Old 08-25-2014, 10:50 PM   #15
Trottinon
Cncampers's Avatar
1962 19' Globetrotter
Maplewood , Minnesota
Installing insulation ABOVE the subfloor
We have used our trailer in the MN winter (never above freezing while we were out). There was a big difference in the floor temps between the back of the trailer where the insulation had been removed along with the plumbing compared to the middle and front of the trailer. We plan on insulating below the floor. Product yet to be determined. I recall reading that the Forbo Marmoleum Click has insulating properties. Can't recall if there was an R value. Window treatments are another thing that we factor in for winter use. A lot of heat escapes through the glass. Discussed that we might try some bubble wrap over the windows on our next winter trip. That would let in light and provide insulation. The options are endless. It all depends on how and where you use your trailer.
Nancy
Cncampers is offline   Reply With Quote
Subfloor insulation--Ick! Zeppelinium Repairing/Replacing Floor &/or Frame 1 11-30-2012 07:01 AM
Bubble Foil Insulation Between Frame and Subfloor ASNomads Repairing/Replacing Floor &/or Frame 5 10-25-2012 08:55 AM
New water lines above or below subfloor? DearArgosy Plumbing - Systems & Fixtures 3 03-19-2012 03:54 AM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
holding tanks above subfloor? photocodo Plumbing - Systems & Fixtures 10 10-04-2009 07:56 PM
