Old 10-27-2014, 10:11 AM   #1
Installing Wood Planks
Hello,
I'm wanting to instal 9 inch wide pine planks for my flooring. Does anyone have advice on doing so? Is it necessary to use glue or is just nailing the planks down onto the plywood subfloor sufficient? What's the likely-hood of the floors moving and buckling after moving it?
Trixella is offline   Reply With Quote
Old 10-27-2014, 11:03 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I don't jump at the idea but how about some more info.
Trailer, plank thickness, tongue and grove or not, and condition of sub floor.
My first reaction was the weight my second was whether it should be installed as a floating floor
2004 Excursion 4x4
Old 10-27-2014, 11:21 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You need room for expansion as the wood gets hot & cold and dry and wet from the atmosphere...Gluing it down might not be the best as it could buckle and warp.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-28-2014, 06:06 PM   #4
It's a gutted 1968 Streamline, the pine planks are tongue and grove I believe, and the subfloor is new 1/2 inch plywood (not marine grade). I think the wood planks are about 3/4 inch thick.
I had a contractor tell me today that I should only staple the wood planks around the edges and let the rest just be held together with the tongue and grove.
Old 10-28-2014, 06:14 PM   #5
Mixter's Avatar
1976 27' Overlander
I'm interested in the responses too....
When I bought my trailer, the PO had glued down square tiles. They aged very badly and were a mess to clean up. (this was long before I ultimately lifted the shell and installed all new plywood subfloor on my new frame)
Based on how the stuff aged, and the mess to clean, I decided I would use the pre-finished real wood, tongue & groove flooring and nail it down with this: 2-in-1 Flooring Nailer/Stapler
I will leave expansion joint around the perimeter and cover with shoe molding or similar. My thoughts are that if I ever get a leak and the subfloor gets wet, the real wood would help dissipate and dry out, rather than stay moist under the foam used in a floating floor.
I also think that if I ever have to rip up a section of floor, I can sacrifice one of the tongues on the planks and pull up a section and be able to replace it just as easily...
Just my thoughts on the way I'm going to go, unless I hear an idea I like better.
Mic
Mixter is offline   Reply With Quote
Old 10-28-2014, 06:18 PM   #6
Mixter's Avatar
1976 27' Overlander
Looks like we posted same time...
Yes, one of my first concerns was weight, but I'm not so sure theres a huge difference between several boxes of vinyl tiles, or a roll of carpet, or the other manufactured products, versus wood. Just cant think theres that much difference.
I also think the contractor gave you advice I will likely follow as well. Although I dont think I'll rely solely on the tongue & goove, but rather take that as I wont use a ton of nails.
Old 10-28-2014, 07:28 PM   #7
Did you use marine grade plywood for your sub floors? I'm a little concerned about mine not being marine grade.
Old 10-28-2014, 07:49 PM   #8
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Nail or staple around the edges let the rest float. Would not worry about expansion after all you are installing wood on wood. They both will expand any difference will be so small it won't matter. The aluminum will expanded more than the wood with hot and cool. Would not run all the way to the wall inside cabinets in case of a leak.
thehandyman is offline   Reply With Quote
Old 10-28-2014, 07:58 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well, the floor is not where you should 'scrimp'. This is integral to trailer longevity. You did not say what plywood you DID use... the 'difference' can be immense. Plywood 'voids' in lots of 'construction' grades can cause issues. The Marine stuff should be of a grade that has less/no 'voids'... can you build out of cheap CDX grade? Sure.. but don't expect decent results.
Next is water... Marine grade is still 'wood'.. it will swell WHEN it gets wet.. yes, it will get wet.... plan on it. So, If you have used a lesser grade, all may not be lost.. if you impregnate with epoxy or fiberglass you will have 'waterproof'...and increase strength...
When doing these 'mods' you also add WEIGHT.... be prepared.. it adds up quickly!
We installed 'engineered' snap together flooring from Lumber Liquidators. it is NOT nailed ANYWHERE.. it is not glued either. However, I did 'trim' and fit each piece on the edges very carefully. There was 1/8' to 3/16 around the perimeter.. I then installed 'quarter round' and actually GLUED it to the walls and vertical cabinet areas... flush with the floor. The floor can 'float'... the snap together edges are impervious to dirt and have NOT moved. The flooring cam with a thin foam 'backing' and it has enough friction there is no discernible movement...
