Old 02-08-2014, 05:11 AM   #1
1968 26' Overlander
Chattanooga , Tennessee
If modern plywood is thinner ...
The original floor in my 68 Overlander was true 3/4 inch. The 3/4 exterior ply I'm using in my shell-off replacement is a bit thinner. Does this matter when dropping the shell back on?
In particular I'm wondering about the front hold-down plate where the rivet holes will be a fraction off from the holes on the shell...
Sardine is offline   Reply With Quote
Old 02-08-2014, 06:21 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Nope, doesn't matter. You'll have to re-drill to suit, but you'd likely have had to do that anyway even if the new plywood was exactly 3/4". We've done numerous "body off" / "rotisserie " restorations & this is normal.
Good luck,
Colin
Colin H is offline   Reply With Quote
Old 02-09-2014, 06:07 AM   #3
1968 26' Overlander
is it okay if re-drilling elongates existing holes?
Colin - thanks for the answer.
As it sits now, re-drilling means elongating the existing holes on the skin or hold-down plate. (I guess elongating the holes larger on the plate is preferable to the skin?)
Seems I have a few options:
-Buck the elongated holes, and perhaps drill a new 3rd row for good measure to stop movement shearing the rivets.
-Shift the shell to one side 1/3" or so and make completely new holes on the plate.
-Re-drill everything about an 1/8(?) bigger and use a larger rivet
Thoughts?
Old 02-09-2014, 06:27 AM   #4
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Thoughts?
The original rivets had 1/8" diameter shaft, & replacement rivets from Vintage Trailer Supply can be either 1/8" or 5/32" diameter. We use 5/32" for almost everything, as the head is the same size as the originals. I would be very surprised if the holes are exactly 1/8 th offset everywhere, but if they are, you should use a scrap piece of aluminum on the inside as a "backer washer", then perhaps add another row though virgin material.
Colin
Old 02-09-2014, 07:01 AM   #5
1968 26' Overlander
Thanks Colin - that's just the information I needed.
What year did AS stop using plywood floors? t walgamuth Repairing/Replacing Floor &/or Frame 5 10-24-2011 04:44 AM
7.0 x 15 what is this in a modern tire? perryg114 Tires 7 09-14-2011 07:25 AM
2 layers of plywood? P&K Repairing/Replacing Floor &/or Frame 20 08-14-2011 08:15 AM
Removing 1" plywood under fresh tank bennyg Belly Pans & Banana Wraps 0 06-12-2011 02:50 PM
Aluminum Trim for Plywood Walls Motochi Upholstery, Blinds, Walls & Interior Finishes 7 02-06-2011 09:33 AM
