Old 01-17-2005, 11:41 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
insulation suggestions?
I peeked around and looked for an insulation thread; point me in the right direction if it's been said and done.
What kind of insulation should we replace the yellow stuff with that's under the floor? How does it stay in between frame pieces, or does it attach under the frame or floor somehow? I know some of you have done this, pictures would help. I know the higher rating the better; I'd like to hear some experiences of others putting in insulation when they replace the floor. FYI: The belly pan is almost completely off and we're replacing the entire floor.
http://community.webshots.com/user/pinkflamingoes/
Pictures at this link.
Thanks all!
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 01-18-2005, 12:42 AM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
Nice set of pictures. Looks like you have your job well underway. I take it you are going to take the shell off since the belly pan is off or do Malcolm's technique.
The insulation discussions have been mixed in with the floor threads.
You have your foamers and your glassers. Foamers come in two general types, cut to fit or blow in place. There are always the ambivalent ones who blow in place the cut to fit. Glassers tend to duplicate the factory by laying down a layer over the frame and squishing it with the floor. I think the foamers out number the glassers. There are a few bubble wrappers but they tend to hang out on the walls and wear baggy pants.
I am debating the same issue. If the weather was warm I think I would use cans of foam to fill in around cut foam board. Problem is what kind of board and what kind of foam will hold up without condensation and mold problems. In fact I may use foam to seal all possible entry to the belly pan by critters and leave the air space with a layer of reflective foil. This will give me working room for attaching the floor as I am putting the belly pan on first. Do mice eat foam. The foil on top of the frame and under the floor. Returning later with more foam from underneath if I need more R.
A thermo break between the floor and frame seems like a good idea, but the walls don't have one. Of course the walls don't have wood to rot from condensation either.
Your choice will be influenced by the order of battle so to speak. Floor on first or belly on first. I wonder how much the foam would push out the belly pan if sprayed into the cavity after it's all together.
I think this may be the least standardized of the restoration projects. I am determined to be mice and snake proof.
Over59 is offline   Reply With Quote
Old 01-18-2005, 02:45 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
glassy eyed here
...I mean glasser here. I am redoing sections of mine so I will be going back in with the fiberglass similar to the way the factory did it. From what I can tell they put down 2" paper faced batt insulation from the top, then added a layer of unfaced (not sure how thick) from the bottom before installing the belly pan. I am probably going back with 6" faced from the top and "notching" where it goes over the frame to make it a little easier to fit. The ONLY board insulation that I am aware of that doesn't absorb water would be the Extruded Polystrene ( usually in blue or pink) which is used heavily in the building industry in places like basement walls, under slabs and in roofing systems. There is also Expanded Polystyrene which is the white beaded stuff(like the cheap coolers are made out of), but I don't think it would stand up to the constant vibrations and it is has a fairly poor "R" value per inch. I also wondered about the lack of a thermal break in the walls....next time I go to the Boeing Plant for a tour; I will pay more attention to what they put in the walls of the 747's IIRC they were using a couple of different types of insulation depending on where it was in the aircraft. I know in at least one location they were using a fiberglass insulation that was incased in a poly wrapper.
Aaron
WBCCI #XXXX AIR #2495
Old 01-18-2005, 05:31 AM   #4
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Didya have to say snake?
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 01-18-2005, 06:54 AM   #5
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Or do both ...
We chose rigid extruded foam for most of the easy spots, and traditional fiberglass batts for the curved and tricky spots. I prefer the rigid foam because it will not be affected by water, but the fiberglass is better at noise dampening.
Name:	scaled.rear rigid insulation.jpg
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 01-18-2005, 07:11 AM   #6
Images: 59
I'm a glasser and a foamer. I used 3 1/2" fiberglass (formaldehyde free), but I didn't want it to be resting directly on the belly pan. I felt that leaving an air gap between the insulation and the belly pan would provide for drainage and drying out if water ever got in.
I suspended the batts of insulation with galvanized metal angle, mounted to the crossmembers, and strips of sheetmetal between the angles.
At the corners, I used sheets of polyisocyanate foam, glued to the bottom of the floor, then trimmed with a knife to match the contour of the bellypan.
ID:	10120   Click image for larger version
Old 01-18-2005, 12:46 PM   #7
greg176's Avatar
Gabriola Island , British Columbia
Aaron
Boeing (and Airbus) uses a fiberglass insulation in a mylar bag.Its mostly about keeping the insulation together the air roars around quite a bit in flight.
greg176 is offline   Reply With Quote
Old 01-18-2005, 01:31 PM   #8
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I am replacing the floor of our 68 Caravel, which originally had sprayed on insulation. A local restorer told me he had replaced many 68 floors that he believes were rotted out because of this spray on insulation, which prevented moisture from escaping the floor by sealing the bottom. So I'd avoid spraying anything on that would seal the wood from below.
