Old 04-26-2010, 09:42 PM   #1
2008 28' International CCD
L.G. , Virginia
Insulation in the walls -- adhesive or no adhesive?
I have read and seen different photos of how the fiberglass is applied to the walls during Airstream assembly at the factory.
Several posts allude to the giant blankets of fiberglass being draped over the exterior frame and the exterior aluminum sheets riveted to the frame holding the insulation in place.
Others post and a factory video show a water based adhesive being sprayed to the inside of the exterior sheet and the fiberglass being adhered with the glue.
We have a 2008 Airstream and are wondering which method was used.
Thanks for any insight.
wrajr is offline   Reply With Quote
Old 04-27-2010, 01:38 AM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Without a thermal break on the ribs of any Airstream all the insulation in the world will not matter or how it is attached! Sorry again to raise this point it just sad for me that no one ask or seams to care! 60 to 70 percent of your heat or cooling goes from your inner to out skin though the ribs!!!!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 04-27-2010, 06:36 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Todd,
What would you recommend for the thermal break before we put the inner skins back on? A directly related question is, would the thermal break, just by being in between the inner skins and the rib, weaken the overall mono-structure of the shell?
Chris
Old 04-27-2010, 09:32 AM   #4
_
the o.p. has a modern stream.
there IS a thermal break on the ribs, under the outer skin.
they've been doing this for YEARs (more than 10)
__________
to the op
the info you have viewed or your interpretation of that info seems 2b mangled.
they've never hung the pink stuff then attached the outer shell to hold it.
a complete outer shell is attached to the floor/frame then takes a shower...
any sealant gaps are fixed from INSIDE at that time...
THEN the pink stuff is installed from INSIDE before the inner skin is attached.
and they don't spray any water based adhesive on the inside of the outer skin.
the pink stuff is stuffed into the spaces and held long enough for the inner skin to go up.
spray adhesives are used to attach the mouse fur or vinyl ceiling/wall treatments.
the spray goo is low on VOCs but i don't think the stuff is water based.
____________
perhaps you've seen pics of outer segment REPAIR/replacement
which might show skin being added over the existing insulation.
but that's a repair not original/new assembly.
the basic question seems to be "howz my stream built"
and the clearest way to understand that is a factory tour.
the a/s website used to include a picture/slide show of assembly
and there are/were threads here with pics from INSIDE the plant...
from the daze b4 cameras were banned....
cheers
2air'
Old 04-27-2010, 11:24 AM   #5
lynn's Avatar
The Thermal seperation (barrier) tape was added around 1994 when they changed how the shells were built.
lynn is offline   Reply With Quote
Old 04-27-2010, 11:30 AM   #6
_
yes that's it...
the UPright assembly jigs (for rib/skin assembly)
3 piece ribs, pushed OUT corners and 5 segment shells=thermal tape.
approaching 20 years of use.
cheers
2air'
Old 04-27-2010, 05:48 PM   #7
L.G. , Virginia
__________
to the op
____________
cheers
2air'
Many thanks for the explaination -- makes sense!
Old 04-27-2010, 08:43 PM   #8
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Sorry about the hijack, but what is this thermal barrier, how thick is it, and would it behoove me to install it on the inside of my frame before I put the inside skin back on?
Birdwell57 is offline   Reply With Quote
Old 04-27-2010, 09:08 PM   #9
_
Originally Posted by Birdwell57 View Post
Sorry about the hijack, but what is this thermal barrier...
the oem stuff is a double sticky butyl tape ~2 mm thick.
there are maybe dozens of threads on this issue some very recent (like this month) ...
with discussions about WHAT to use and HOW to apply it and IF it does much.
search the key terms it's all there.
http://www.airforums.com/forums/f46/...ide-63397.html
http://www.airforums.com/forums/f381...kin-60323.html
cheers
2air'
fiberglass, insulation
Which flooring adhesive? Anniedog Floor Finishes 1 09-18-2009 05:23 AM
Use of Construction Adhesive - Any Thoughts? Gael79 Cabinets, Counter Tops & Furnishings 4 05-19-2008 04:19 AM
Vinyl Floor Adhesive kevino Floor Finishes 5 05-11-2007 07:34 AM
door gasket adhesive Al Falcon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-09-2007 10:46 AM
Rubrail Adhesive and Repair Shepstream Clearcoat, Exterior Paint & Trim 3 08-09-2004 11:01 AM
