Old 01-06-2016, 08:40 AM   #15
GuitarmanFL's Avatar
1972 27' Overlander
Orlando , Florida
Explanation...
Originally Posted by rugjenkins View Post
I resemble the hillbilly alabama remark- I am one�� then again redneck engineer might be better
Hi Rugjenkins....
I'm from Alabama too...
GuitarmanFL is offline   Reply With Quote
Old 03-20-2016, 08:40 AM   #16
Tbeck11931's Avatar
1990 34' Limited
2013 23' FB Flying Cloud
Conroe , Texas
Gantry method s the best using one in the front and one in the back.
Chain hoist and lift through the fan and AC openings in the roof lifting up from a 4x4 beam placed lengthwise inside the camper.
Before lifting You can also place a few 1x4" secured diagonally inside across the camper shell for stiffeners.
The shell is stronger than you may think it is being of monocoque construction. Always look out for that one overlooked bolt or fastener during lifting.
Tbeck11931 is offline   Reply With Quote
Old 04-14-2016, 09:04 PM   #17
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
I did my shell off with bottle jacks and 4x4's as well. I used 10' 4x4's so they extended past the shell and I could jack from outside. One on the furthest forward rib and one on the back. I used galvanized metal and self tapping screws for my belly pan so it was very easy from underneath. The holding tank galvanized metal outlasted the aluminum belly pan by far so it seemed logical. Gantries would have been easier but I am impatient and spending a day building gantries seemed like too much work for something I would never need again.
AlbertaBound is offline   Reply With Quote
Old 04-14-2016, 09:45 PM   #18
1975 Argosy 26
Tulsa , Oklahoma
I'm doing my restoration with the Frame On on my Argosy 26', as I was worried I'd end up with a leaky shell if I took the Shell Off. It's still a work in progress but I've almost got the frame cleaned up and floor back in (It's partially installed).
Now that I've removed the interior, the floor, the pan, the belly wraps, removed rust on floor, replaced plywood in a c-channel compressed by the shell's weight etc, I wish I'd taken the shell off. If I had the shell off, it would have been so easy to bead blast the frame, flip to remove the pan etc...Still a lot of work, but I have to think it would have been less work than the way I did it.
You can do it with the shell still on, but it is a royal pain in the keister. If there ever is a 'next time', I'll be building a gantry and lifting the shell off.
DDOK is offline   Reply With Quote
Old 04-15-2016, 06:44 AM   #19
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
And then when you are done with the lift, the frame flip and work, etc., and the shell reattachment, you can use the gantries as scaffolding for replacing the air conditioner and all the miscellaneous roof work.
youngpeck is offline   Reply With Quote
Jack vs Gantry-shell lift gronlampa Repairing/Replacing Floor &/or Frame 9 11-07-2015 09:07 PM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Shell lift question daved20319 Repairing/Replacing Floor &/or Frame 1 01-27-2015 10:31 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Shell lift off question sawdawg1 Repairing/Replacing Floor &/or Frame 6 01-29-2012 07:03 PM
