Old 03-28-2007, 07:22 PM   #1
1967 24' Tradewind
gilbert , South Carolina
I removed the rotted floor today!
I removed the rotted floor today in the 76 sovereign. I also removed a bunch of wall panels and the plastic end cap, to access some dents. I worked all day welding and repairing rusted out metal on the frame and I'm almost through with that section. I really got alot done today and enjoyed every bit,except the old insulation, that stuff makes me go into a coughing and sneezing fit. I was even suprised by the ease at which I popped out some dents. I've seen some of you putting in that foil insulation, could someone tell me what it is called and where I can get it. I've sent some pics of the floor and hope to send more soon.
ID:	34742   Click image for larger version
chris's 67 is offline   Reply With Quote
Old 03-28-2007, 07:38 PM   #2
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
I love the hat.... or new doo...
Congrats on the progress!!!
sequoiacoast is offline   Reply With Quote
Old 03-28-2007, 07:42 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Yikes!!!!!
The Coneheads Attack!!!! Good Lord the Welding Helmet Division!
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-28-2007, 09:56 PM   #4
1973 31' Sovereign
Portland , Oregon
Images: 22
Foils sources and details...
Check out the following thread for some detailed foil installation suggestions:
http://www.airforums.com/forum...cks-30196.html
I did not see any sources of the foil mentioned there so here are a couple notes about that:
I bought mine at Lowes and it is the Reflectix brand. Another source that I did not know about when I bought mine is:
Insulation 4 LESS
Their product is interesting in that the middle core is foam instead of air bubbles like the Reflectix foil. They also seem to sell in larger rolls so you would have to be a bit more carefull about figuring the amount you need. There prices may be cheaper. As I recall Reflectix foil is about 50 cents per square foot at Lowes in 4' x 25' rolls. Actually I just check the Lowes website and that is pretty close:
http://www.lowes.com/lowes/lkn?actio...&Ntt=reflectix
Hope this helps,
Malcolm
P.S. Congratulations on your fast progress with the floor.
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 03-28-2007, 10:58 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The foil bubble wrap will not dampen sound, the Insulation for less Foil-Foam-Foil does. I went for the large roll
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 03-31-2007, 12:23 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
foil insulation
Wabbiteer, Thanks for re-posting insulalation info. I am sending you some Karma for doing that... Ed
Old 03-31-2007, 12:31 PM   #7
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Chris, I've been there and done that. It's great to get all that old wood out. It's also great to know you are on your way to restoration. Please keep up posted with lots of pictures and your ideas as work toward completion.
Don
NorCal Bambi is offline   Reply With Quote
Old 03-31-2007, 01:39 PM   #8
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
floor out
I'll be the trailer smells a lot better now!
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Has anyone removed wall mirrors? Pahaska Cabinets, Counter Tops & Furnishings 5 08-14-2006 04:16 PM
Has any one just removed.... tyndalelady Upholstery, Blinds, Walls & Interior Finishes 4 01-26-2006 12:12 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
