Old 01-24-2010, 12:44 PM   #1
1991 29' Excella
Cloverdale , British Columbia
How to replace floor in a 1991 29ft Excella?
Hello, We recently purchased a 1991 Excella and have discovered floor rot in the front and back and are wondering if anyone has any advice/tips on how to replace the rotted sections properly...I have read that the floor is part of the structural integrity so want to make sure that is properly supported but also don't want to replace the whole floor if it is not necessary as there is hardwood flooring that we are hoping to keep. Thanks in advance!
walden91 is offline   Reply With Quote
Old 01-24-2010, 12:51 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First off find the reason for the rot and fix that. Then find how extensive the rot is is. Yes you may have to remove any current hardwood flooring to determine this but it has to be done.
While the flooring is a part of the structure you can replace smaller sections without compromising the structure. You can only make that judgment once you have define the problem.
2004 Excursion 4x4
Old 01-26-2010, 09:04 PM   #3
1992 34' Excella
Joplin , Missouri
Hi. I am new to the forum. We just purchased a 92 34' Excella 1000 (also says airstream classic on the side). Before buying we did a fairly intense inspection and revealed some rot at the perimeter floor in the front to the left of the driver's side battery box, and to the right of the passanger side battery box as well as back behind the passanger side wheel well (accessed via the closet). The trailer had not been towed since the summer. Our only guess is that it is leaking at the seam on the outside of the trailer that runs around the perimeter of the trailer about floor height. Can anyone confirm this is a likely place and what the procedure is to fix this if this is in-fact the case? Thanks.
Woodhippie is offline   Reply With Quote
1991, floor repair
Excella 1991 29' Fritz 1990 - 1993 Excella 7 06-20-2018 06:45 PM
1991 OSB Floor repair question capehoorn General Interior Topics 2 06-11-2006 08:13 PM
1991 Excella 25' aeriqua Trailer Values 20 12-18-2005 09:08 PM
1991 34' Floor water damaged in rear. potatoes Repairing/Replacing Floor &/or Frame 11 06-03-2005 04:45 PM
