Old 01-19-2012, 06:02 PM   #1
Eric Johansen
1976 31' Sovereign
San Francisco , California
How to waterproof new sub-floor?
What product do you recommend to waterproof a new plywood sub-floor?
Thanks, Eric
EricJohansen is offline   Reply With Quote
Old 01-19-2012, 06:17 PM   #2
2005 30' Classic
Images: 12
Not that any water-proofing is considered long term, but I used marine epoxy on my marine grade ply.
GetOutDoors is offline   Reply With Quote
Old 01-19-2012, 07:10 PM   #3
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
I used a product from Sanitred. It is a liquid rubber coating application. It has may different applications. i especially like the fact that it is used to make aquariums. The wood will be completely waterproof once the product is applied. Not water resisitent but water proof. It is very pricey though. I didn't mind the cost as I never want to need to repair my follr again.
DIY Wet Basement Waterproofing, Finishing & Flooring, Swimming Pool, Deck & Concrete Crack Repair, Roof & Industrial Floor Coating
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
wasagachris is offline   Reply With Quote
Old 01-19-2012, 07:34 PM   #4
Tool Hoarder
marzboy's Avatar
1965 30' Sovereign
West Hills , California
I used West systems epoxy around the edges of my MGP sub floor then used spar varnish on the rest
Behind every great man, there is a woman rolling her eyes.
My Airstream renovation and camping Blog
My frame and floor restoration thread
marzboy is offline   Reply With Quote
Old 01-19-2012, 09:32 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Hardware store epoxies may not be waterproof. Look for boatbuilder/marine epoxies. System Three and MAS are good; West System probably is a more expensive option.
When I re-did areas of floor on my Argosy, I used System Three on the plywood edges and six inches on top of the floor perimeter. And then I treated the rest of the floor-top (eg, under the water tank) with RotDoctor - a high-solvent penetrating epoxy (ventilate nothin' -- gotta do this with a lot of outside air circulation!). Don't count on System Three, MAS or West to penetrate. Encapsulating wood really is a vain pursuit -- moisture will still penetrate somewhere and then nothing can evaporate (resulting in accelerated rot). I left the underside of my floor untreated.
Marine epoxies can be dealt with in enclosed spaces. Nothing more than a slight ammonia smell. But be very good on glove wearing and wash any skin contact with un-set resins. Use respiratory protection if you power finish or power sand any epoxy treated area.
Time spent looking at window gaskets, roof penetrations & skin lap seams will be more important than going overboard on sealing the floor. Gotta take care of the 'they all leak' problem.
5 meter Langford Nahanni
Old 01-19-2012, 10:38 PM   #6
InsideOut's Avatar
1956 22' Safari
Edgewater , Colorado
Images: 94
Lightbulb Thinking ahead...
What kind of floorcovering will you be putting down? Some "glues" will not stick to the :waterproof" surfaces. If you are just laying carpet or something that isn't glue-down, no problem. If you plan on installing linoleum or tiles, you may want to think twice before applying a waterproofing material wall-to-wall.
Shari
RMVAC | WBCCI DenCO Unit | Tin Can Tourists | Sisters on the Fly | BIRDY - our '56 Safari
Old 01-20-2012, 06:59 AM   #7
1981 31' Excella II
Orlando , Florida
Polyurathane wood coating works well and it is relatively cheap. It is also waterproof assuming there are no holes in the coating or gaps. Edges are especially important that they are sealed. You want to seal any penetrations through the wood as well. If the floor stays wet long enough eventually water will penetrate through some pinhole or crack in the coating etc. Many so called fiberglass boats are just fiberglass coated wood. The wood rots in 10 or so years and you have a fiberglass egg shell where your boat use to be. The advice of coating the top and the edges and leaving the bottom bare is probably not a bad idea if there is nothing like pink fiberglass that is holding moisture against it. The bottom edges should be sealed for 2 or 3 inches from the edge though.
Perry
Old 01-20-2012, 07:13 AM   #8
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Another thought:
Look at Tnemic coatings. ( Tnemec Industrial Coatings and Architectural Coatings ) I have used this on concrete to waterproof the interior of an indoor water feature. I believe they have a product that will work on wood as well. It will be pricey but bulletproof.
A different option would be a peel-and-stick membrane variety. I have used a product called Proflex. Is a waterproofing membrane as well as a sound reducing mat. The primary application is for tile underlayment, however I have used it under wood floors in multiple applications with great success. PROFLEX? Products - Crack Suppression - Waterproofing - Sound Control - Membranes Underlayments
Casey
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 01-20-2012, 10:15 AM   #9
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I replaced the back sheet and then realized the whole floor had to go. I know, poor prior planning but I kept hoping to find where one gawd awful smell was coming from but even with bath, tanks, and all plumbing out it persisted.
I wasn't happy but I learned a couple of things that I'll share..
I used marine-grade plywood and put 4+ coats of vinyl-ester resin on before installing it. The first two coats were thinned and the wood was saturated to the point of rejection, I just kept washing it on until the soaking in slowed way down. Two more un-thinned coats and I though I was set.
Vinyl Ester resin is superior in every property as compared to all polyester resins. This product is used in high performance applications in which high-strength and maximum heat tolerance is necessary. This resin is extremely chemical resistant when cured. Similar in strength to epoxies with much increased stiffness.
Vinyl-ester is brittle - although it armored the surface the underlying wood yields and the VE cracks like rock-candy. When the wood grain shifted from moisture content the VE failed. See picture, the MGP on top of the pulled 40-year-old flooring.
The 8-ply the private lumberyard sold me was more furniture grade than construction grade. If you go MGP research the grades and symbol stamps and review the offerings available before you commit. The $85 sheet I got had a soft exterior ply and even softer internal plies - I had floor screws pull halfway through with little effort.
The new floor I just put in is a hardwood construction grade plywood (MDO) and I followed directions meant for outdoor advertising billboards: Fill any flaws w/ caulk and two (three in my case) coats water-based primer, then two top coats of outdoor porch paint. If you want to rubber-neck along with my slow-motion train wreck restoration look for a post "Hey y'all, watch this..."
If I were doing a back-sheet restoration again I'd seriously be tempted to use an epoxy resin that would allow thick build up, kinda like a surf board but that is just me.
ID:	149254   Click image for larger version
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 15 01-10-2012 08:12 AM
Floor replacement question: to do it right the first time! Eric H Repairing/Replacing Floor &/or Frame 7 12-06-2011 09:19 AM
Trying to decide on floor insulation or none at all perryg114 Repairing/Replacing Floor &/or Frame 1 09-20-2011 01:52 PM
No Factory Floor Covering Intrepid Repairing/Replacing Floor &/or Frame 2 09-20-2011 07:48 AM
Mismatch of floor and outrigger width MtnMDStan Repairing/Replacing Floor &/or Frame 3 06-19-2011 02:44 PM
