Old 08-23-2006, 06:45 AM   #1
1968 20' Globetrotter
1988 29' Excella
Jonesboro , Georgia
Insulation between floor and belly pan. What to use?
I've not seen too much discussion about types of insulation that can be used between the floor and belly pan of old trailers, like '68 Globetrotters. Any hints on material and installation?
Dan
68Glbtrotter is offline   Reply With Quote
Old 08-23-2006, 07:20 AM   #2
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Dan,
I seem to recall a thread months ago where several people were advocating the spray on insulation. This is the canned stuff that rapidly expands and you saw off the excess with a serrated blade. You can buy it at Lowes or Home Depot. I used some last week to seal some cracks around the exterior of my house. On the plus side if it gets wet it seems like it wouldn't be harmed and on the minus side if you have to get to your pipes later you'd need to chisel the stuff out of the way.
I can't find that thread in a search. Maybe someone else will chime in with their thoughts.
Scott
Moonshot is offline   Reply With Quote
Old 08-23-2006, 07:54 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I remember that most people advocate the use of the roll-type fiberglass insulation, as it won't turn into powder from the movement of the trailer while driving.
Old 08-23-2006, 09:02 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Ditto on overlander63's comments. During manufacture a wide unbacked fiberglass batt was laid over the frame before the plywood floor was installed. So you will note that the original fiberglass is pinched at any frame locations. I used stainless steel staples to reattach standard 16" fiberglass to the floors between outriggers when I had the banana wrap off my Argosy.
Experience in other threads has been that foam insulations turn to dust during towing movements. There really isn't any reason to get expensive with floor insulation for the same reason we put more insulation in our attics than our floors at home. The shell around you has much more influence on internal heating and cooling loads -- it has no thermal break and a scant 2" of fiberglass. The floor doesn't really pass much heat in or out.
One potential problem with spray-in foam would be loss of ventilation under the floor. This ventilation is important to retard moisture problems with wood, steel, etc. That is the very good reason your banana wrap & belly skin is loose fitted.
5 meter Langford Nahanni
Old 08-25-2006, 08:23 PM   #5
1973 31' Sovereign
Portland , Oregon
Images: 22
I am a fan of reflective foil insulation. I would suggest installing some of that to the bottom side of your floor. It would be best if you could install it at least 1/2" below the floor so that there is an air gap between the wood and the top of the foil. This can easily be done by using narrow strips of plywood or foam insulation board around the edges of each cavity. You can then either glue or staple the foil to the strips. I bought my foil from Lowes and the brand name is Reflectix. Check out the following thread for a lot of information ab out foil insulation:
http://www.airforums.com/forum...ods-14803.html
Malcolm
malconium is offline   Reply With Quote
Old 08-26-2006, 05:46 AM   #6
Over59's Avatar
Putnam , Connecticut
Images: 37
Going down the road in summer with the surface 100+++ degrees I suspect you get significant heating from the road. If you have the belly pan off consider foam sheets. I used 2". The complete set up is, painted the underside of the floor with nanoreflective paint, then under that double sided reflective 3/8 bubble wrap with random bubbles, airspace, foam board cut to fit very snug. Filled the ends with foam above the foam board.
Over59 is offline   Reply With Quote
Old 08-26-2006, 06:28 AM   #7
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I was just at the factory and can report that they are now using the reflective bubble type in place of fiberglass.
Michael
ArtStream is offline   Reply With Quote
Old 08-26-2006, 06:40 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Michael
Interesting. Is it just in the floor, or the walls, too? how is it attached? (air gap?) is it in conjuntion w/ solid foam or any other material?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 09-10-2006, 01:49 AM   #9
1959newbie's Avatar
Hill Country , Texas
Michael
Michael, are you out there somewhere? I also am interested in how the factory is using foil bubble-type insulation now.
Lynne
1959newbie is offline   Reply With Quote
Old 09-10-2006, 04:21 AM   #10
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
This stuff looks good http://www.insulation4less.com/highr_FfmF.asp
  • Is waterproof and non-absorbent.
