Old 06-03-2015, 10:25 PM   #29
Fixxxer's Avatar
1967 24' Tradewind
Summerland , British Columbia
Still working on it , just so many little things that are time consuming! Had the body all riveted on but had a problem with the panels bulging when I was fitting the wheel wells. I had to drill out the rivets at the corners and add spacers to move the body back. live and learn, it has been challenging but also rewarding.! I know it will be nice when done!
Fixxxer is offline   Reply With Quote
Old 08-26-2015, 08:04 PM   #30
1960 24' Tradewind
Tipp City , Ohio
Gettin' ready to start Vegas Wedding resto
When you decided on the new frame, that looks great by the way, did you use the old one for the pattern? How did you determine the size of the material? What do you think the built up frame cost.
streaming24 is offline   Reply With Quote
Old 09-08-2015, 06:05 PM   #31
Fixxxer's Avatar
1967 24' Tradewind
I had the old frame right beside the new frame build, so I could copy it as much as possible but changed a few minor things.
I used a slightly thicker material but it was 2x5 tubing.
I priced it out and it was going to cost $3000 to get it built by a local shop. So I bought everything myself and only spent $1100!
