07-07-2011, 06:29 PM
1973 23' Safari
New Albany
, Indiana
If you only had 5 instructions for your frame welder what would they be?
I have found a 73 year old man in the neighborhood who has been welding for 40 yrs. He works mainly with small time race cars and the like, and can weld trailers but has never dealt with an AS. He said he can do it no prob but the work will be done on a gravel driveway which looks level. any input appreciated.
07-07-2011, 07:17 PM
OO
, OO
Where is then the problem? I would be glad, according to a man in the neighborhood to have!
07-07-2011, 07:31 PM
1973 23' Safari
New Albany
, Indiana
no problem, i just want to make sure that he knows how precise certain aspects need to be! i have read about being perfectly level and you cant be off 1/4" here or there. i just want to make sure I use the right welder bc there are 100 of the around Louisville looking for work! There is even a welding school that will do it for pennies for a class project!
07-07-2011, 07:46 PM
x
XXXX
, XXXX
Benny a welder of 40 yrs will know to tack everything in place first. Check for square and level before final welding. He will also know that stitch welding long seams is actually better than one long continous weld. I myself don't know much about welding but listened to the guy who welded mine. He actually built the new frame upside down on top of the old one. Once it was altogether we flipped it over and placed spacers between the two and added the axle plates and the kick plates at the rear, then the tank supports were done using the tank pans to check for clearances.
07-07-2011, 10:38 PM
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck
, North Dakota
Send him to ND when you are done with him. We could use a few hundred or so welders. Starting first with our project of course.
07-08-2011, 08:47 AM
1974 31' Excella 500
Charleston
, South Carolina
If he can weld a race car he can weld the chassis. There is nothing magically special about an Airstream chassis.
1) No drinking during work.
2) Must have a helper.
3) Trailer must be level and square.
4) Old chassis is pattern. No improvising without prior agreement.
5) There is no rush. Take your time, but make steady progress.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
07-08-2011, 02:53 PM
1973 23' Safari
New Albany
, Indiana
I forgot to mention that he said he would fab the crossmembers and outriggers. I am a little leary on that! I know I would at least have to buy the outriggers for the steps. any opinions on making your own crossmembers and outriggers?
07-08-2011, 03:02 PM
Corpus Christi
It may be worthwhile to talk to some of his customers, especially any who had him do trailer work.
So Long!
07-08-2011, 03:04 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
I say if he has 40 yrs. and a pattern,he can make about anything.On my 63 I fabed the cross members,so the tanks would fit where I wanted,and I am a plumber,though I did learn to weld at an early age. Dave
07-08-2011, 03:09 PM
x
XXXX
, XXXX
Benny the price of the outriggers is so cheap I doubt that he can fabricate them any cheaper. As far as the crossmembers are concerned the ones I bought were all too short and I had to box in the frame to use them so for the rest we just made them ourselves.
07-08-2011, 08:58 PM
Charleston
, South Carolina
On mine I replaced the thin 5 inch C channel with 5 inch C channel 6.7 lbs per foot type.
I looked at the cross members and outriggers and they looked to me like they were of the same type so I just used the same C channel for the cross members and to make the outriggers. Less hassle for me.
The guys that did it were able to cut the slits for the steps into the outriggers.
- Andrew Carnegie
07-09-2011, 07:58 AM
1976 31' Sovereign
Greenwood
, South Carolina
I ordered outriggers and fabricated crossmembers out of the same box tubing as the main rails. Set up a time frame for the job to be completed. The guy that welded my frame said 1 week and took 4 months, which put this entire camping season out of reach.
07-16-2011, 10:13 AM
Tool Hoarder
West
Ha I did most of the welding myself. make sure that the guy is meticulous measure twice cut once make sure everything is square. Buy the outriggers waaaay cheaper than fabrication.
07-16-2011, 10:35 AM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
This guy is probably better than most pros today.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
07-22-2011, 01:28 PM
Sunset Beach
, North Carolina
Has anyone used 1.5" X 1.5" X 1/8" angle to make crossmembers? I was planning to use one across the top of the c channel and one across the bottom, with a couple vertical pieces to reduce the deflection of the top piece when walked on. I see outriggers @ $20 ea. I am thinking 14 3/4" 1.5" angle, and a piece of cut and bent 14 ga. steel underneath to complete the profile.
07-22-2011, 01:47 PM
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
For a time example, it took me 6.5 hrs to fit and tack weld everything , 5 hrs to go back and seam weld everything , 1.5 hrs to install / weld axles . 13 hrs fab for a complete towable frame.
If it takes months they are screwing you over.
07-25-2011, 07:23 PM
1976 31' Sovereign
Greenwood
, South Carolina
Your telling me, not even a kiss. To top it off the rear crossmember was made too wide , top to bottom, and welded in 1 inch out of place. Then he wouldn't fix it, I had to take it to another welder to do that. Needless to say I was not a happy camper.
07-26-2011, 05:38 AM
Baltimore
, Maryland
I think the best thing you can do is keep his beer cold and stay out of the way. This is not rocket science.
The biggest mistake I think most people make is to make a frame that is too stiff. Most think it needs to be beefed up and that is not what should happen. The frame needs to flex as it goes down the road. Just copy what is there and it will turn out perfect.
