Old 12-13-2014, 06:25 AM   #15
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
Should the inner fender liners be under the floor? In other words install the fenders first then the floor. I noticed the great floor finish picture that there are no fender liners. I am just about ready to start installing my floor and fenders but i think mine were under the floor.
JCPOTTERF is offline   Reply With Quote
Old 12-13-2014, 07:07 AM   #16
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
On my 67 Caravel the wheel wells are sandwiched between the floor and the frame / outriggers.
Dingo Girl is online now   Reply With Quote
Old 12-13-2014, 07:25 AM   #17
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
On my 57 it's the same way. The flange on the wheel wells goes between the plywood and the frame
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 12-14-2014, 10:38 AM   #18
Fixxxer's Avatar
1967 24' Tradewind
Summerland , British Columbia
Part of my reasoning for building a new frame ,aside from the fact that it was rusted and falling apart, was to build a custom frame and floor to accomodate larger tires and wheels . So the wheel wells are to be custom as well.
I am planning on the kitchen cabinet to be supported by the wheel wells as well and they will be made of 3/4" plywood and lined with metal .
Fixxxer is offline   Reply With Quote
Old 01-18-2015, 09:52 PM   #19
Fixxxer's Avatar
1967 24' Tradewind
Not much accomplished with the holidays and then getting sick.
I must be a glutton for Airstreams,I mean punishment. I just picked up a 1968 Ambassador. It is mostly gutted and has the usual rear frame rust. I originally bought it for parts , but now that I have it home away from the patio that it was sitting next to,it actually looks better than I thought. I might sell it quick if anyone wants it , but I might start robbing parts off it.
/Users/gord/Pictures/iPhoto Library.photolibrary/Masters/2015/01/18/20150118-201221/P1030816.JPG
Old 01-22-2015, 10:32 PM   #20
Fixxxer's Avatar
1967 24' Tradewind
Anyone want to save the Ambassador before I rip it apart?
Old 01-22-2015, 10:51 PM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
for the inner fender... I would arrange so that it is 'removable' without disturbing the floor. In other words, they should be mounted from the outside of the AS interior. You can properly seal so that water has difficulty getting underneath and attack the frame or floor... AND, should you ever throw a shoe damaging the underside, you could remove the damaged fender from the wheel well area without tearing up inside the AS..
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-26-2015, 10:17 PM   #22
Fixxxer's Avatar
1967 24' Tradewind
I was just looking at the wheel wells this weekend trying to figure out what to do, but I like your plan! I will look closely at that before I proceed.
Old 02-02-2015, 12:41 PM   #23
GlamperGirl
Question for you on the insulation. I noticed you did one layer of 1' and it was on top of the frame. Then you placed the plywood on top. Is that what I am seeing? Why not two layers of the 1' and why not under the frame in between? Thank you!
thumbelinadj is offline   Reply With Quote
Old 02-04-2015, 10:01 PM   #24
Fixxxer's Avatar
1967 24' Tradewind
The insulation was cut to fit between the frame,so the floor is sitting on the frame. My tanks are going up into the frame and touching the insulation,I didn't want to lose another inch of space taken up by insulation. We won't be camping in the winter so Im not too worried about the floor being cooler in the summer.
Old 03-30-2015, 10:10 PM   #25
Fixxxer's Avatar
1967 24' Tradewind
A lot of small things to do that take up so much time! Finally have the 2 maxxair fans , and vent with maxxair cover on. Polished the roof in a few areas before I set them in.
I also de-anodized bunch of mouldings so I was able to polish them easily!
ID:	235261   Click image for larger version
Old 03-31-2015, 07:18 AM   #26
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Please explain the procedure for "de-anodizing" the moldings.
youngpeck is offline   Reply With Quote
Old 03-31-2015, 11:00 PM   #27
Fixxxer's Avatar
1967 24' Tradewind
I mixed 2 tablespoons Drano granules in 1 gallon of warm water and put it in a 1 1/2 " abs pipe capped off at one end. Insert the moulding and leave for a 1/2 hour or more ,then rinse of with a pressure washer. Be careful of the fumes and use rubber gloves when handling. I only had an 8ft piece of abs , but I did one end of the 14ft piece ,then flipped it end for end.
ID:	235339   Click image for larger version
Old 04-01-2015, 07:58 AM   #28
youngpeck's Avatar
1976 25' Caravanner
Very nice! I'll try it soon. Thanks much.
