Old 09-21-2004, 10:13 PM   #1
wol
1974 27' Overlander
memphis , Tennessee
I am new a member and I have some questions
Ialso have floor rot in bath area. I have replaced the floor and sealed with rot dr. epoxy. I also have beefed up the frame with 4 inch channel from in front of axles to the rear of the trailer. I was wondering if I could add bigger holding tanks without a big headach. the trailer is a 74 overlander that was given to me, so i dont mind spending a little money on it. Everything on the trailer works or it did before i took a part. any help or informantion on any part of the trailer would be abig help thanks.
wol is offline   Reply With Quote
Old 09-21-2004, 11:58 PM   #2
1973 31' Sovereign
Portland , Oregon
Images: 22
You should be able to...
Depending on where your tanks are now you should be able to add bigger ones. If they are way in the back end you might want to consider adding bigger ones further forward if you can get the plumbing to work. That way you won't be adding a lot more weight too far back - which might unbalance the AS too much. The other thing to keep in mind is that you will either have to let the new tanks hang down below the belly pan to allow them to be bigger or mayby modify the frame cross members to allow them to be wider to get the increased capacity.
I suggest that you check out the following thread for some discussion about tanks and some sources where you can get them:
"Combined Gray and Black Water?"
Malcolm
malconium is offline   Reply With Quote
Old 09-22-2004, 12:08 AM   #3
gerbermania's Avatar
A few of us have added, or are in the process of adding, tanks.
I recommend doing a search on this forum for "grey tank" or "gray tank", this should yield some threads where additional tanks have been discussed at length.
Personally, I just completed a floor replacement, and I am now adding a new graytank underfloor.
Here is a sample thread: http://www.airforums.com/forum...light=greytank
and
http://www.airforums.com/forum...ight=gray+tank
Enjoy,
Christopher
gerbermania is offline   Reply With Quote
Old 09-22-2004, 08:35 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Christopher
Christopher,
What did you wind up using for a tank? custom, or pre-fab?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-22-2004, 09:36 PM   #5
wol
1974 27' Overlander
memphis , Tennessee
thank you Malcolm and Christopher for the threads this abig help. thanks billy
Old 09-22-2004, 09:47 PM   #6
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Oh, and by the way - wolcome to the forums.
bredlo is offline   Reply With Quote
Old 09-22-2004, 09:55 PM   #7
wol
1974 27' Overlander
memphis , Tennessee
hey brad thanks for the welcome. I thank a 8 gallon gray tank and 11 gallon black is just small for my wife my son and myself. this is why I was looking for bigger holding tanks billy
Old 09-22-2004, 10:17 PM   #8
2004 25' Safari
2019 25' Flying Cloud
South West , USA
8 gal. gray ?? If that's right it is small, real SMALL . BTW:Welcome to the forums & good luck with your project!
RivetED is offline   Reply With Quote
Member Titles, what do you think? Andy R Forum Admin, News and Member Account Info 17 08-18-2007 10:13 PM
Member reviews now available! Andy R Our Community 4 07-20-2002 11:34 AM
