Old 03-25-2013, 08:50 PM   #29
bovk's Avatar
2011 20' Flying Cloud
Beaumont , Texas
I should not doubt you guys, you are way ahead of me! I will get some reference measurement away from the walls and the details of the ports show very nice work.
This is fascinating - the techniques you developed.
Let me try to sum it up: so far the contributors to this post described following methods to check the status of the floor:
- measuring plywood moisture content with meter, sensor points attached to the meter or detached for better reach. This is done from above, through the vinyl and / or aluminum
- permanent ports in the pan enabling inspection and installation of humidity detector in the pan, detector visible without opening the ports, ports allowing visual on rear area from below
- many (20) not covered holes in the pan to allow inspection via optical wand
- several larger openings for inspection and repair, later covered by aluminum sheet and self threaded screws
This is a good reference and starting point for detecting moisture in the floor plywood. If I am missing anything comment please.
bovk is offline   Reply With Quote
Old 09-17-2014, 04:40 PM   #30
bovk's Avatar
Beaumont , Texas
Water inspection around the perimeter of 2010-2015 20' FC
My 20' FC has 4 years and over 60k miles so I decided it is time for a more thorough inspection. Since I took a couple pictures i thought others may be interested seeing that on 20' FC it is possible to get nearly to the whole perimeter of the floor.
Starting from the hot water heater under the seat and going clockwise (CW) around the front perimeter I cut off about 6" of the vinyl cover around the walls. I do not think it is needed there and its removal makes water measurement easier. I could get all the way around the front of the trailer to the inside of the compartments on the front edge of the door.
From the water heater going CCW I could get close to the wall between the seats removing the channel cover between the seats. Removing the left seat top does not help much because it is difficult to get to the floor so i took measurements as close I could around. From the bathroom I could get somewhat to the space behind the wheel by removing the metal cover behind the toilet. The space between the wheel and the shower is nearly impossible to check. I could get under the shower by unscrewing the the inspection plate under the shower door. Now I switched to the rear storage compartment. From there i could get limited inspection of the space under the shower. In the future I will cut a larger access to that space. Going CCW from the rear storage compartment I could get all around the rear of the trailer to the space under the kitchen drawers where the water pump is located. (So far I did not find any leaks).
In summary there are only 3 areas where I could not get (total less than 10'):
Between the left wheel and shower (4').
Under the shower (this can be improved easily).
Space under the furnace and fridge (5') = between the right wheel and the door.
Would somebody know if the area around the wheels is likely to get wet? I was concentrating on the front and rear perimeter (known problem areas) but now I am more concerned about the areas difficult to check.
Name:	under the bed looking at water heater.jpg
ID:	222096   Click image for larger version
Name:	Floor C channel where battery cable comes inside.jpg
Name:	Front of the trailer under the bed.jpg
ID:	222098   Click image for larger version
Name:	Under the closet next to the door.jpg
Old 09-17-2014, 06:41 PM   #31
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I can't answer your question, but I have been doing something similar on our 25fb. I would like to be able to see as much subfloor as possible by removing the vinyl flooring under cabinets etc.
Honeywell makes an area water alarm that will detect moisture along the length of a 4 feet long wire. I plan to buy a couple of these and install the wires on the subfloor in the hard to reach/ see areas under the kitchen cabinet and around the shower area.
Name:	ImageUploadedByAirstream Forums1411000847.632775.jpg
Landrum is offline   Reply With Quote
Old 09-19-2014, 03:10 PM   #32
bovk's Avatar
Beaumont , Texas
Great find, I ordered one to try, if not for AS it will work around the house.
Old 09-20-2014, 06:22 AM   #33
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Bovk and others - provide review on this later as I will be looking for something like this soon too
PharmGeek is offline   Reply With Quote
Old 09-22-2014, 08:17 PM   #34
bovk's Avatar
Beaumont , Texas
How to inspect plywood floor?
DKOTTUM wrote in another post :
Beyond inspecting shell seams, the moisture meter is an excellent tool, and if you are still uncomfortable back it up with a Seal Tech pressure leak test at an RV shop. We use the meter quarterly and had a Seal Tech test at two years, just before warranty expiration. We'll probably do it again on a two year interval.
I just brought it into this thread so we have a reference to the Seal Tech test. Maybe dkottum or others can described this test some more. I think it is related to this thread.
Via Airstream Forums
Old 09-22-2014, 08:32 PM   #35
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
In case Doug misses this, the Seal Tech unit is like a reverse vacuum machine, it pressurizes the cabin of the trailer - usually through one of the Fantastic Fan openings on the roof. Once pressurized, the technician sprays the exterior of the trailer with a soapy solution. Any gaps or imperfections in exterior seals will quickly be seen by large bubbles forming over those areas.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 09-22-2014, 08:35 PM   #36
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Thanks TinTin. Here's a page from their website, I believe it has a video on it.
SealTech Manufacturing USA | Industry Standard for RV Leak Detection
Doug and Cheryl
Old 09-22-2014, 10:43 PM   #37
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
doug...I forget now...you had jackson center do this test then they corrected the detected spot(s)?
I would like for leak detection as such to be on AS’s dime during the warranty period if possible of course...it would be useful to have this done within my warranty period just as a check and if any found they can repair...then after warranty period I like your idea of having this done ever 2 years....the cost?
Old 09-22-2014, 10:52 PM   #38
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
just watched the sealtech video...wow, that moho had a bunch of leaks....that is a very cool test....
what does AS folks say about such testing?
Does the process run any risk of damage to otherwise healthy sealed areas?
If you were to find leaks within warranty from a dealer down here somewhere, would AS authorize the fixes for the detected leaks?
Of course outside of the warranty, that would be a non issue.
Old 09-22-2014, 11:08 PM   #39
dkottum's Avatar
Pharm, I found the leaks first with my Sonin (they were real minor) then had Airstream do the SealTech pressure test while we were there for our recliner conversion, as well as their 27 point inspection, plus a bike rack and vent cover.
They fixed the leaks, and I have added some sealant around similar trouble spots (awning support bracket rivets and screws) since then as a precaution.
Our final bill at the Service Center was lengthy, because much of the repair was warranty, it was unclear how much the leak test was. I'm not even sure they charged us for it, they were very generous.
Normally they charge by the hour and I believe the leak test would be charged that way, or they may have a set charge. Many rv shops have the SealTech machine.
Airstream will want any warranty repairs done by an authorized Airstream repair shop. That would be a good reason for having an Airstream dealer do the test.
Doug and Cheryl
Old 09-22-2014, 11:19 PM   #40
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Generally we 'reseal' our whole AS. There is a member here who actually does this testing with his own rig for AS's.
My thoughts are.. "well, if air can escape and make bubbles like that, how do you know you have it 'sealed'? "
Solution: If we pull a negative pressure on the AS... very low.. say, 2-3, then wouldn't that help 'suck' the sealant into the invisible leaks?
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-30-2014, 01:11 PM   #41
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
So how is the shell mounted to the floor? Is the shell placed on top of the perimeter of the floor. If water penetration is detected how to you insure the part of the floor under the shell can dry and if you need to treat it how can you get the marine epoxy to that section of the floor under the shell lip?
So far I have not detected any water penetration from the rear bumper and front bedroom and entrance door areas using my Sonin meter I haven't read of any Classic owners seeing this issue only Safari and Flying Cloud owners for the early to late 2000s model year AS. Are the Classics built differently in that regard?
Kelvin
