Old 09-17-2014, 04:10 PM   #29
1981 31' Excella II
New Market , Alabama
How thick is the channel? I don't know why they did not use Square Tubing.
Perry
Old 09-17-2014, 04:55 PM   #30
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
3/16 channel boxed in from the front hold down back to bumper. It is added to and reinforced in the back for the grey tank. The out riggers are different they do not have the cut outs they are solid all the way across.
thehandyman is offline   Reply With Quote
Old 09-17-2014, 05:46 PM   #31
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
My photos wont post from ipad. Help anyone?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 09-17-2014, 05:46 PM   #32
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The Caravelle is a rare Airstream. They were built light so they could be towed with the 4 cylinder cars of the day as I read the 1980 Airstream brochure. But I would be scared to death of a 3" channel A frame. That's small utility trailer stuff.
Geez, my 66 was built with a 5" box channel A-frame. The rest of the frame is 5" C channel. The trailer weighs about 4100 lbs.
What did Airstream build the 07 19 footers with?
David
Name:	1312 Frame POR 15 A Frame.jpg
Old 09-17-2014, 07:15 PM   #33
1980 24' Caravelle
Stronger than you would think. Run about 600lb tounge weigh loaded. Is yours made with formed channel or structural channel?
Old 09-18-2014, 06:01 AM   #34
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The A frame on the 66 Trade Wind is 5' x 1.5" x 3/16 thick fabricated boxed channel. Tongue weight is about 440 lbs. I don't believe there is any situation I could create with my Reese WD hitch that would bend one of these frame members, other than a head on crash!
I had my trailer jacked up all last winter supported by jack stands under the left and right rear axle plates, and the tongue jack. Three points of support leaving the A frame and frame rails to support the weight of the trailer. I didn't detect any problem. I stood on the A frame while working on the front of the body. Seemed real solid.
I can't imagine a weight distribution bar bending an A frame member on a 07 Airstream. Just trying to understand what caused Sbb's damage.
David
Old 09-18-2014, 06:08 AM   #35
Gainesville , Florida
Has the trailer been dropped off the jack on a hard surface? Jim
Old 09-29-2014, 05:09 PM   #36
Sbb
begorragirl
Sbb's Avatar
All fixed, new airframe, one part ( frame) , many hours of labor. I am able to use same hitch, although slightly different hitch setup. Tomorrow car will be unloaded u til next May, it will be interesting to see if there is any difference.
2010 Funfinder
2005 T@B
Old 09-30-2014, 06:10 PM   #37
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I Bent My Frame
Did they replace the entire frame ?
If so, did they give you a bill to pay?
Old 09-30-2014, 08:27 PM   #38
Sbb
begorragirl
Sbb's Avatar
Why of course I get a bill, $3500.00. I now have 3/16 5" steel tube, they fiound a slight leak up front which was cleaned and sealed. A bonus for me. The dinette and more had to come out to do the work, because the frame was bolted from under my front floor.
2010 Funfinder
2005 T@B
Old 09-30-2014, 08:42 PM   #39
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I Bent My Frame
I didn't know for sure if it was a warrantee thing or not, and I was wondering if they replaced the entire frame, which would have seemed like overkill to me.
I see now that the trailer is an 06, but I hadn't looked at your profile till now.
I didn't want to come right out and say that if they charged you 10K to replace the entire frame...
And I didn't want to outright ask you how much the repair cost,,,, so I apologize for not expressing my curiosity forthright.
It sounds like you did pretty well by getting out for $3,500 though.
Old 10-03-2014, 12:55 PM   #40
2004 16' International CCD
Chicagoland , Illinois
Wow that is an expensive fix - still much cheaper than a new trailer... Nevertheless, considering the amount of time and materials that must have gone into the fix, I think that you got a pretty darn good deal.
Airrogant is offline   Reply With Quote
Old 10-03-2014, 03:53 PM   #41
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I expect you will be very happy with the trailer now. I had to have a new A frame at JC because of a rust problem. They did a fine job. More expensive than a local welding shop maybe but less chance of damaging something else in the trailer. You can think of yours as a true upgrade rather than just a repair.
A comment from Wally B. to someone who had a expensive problem to fix. "Airstreams are not cheap."
Frame bent, or normal? ROBERTSUNRUS Repairing/Replacing Floor &/or Frame 15 06-21-2010 11:18 PM
Bent Frame on 2005 22' Intl - How bad is it? JK3500 Repairing/Replacing Floor &/or Frame 37 09-24-2009 08:45 PM
Bent frame? c.zellermaye Repairing/Replacing Floor &/or Frame 5 08-25-2009 09:36 PM
Bent Frame: Need Advice thombrad Repairing/Replacing Floor &/or Frame 2 07-22-2009 03:35 PM
Bad axles, rough road, bent frame Lumatic Axles 0 05-21-2007 08:24 PM
