Old 01-09-2016, 10:15 PM   #29
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
C130s, 141s, 17s, etc. are not made to exacting lawn furniture standards either, nor do they have their bottom thirds hacked off intentionally to attach third-world quality iron axle mounting brackets that just happen to be handy for racking for ricks of wood we take advantage of as flooring...
Seriously folks, as lawn art they don't need the inside skins but do just a couple Dukes of Hazard jumps across culverts or lift the wheels dragging the tail end just a few times while taking shortcuts up pikes peak and see if the door(s) and windows start popping open randomly or the shell begins leaking daylight and water...
Old 01-09-2016, 11:45 PM   #30
68Streamline's Avatar
Cerritos , California
Last year we pulled a 1947 Curtis Wright Model 5 from Texas to Los Angeles. No interior skins and no windows. This 68 year old made it home in one piece. "Over engineering" comes to mind.
68Streamline is offline   Reply With Quote
Old 01-10-2016, 12:01 PM   #31
1998 30' Excella 1000
Livingston , Texas
I know that this thread was started about the interior skin, but with all the engineers following it, I'd like to ask a question about the exterior skin, which has been indicated to be the most important structural component.
My '98 was built after Airstream greatly reduced the buck rivet density by using some kind of double stick foam tape at the ribs. On one section of my sidewall, in an area of almost 40 sq ft, I only count 10 rivets. The foam tape has clearly released in these areas, as I can depress the skin over 1/8" before contacting the rib. I'm just wondering how much this has reduced the structural strength of the shell, in comparison to the highly riveted older models. Will these new ones hold up for +50 years like the Airstream of old?
Siegmann is offline   Reply With Quote
Old 01-10-2016, 06:05 PM   #32
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Interior skin necessary?
My opinion is that the interior bulkheads provide far more strength than the interior skins, but with the exception of being covered with a very thick and heavy load of snow and/or ice, my 70s era trailer is more than strong enough to tow anywhere without skins or bulkheads.
I wouldn't give it a second thought.
I guarantee that the exterior construction of the trailer is very stout.
Brevi tempore!
Old 01-10-2016, 06:16 PM   #33
Interior
The fact is that the interior skins, are indeed a part of the "MONOCOQUE" construction.
It's proven over and over again, that the interior, while not as contributing to the aircraft design as the exterior, is STILL very important.
Airstream learned that the structure needed beefing up, and that's simply why they increased the thickness of the exterior sheets, some years ago.
But once again, since each person owns their Airstream, they certainly are free to discount any and all design criteria that the Airstream engineers have developed over many years.
They then can suffer the losses and somehow blame Airstream for it.
Oh well, I am sure the 2017 models will have some changes. Lets all wait and see.
Old 01-10-2016, 08:44 PM   #34
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
My 28' TT before purchasing was gutted for years. Not a panel in it. It was towed 100+ miles through the hills of KY to my location without any harm, was it safe? probably not, but the structure showed no signs of stress or torque after towing. That being said it is possible to tow without skins, in good conditions. But be advised that any adverse condition may change the outcome. So would I continue to tow without them if I had a choice? absolutely not! create a access panel that can be removed but intact while towing.
ID:	255499   Click image for larger version
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 01-10-2016, 09:05 PM   #35
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Here's what can happen with no interior skin and a wet snow load.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 01-10-2016, 09:08 PM   #36
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
My god! You can never underestimate mother nature!
Artisan Airstreams
Old 01-10-2016, 09:26 PM   #37
Cardinal283's Avatar
Dallas , Texas
Yeah. That's kind of exactly the situation I was describing. Maybe some of the engineers need to run their numbers again. That doesn't even look like a lot of snow compared to others I've seen.
Has anyone contacted an engineer at Airstream about this subject?
Cardinal283 is offline   Reply With Quote
Old 01-10-2016, 09:27 PM   #38
Dallas , Texas
I'll bet the trailers in the background have their interior skins in. 😂😂😂
Old 01-10-2016, 09:31 PM   #39
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Engineer or not you add enough snow to any structure and it will fail.
I'm sure the owner regrets not getting the broom out to knock some off before it got too bad. It had to be showing symptoms before the implosion.
Artisan Airstreams
Old 01-11-2016, 08:25 AM   #40
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I don't believe that was from a snow load unless u can show before and after pics. That looks like a tree damage or a wreck.
Matt
rugjenkins is offline   Reply With Quote
Old 01-11-2016, 08:49 AM   #41
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
There is a thread in here somewhere where the owner of the crushed trailer discusses the sad situation.
He says snow load.
Brevi tempore!
Old 01-11-2016, 09:01 AM   #42
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
This is the roof over the cab of my 84 Motorhome. I bought it this way from a fellow in Vermont. I am not sure if it was snow or something else, he did not say. There are no ribs in front or the rear sections of the motorhome, and only the plastic liner inside.
WayneG is online now   Reply With Quote
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 06:15 PM
interior skin scrap for exterior skin patch? badger Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
is a rock guard necessary? flyingcloud Rock Guards, Segment & Window Protectors 33 07-28-2005 03:28 AM
Are drain valves necessary? nickcrowhurst Fresh Water Systems 9 11-26-2004 07:37 PM
