracked behind the rear axles or rusted?
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 03-11-2011, 05:01 PM   #18
Baseman's Avatar
1974 25' Tradewind
Yep! The main frame rail (roadside) was rusted through directly behind the rear axle. Reinforced with a couple of pieces of 3" channel. The curbside wasn't to bad. Got a few bad out riggers(new ones on the way from Inland RV). The rest of the frame and crossmembers are in good shape.
Colorado Title? lucymcdog Title, VIN & Registration 105 10-21-2016 08:28 AM
'78 31' Sovereign 87MH 1974 - 1979 Sovereign 99 01-12-2015 07:28 PM
Future home of the Albatross ND10CentCan 1974 - 1979 Sovereign 49 08-01-2013 03:43 AM
This is a bad dream . . . right? Splitrock Off Topic Forum 49 04-19-2011 08:21 PM
Factory hooked up gas detector wrong! lsrart1 General Repair Forum 6 01-13-2011 01:51 PM
