Old 01-09-2011, 04:48 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
How to attaching the floor
This may be somewhere, but I'm probably to lazy to look for it.
I'm ready to start attaching my new plywood floor to the chassis.
I have 50 elevator bolts.
What do I use to
1) Attach those plywood pieces used as supports where the floor breaks.. to the chassis (elevator bolts)
2) Attach the edges of the plywood floor to the plywood supports?
Someone mentioned on another thread to use a Fozberry bit or something to make countersink holes (for the elevator bolts?).
3) Attach the CJ channel to the edge of the floor?
Big Baby will be getting her new entrails here soon!
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 01-09-2011, 05:06 PM   #2
x
XXXX , XXXX
What do I use to
they were never attached seperately to the frame. factory used floor screws through the floor sheets and doublers into the frame.
Same as above floor screws are what was used but elevator bolts can be used. I used screws and attached to both crossmembers and the main frame rails also. I needed more than 100 floor screws as well as the 50 elevator bolts through the c channel into the outriggers.
It's called a forstner bit.
If you are talking about the straight sections along the side of the trailer they just slide over the edge of the plywood, actually mine needed to be hammered into place. It was areally tight fit. The c channel on the end caps attach with elevator bolts and larger bolts and nuts through the front and rear hold down plates into the main frame rails.
I hope this answers your questions and as always will help as much as I can.
Chris.
wasagachris is offline   Reply With Quote
Old 01-09-2011, 05:20 PM   #3
DanielB's Avatar
Hey Chris. I appreciate the info.
1) So the forstner bit is to to sink the heads for the elevator bolts?
2) Where the floor breaks, you used floor screws on each side of the break and screwed them down into the cross members?
3) You used elevator bolts just on the outrigger? On the outriggers, did you use elevator bolts on both sides of the break?
4) So the CJ channel isn't drilled into the plywood floor at the edges?
- Andrew Carnegie
Old 01-09-2011, 05:30 PM   #4
x
XXXX , XXXX
Daniel I'm responding withour color so as to not offend the moderator Gods.
1) Yes it is a tool to create a counter sink hole in the plywood to allow the head of the elevator bolt to sit flush.
2) Yes on either side of the seam between each floor sheet I used the floor screws throught the floor and the small doublers of plywood into the crossmembers.
3) Each outrigger recieved three elevator bolts through the floor sheets into the outrigger. One was through the c channel and floor sheet in to the outrigger and the other two were just through the floor sheet into the outrigger.
4) It is attached with elevator bolts through the floor into each outrigger.
Old 01-09-2011, 05:44 PM   #5
DanielB's Avatar
I hope you are kidding about the font color thing.
That is why I can't go to state parks. I inadvertently wind up breaking 2/3 of the rules without even trying.
- Andrew Carnegie
Old 01-09-2011, 05:49 PM   #6
x
XXXX , XXXX
Daniel No I'm not they just editied another thread because of excessive color and font size. I'll have a pic for you of the wate outlet in a minute and will post into your thread.
Old 01-09-2011, 05:50 PM   #7
DanielB's Avatar
Awesome..
- Andrew Carnegie
Old 01-09-2011, 06:00 PM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Self tapping wood to metal screws can be used too. Here is an example. Trailer Floor Repair Screws.
I have found them at Lowes. IMO they are not a replacement for elevator bolts but for small area repairs they are very handy.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-09-2011, 06:09 PM   #9
x
XXXX , XXXX
Well I count six different uses of color font and four different colors as well as bold print. Must be different rules for mods.
Old 01-09-2011, 06:11 PM   #10
DanielB's Avatar
lol
- Andrew Carnegie
Old 01-09-2011, 06:16 PM   #11
1967 22' Safari
1960 Caravel
Images: 8
Just trying to show an example of "sparingly". I guess you are going to take issue with this. LOL!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-09-2011, 06:23 PM   #12
DanielB's Avatar
Nothing wrong with a little flair. Just watch out, the other mods might be talking about you behind your back..
- Andrew Carnegie
Old 01-09-2011, 06:29 PM   #13
1967 22' Safari
1960 Caravel
Images: 8
Yep! Talking about you. Watching you. All that and more...
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-09-2011, 07:01 PM   #14
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Yup...kind of like a double secret probation.
Some uses of color and bolding are acceptable (your reply is one of them) One of the main reasons for a consistent font is ease of reading across the forums.
Aaron
WBCCI #XXXX AIR #2495
The old girl needs new shoes.... Trex 1970 - 1973 Sovereign 1160 03-04-2017 10:39 AM
Is it a 'do over' ?? tvanwave Repairing/Replacing Floor &/or Frame 33 01-16-2011 06:13 PM
1966 Sovereign waste tanks Brianv512 Waste Systems, Tanks & Totes 9 01-05-2011 10:09 PM
Interior panel removal...floor access PA BAMBI II Repairing/Replacing Floor &/or Frame 1 01-03-2011 01:13 PM
