Old 11-01-2014, 07:10 AM   #29
Wayward's Avatar
Cary , North Carolina
Treat with borate first.
Originally Posted by Trixella View Post
Can I just use something like Thompson's Water Seal for sealing the plywood?
Before painting or waterproofing, treat with borate. Also known as Borax it is a safe mineral solution that will prevent any wood rot fungus should you have a leak in the future. I use it for termite and wood rot protection on remodeling projects.
Bora-care is a commercial supplier which is particularly good when there is existing fungus.. Builders » Nisus Corp
Another is Tim-Bor - easy to mis powder for new wood. Amazon.com : Tim-bor Professional Insecticide and Fungicide, 1.5 lb. bag : Insect Repellents : Patio, Lawn & Garden
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-01-2014, 07:24 AM   #30
Wayward's Avatar
The PO layed the plywood pretty tightly against the walls in spots... is there a tool I can use to shave those spots down without having to uninstall the plywood? It's tight mainly around the corners.
Is your concern having an expansion gap for the plywood subfloor? If so, it is not nearly as critical for the plywood as it is to have the gap with the finish floor.
Wood expands from humidity across the grain not with the grain. That is why your flooring needs a gap on the sides but not the ends. Plywood layers are glued up with the grain running against each other, controlling expansion.
If it is already lifting up or otherwise concerns you, you could carefully chip it out with a wood chisel , a small oscillating saw, or a small rotary blade on a dremel tool.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-01-2014, 08:06 AM   #31
millertimeUS's Avatar
1976 25' Tradewind
Great advice on the Tim-bor I have a new plywood subfloor on my 76' definitely going to treat with this everywhere prior to painting floor with an oil based floor paint. Any need to prime subfloor? I saw another poster say they did, but would adhesion really be a factor?
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 11-01-2014, 09:23 AM   #32
Wayward's Avatar
Originally Posted by millertimeUS View Post
....painting floor with an oil based floor paint. Any need to prime subfloor?
If you plan for your finished floor to be oil based paint then using an oil based primer and sanding between coats is best.
If you are painting the subfloor to seal and shed any water leaks before putting down the finish floor, one or two coats of oil or water based primer should do the trick.
Soak it well and for plywood, try to treat the edges. As soon as the one coat has soaked in - add another until it will not take anymore. If you want to paint, let it dry out well.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-01-2014, 09:49 AM   #33
Originally Posted by cwf View Post
The sooner you get the siliconr ne off the better. Mineral spirits may help too.
I just picked up a tube of Parbond. After I pick the silicone out and clean it with mineral spirits, do I need to wash the mineral spirits off the surface with something like alcohol so the parbond will adhere?
Trixella is offline   Reply With Quote
Old 11-01-2014, 10:00 AM   #34
I'd like to know the answer to this question too.
Old 11-01-2014, 10:03 AM   #35
As far as your flooring goes. I'm a cabinetmaker who loves wood and still bought a real wood veneered engineered flooring with a cork backing. It was a breeze to install as it clicked locked together. I floated the floor for ease of repair or replacement.
I have seen a 3/4 solid floor installed in an Airstream with screws and plugs. The flooring heaved, broke screws, buckled, pulling screws out of the subfloor and ended up a stained mildewed mess. Pine, especially 3/4" will expand significantly if not sealed. Also you MUST seal both sides the very same way as finish on one side and not the other will cause the wood to cup big time. I personally would not use solid wood in a trailer floor.
I really like the look of the wide wood planks and the price point is really good but I'm beginning to reconsider paying 3 to 4 times as much for an engineered floating floor. Hmmm.
Old 11-01-2014, 10:29 AM   #36
1976 25' Tradewind
Awesome wayward thanks for the info. Would a water based primer hold up to foot traffic as well as oil until I get finish floor in. Might be quite a while.
Matt
Old 11-01-2014, 02:22 PM   #37
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I don't recall if the original poster was planning on using a pre-finished wood floor or the traditional flooring requiring sanding/ finishing. I think the ease of the engineered floating floors available would offset the fuss and mess of the sanding & finishing process. The fact that they have much less expansion & contraction is another big plus. Our first and older AS had a floating cork floor that was good looking and nice to walk on but if doing it again I think I'd go engineered wood of some kind.
Whichever way you choose, good luck with it. I'm sure the end result will look great.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-03-2014, 05:16 AM   #38
Wayward's Avatar
Yes. Use two coats then.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-03-2014, 05:32 AM   #39
Wayward's Avatar
Good points. Trixella seems to like the look and price of unfinished pine wide planks.
The white pine and yellow pine flooring I use comes sanded very smooth, and the wide planks in 8 foot lengths minimize joints, so final sanding is a breeze.
For an application like this, the boards can even be lightly sanded, stained/primed and finished with one coat before installation. Then a light sanding and one or two finish coats after installation.
Engineered floors have advantages too, nail, glued or floated. In an Airstream or other moisture prone environments I like to seal the bottom and edges. That is time consuming with prefinished floor to avoid messing up the finished side.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-03-2014, 06:18 AM   #40
I've decided to do a floating cork floor. I can seal the edges and bottom with a matte water based polyrurethane. The clear matte wouldn't show up if a little did get on to the top side.
Old 11-03-2014, 10:25 AM   #41
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
cork is great .. I used it in my prior trailer. In this one I have vinyl cork planking, it look s great too and has very low maintenance.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-06-2014, 05:49 PM   #42
Do you sprinkle it on the surface of the wood in its powder form or do you apply it another way?
Allure sticky side planks Silverflames Floor Finishes 41 12-30-2013 03:53 PM
Allure Trafficmaster Vinyl Planks hippiechick Floor Finishes 53 06-09-2013 09:11 PM
Replacing fake wood with real wood webspinner General Interior Topics 65 04-03-2013 09:13 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