Also, I think it is lighter than your Pine you are considering. So, rethink this... you may be better off with a manufactured floor.. like ours, but, hey, it is YOUR trailer... have fun!!!
oh.. no, do NOT nail or screw them down. you might glue them to each other, but not to the floor.. just my $.02
I am in Round Rock.. you can come see what we did anytime... Pics can be sent, too. just PM.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-28-2014, 08:29 PM   #10
I'm not sure what grade of plywood the PO used. As far as the extra weight... my trailer is completely gutted, no cabinets, no walls, no bathroom... the only interior weight will be the floors so I think I'm okay on the weight front. This trailer is going to be a stationary (will have to move once to location) hair salon, the only other weight will be a couple of styling chairs and one shampoo bowl/chair put in after the move.
Old 10-28-2014, 08:37 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
ah.. well, if that is your end goal, no 'standard trailer plumbing', etc, no 'movement'.. I would still go with the engineered, snap together stuff. When you try to sweep the hair and other products from between the cracks you will soon go crazy.
I would pour epoxy all over the floor, paying special attention to the perimeter to 'seal' the wood as best you can from the leaks you will have from the trailer seams and rivets.
Then install the plumbing... epoxy around the cutouts in the floor... then install the flooring.
Also, this may be a good time to discuss how to 'mount' a chair to the 'floor'.. you will have a lot of flex unless you beef up where the chair will mount... this alone will cause some 'working' of the plywood and more leaking potential.
Good luck.
Channing
WBCCI# 30676
Old 10-28-2014, 08:47 PM   #12
Do you have a recommendation for an epoxy? I've never used it before.
Old 10-28-2014, 09:08 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Since you won't be moving the trailer, you can get some around Austin... One place, although more expensive will be West Marine on SW corner of Burnet and 183.
Of course, you could just use the recommendations above... and save a ton of $$$ .. then in the future, if this is lucrative, do a frame up restore and retrofit to your exact needs.
Channing
WBCCI# 30676
Old 10-29-2014, 05:54 AM   #14
Wayward's Avatar
Cary , North Carolina
I have put pine T&G flooring into lots of homes. I have white pine T&G in our master bath. So here are my thoughts.
- For wet or moisture prone environments like a trailer, pre-finish the tongue, groove and both sides before installing. Pre-finish all ends after cutting. Sand and put a final finish coat on after installation. Do this and it will hold up to water and moisture.
- If you are painting it, knots will bleed through so pre-prime just the knots with a shellac based primer like BIN. (Shellac not recommended as whole board primer in moisture prone areas)
- For the trailer attach directly to the subfloor - no moisture barrier.
- Narrow width trailer so a 1/4" gap on each side is enough. 1/8" gap at ends.
- Use a good oil based floor paint or polyurethane finish
- White pine is easy to work with and inexpensive. It is soft and will accumulate slight indentions from normal wear. Some think this adds character - it is just a matter of taste.
- Yellow pine or heart pine is more dent resistant but harder to stain.
- You probably will not be happy floating a 3/4" wood floor. It will not sit completely flat.
- Use galvanized nails/screws to handle moisture in trailer.
- Avoid nailing past the bottom of the subfloor. Blind nail with a 15g or 16g finish nailer (or hand nail and counter sink with brads). Consider the nailing angle and subfloor thickness when choosing your nail length. Do not use standard T&G flooring nails with the 1/2" subfloor.
- When you need to face nail, consider using a countersunk screw instead. That way you can control depth. You can putty or plug them.
- Pine does not have T&G on the ends so you will have to biscuit or face nail/ screw the ends and the edge boards anyway so consider face screws with plugs on the entire job instead of blind nailing.
- Especially for wide plank, look for quarter sawn or buy where you can hand pick your boards to avoid the regular face sawn. This will minimize cupping on a wide plank floor
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Allure sticky side planks Silverflames Floor Finishes 41 12-30-2013 03:53 PM
Allure Trafficmaster Vinyl Planks hippiechick Floor Finishes 53 06-09-2013 09:11 PM
Replacing fake wood with real wood webspinner General Interior Topics 65 04-03-2013 09:13 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