  • Provides Class A/Class 1 fire rated protection.
  • Provides 19 DB Soundproofing.
  • Convenient flange tabs on sides.
  • Does not mildew or promote fungus growth.
  • Does not provide nesting for birds, rodents or insects.
  • Is safe for workers to use as there are no fibers to breath or cause skin irritation.
  • Has more insulation value than 6 inches of common mass insulation products.
  • Can be stapled, nailed, glued or sewn.
  • Easy to cut
  • Reflects 97% Radiant Heat
  • R-14.5
$70 for a 4x25 piece.
'77 Sovereign Intl 31' CB
Old 09-10-2006, 11:46 AM   #11
1973 31' Sovereign
Portland , Oregon
Images: 22
Bob,
This does look like a pretty nice product. I do see, though, that they also sell foil-bubble-foil. The R-value is almost the same but the price is less for the bubble type. These guys provide free shipping to most of the 48 states too so that would be a good thing. I just looked up foil insulation at the Lowes website and their foil-bubble-foil looks to be cheaper for the 4'x25' roll at $48.67. This is about $0.49 per square foot. The larger foil-bubble-foil roll at the site you quoted is a much better deal though at about $0.27 per square foot. With free shipping that would be a good savings. Whether or not the larger roll will work for you depend on how much you need though. The floor area of my 31' unit is right around 200 square foot.
http://www.lowes.com/lowes/lkn?actio...l%20insulation
In my installation in the walls I don't actually use any staples so puncturing the bubbles is not really a problem. If you were going to install it under the floor then staples might be a good way to go. It would actually be better not to staple directly to the bottom of the floor though since this would not leave an air gap above the foil. From what I understand reflective foil insulation works best if there is an air gap on both sides of the foil. The side that is in direct contact with something will have a less effective reflective barrier. I think that this means that foil that is stapled to the bottom of the floor would be better at keeping heat out than it would be at keeping heat in.
There is a lot more information about foil insulation in the following thread. The specs for the type of foil available at Lowes and Home depot are available there.
http://www.airforums.com/forum...+insulation%22
Malcolm
Old 09-10-2006, 12:30 PM   #12
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
From above link -
A longer roll length (7 X) reduces price to $34 for 4x25 roll, with $237 total price (500sq ft) that includes shipping... so it is VERY competitive price as compared to reflectix type wrap from Home-depot, etc.. (reflectix $37.95 x 7 = $265.65 plus tax $284.25)
I have my twenty-seven foot Airstream belly 60% off and am pondering using the foam core type - for rigid foam board to meet the R-14 value I'm looking at .80¢ sq ft vs. .47¢ sq ft for the PRODEX Foil-Foam-Foil type...
Anyone care to check my math? The Prodex R-14.5 figure adds about R-2.5 value over the reflectix in best-case testing comparison..
Thank you Lipets, good timely link!!!
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 09-10-2006, 01:48 PM   #13
Wabbiteer's Avatar
1972 29' Ambassador
eek! Typo found after edit window expired - bulk roll purchase is 4'x175' so 700 sq foot coverage... I am ordering this tonight...
Old 09-10-2006, 02:30 PM   #14
_
Originally Posted by 68Glbtrotter
I've not seen too much discussion about types of insulation that can be used between the floor and belly pan of old trailers, like '68 Globetrotters. Any hints on material and installation?Thanks,Dan
hi dan
a review of several of the body off restoration threads will reveal how each fixeruper has done the floor insulation.
i've read bubble foil, fiberglass and a few foam... blown or sheet.
currently the factory is using bubble foil in the floors as artlink reports...
here is link to a photo as proof...post 14.
http://www.airforums.com/forum...ble+foil+photo
there are issues regarding ventilation and fixing it to the walls but the restortion threads usually cover these things
i've also looked at some professional rehabs...some fiberglass, some foil...only occasionally blown foam...
cheers
2air'
