Old 01-15-2011, 07:38 PM   #1
StPierre's Avatar
1965 22' Safari
Rescue , California
Installing new sub-floor
We are making the brackets for the gray and black holding tanks now. The next step will be installing the new sub-floor. Can anyone give me an idea of how many elevator bolts might be need for a 22' 1965 Safari?
Thanks for the help, again!
The St Pierre's
StPierre is offline   Reply With Quote
Old 01-15-2011, 08:06 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Ummmmm, lets see. For our 31 ft, we used 75 bolts approx.
What do your brackets look like? How did you fabricate them? Do you have pictures? What did you use for grey tanks? We're heading into that territory in the summer, so we're interested!
Kay
Old 01-17-2011, 11:16 PM   #3
StPierre's Avatar
1965 22' Safari
Rescue , California
Kay,
Thanks for the information on the elevator bolts. For the gray tank we used Ronco Plastics tank #17H, 25 gal. I am installing the tank behind the rear axel, keeping all of the plumbing inside the kitchen sink cabinet. The brackets will be 1 1/2" angel iron bolted to the frame. Sorry we don't have any picture yet. We will take some when we get the brackets made and the tank installed.
We are using Ronco tank #18H for the black tank as recommended by Uwe who owns Area 63. Shelly at Ronco was really great to work with.
Maurice
The St Pierre's
Old 01-27-2011, 09:25 PM   #4
StPierre's Avatar
1965 22' Safari
Rescue , California
Gray Tank Pictures
We just installed the gray tank. I made the brackets out of 1 1/2" angle iron, and bolted the brackets to the frame. I then dropped the tank in. The vent pipe and inlet will be inside the kitchen cabinet. Not a hard job at all and can be done with the floor in place.
Now onto installing the new subfloor!
Name:	gray tank frame.JPG
ID:	120260   Click image for larger version
Name:	Gray tank inplace.JPG
The St Pierre's
Old 01-29-2011, 10:36 AM   #5
Minno's Avatar
1972 31' Sovereign
Looks good! Our subfloor is in place so we'll be working from underneath. Chris is going to try his hand at fabricating grey water tanks out of plastic using a plastic welding kit. It's on back order currently, so he's in a holding pattern. We can reuse our black water tank, and bought a new fresh water tank since ours is grungy to the point of no longer safe.
The subfloor is very satisfying to get into place - starts looking like a trailer again!
Spring, Spring, where are you!!?????!!
Kay
elevator bolts, floor repair
The old girl needs new shoes.... Trex 1970 - 1973 Sovereign 1160 03-04-2017 11:39 AM
Installing Propane light lucymcdog LP Gas, Piping, Tanks & Regulators 69 01-23-2011 12:12 AM
What's this hole in my floor? MonaxLisa General Interior Topics 4 01-12-2011 11:52 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 08:21 PM
Interior panel removal...floor access PA BAMBI II Repairing/Replacing Floor &/or Frame 1 01-03-2011 02:13 PM