Rich, is that the bathroom end of your Caravel?
Stephanie
Old 01-18-2005, 02:01 PM   #9
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I am debating if I will even put any back. Most of my camping with be in warm weather. If I camp with it in the winter I'll be heading to the Keys to get Away from the cold.
I found that the insulation was trapping water between it and the frame and caused some rust. As a result I did not install it when I put the new floor in.
If I do put insulation back I will probably do something like Don did.That seems to be one of the best solutions I have seen to date. I will use spray foam where I need a air seal where pipes go through the floor. I have a relativly air/water tight floor because I put down linolium before the shell was put back on. The linoliom will form a gasket effect when I bolt down the inteerior components. The only place water will have access to the wood is holes for plumbing or the outside edge. The wood has also been treated on all sides with a marine Epoxy resin before it was installed.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 01-18-2005, 03:09 PM   #10
1973 31' Sovereign
Portland , Oregon
Images: 22
The approach that I am taking is perhaps more radical than most. I intend to put hot water radiant heating on top of my new Polyboard floor. I have come up with a scheme where I am going to put reflective foil insulation on top of the Polyboard and then add the radiant heating on top of that in such a way as to leave an air gap above most of the foil. Please refer to the attached sketch for details.
If I were not going to put radiant heating on top of the sub-floor I would still want to use foil insulation - but under the sub-floor. I would suspend it in some fashion so that it was at least 1/2" below the bottom of the subfloor so that there was an air gap (reflective foil works best with an air gap). If I were going to install it from below after the floor was in place then I think I would just add some narrow strips of Polyboard, foam or maybe even wood at the edges of the cavities and attach the foil to the bottom of the strips, perhaps with staples. If the belly pan was on and I wanted to install the insulation before the subfloor then I would think about adding some sort of strips of foam, wood or plastic along the sides of each cavity (attached with rivits or screws?) and attaching the foil from above - again perhaps with staples. Since I would be concerned about water collecting on top of the foil then I would consider punching a 1/4" diameter hole in the middle of each section of foil and fastening a screen mesh over it to allow drainage and prevent access by bugs.
In my opinion reflective foil would do a better job of insulation, will not provide a cozy home for mice to nest in, would be light weight and would not capture and hold moisture.
Thats my two cents (or is it more now with inflation?).
Malcolm
malconium is offline   Reply With Quote
Old 01-18-2005, 05:15 PM   #11
greg176's Avatar
I am also not going to put any insulation.My belly pan will be removable and if it is too cold I will add fiberglass later (or wear slippers).
Old 01-18-2005, 05:22 PM   #12
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Yep, that is. The front end looks pretty similar. We had extensive rot (worse than yours) in the front and battery compartment, some under the fridge, and some not-so-great replaced floor in the bathroom (prior owner). It all came out (2/3 of the total floor area).
The good news is that we had easy access to fix a lot of annoying little things and dents along the banana wrap, inspect and put POR-15 on the frame, run some new electric & gas lines, replace the umbilical (7-way) line, etc. If the fridge croaks I now have a new 110v and 12v line right to it for a modern 3-way fridge.
And best of all, that suspect spray-foam insulation is gone. Like you, I was wondering if it contributed to the rot problem, since it seemed to absorb moisture. Water gets up into the sub-floor area, no doubt about it, even with a good belly pan.
We also sealed all the cut edges of the new plywood with wood preservative, as well as the underside, FYI.
Old 01-18-2005, 05:38 PM   #13
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
That must have been a ton of work to get that fiberglass bathroom unit out of there. Good opportunity to run those extra wires though. I'm upgrading to a new fridge, and will have to find a way to get the wires over there.
I have discovered pink insulation in the front under the POs patch below the water tank. When I get more of the wood removed I'll be able to pull it out and see how it held up. If it looks good I might be going with that under the new floor, like you are using in the corners, Rich. I'll also be using POR-15 everywhere I can reach.
Stephanie
Old 01-18-2005, 06:12 PM   #14
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Oh no, it was quite easy. I just wrote a check.
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
Alternator Replacement Suggestions rdm Mechanics Corner - Engines, Transmission & More... 8 11-29-2002 06:49 AM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
Quebec campground suggestions rdm On The Road... 1 07-14-2002 04:34 AM
Ideas, suggestions, needs? ALANSD Forum Admin, News and Member Account Info 5 06-22-2002 09:21 PM
